(sold) 7,000 lumen 12x Mod. This has half the emitters de-domed plus more. $110 free shipping. Two sold last one ready
This light is sold but I will be modding one more and selling it soon.
show photos !!!
As per our PM’s, second one sold, send me your paypal details please!
Oh and price too including shipping to Aus (ouch)
If you wanted to mod more of this form factor I just found this listing:
http://www.tmart.com/2pcs-CREE-T6-15LEDs-5-Modes-Waterproof-Flashlight-Set-Gray_p250042.html
No idea about the driver, but $52 per is quite a good price with modding in mind even if the driver is junk.
PM sent. Not too bad on the shipping really.
ugh… the description says… quick flashing 350000 lumens :Sp must be some kind of zombie blaster :wink:
Hahaha, completely missed that on my inspection… Sounds like it’s an even better deal with that ūber strobe mode driver! :smiley:
I am considering buying them but I wish I knew if it was the same driver. Because finding a good driver for these kind of lights is really hard. Most of the time they stink and you end up with a light that maxes out at 4 thousand lumens or so and trying to get a better driver is expensive. I’m done with the IO drivers. They are just not reliable enough. It’s got to be a good FET driver like the one I’m selling. That or the $50 flex driver that gets used once in a while.
What I thought was funny about the description of the ones I got was the 300meter diving part. Now that is funny. It’s got nice 0-rings but not THAT nice.
You’re not getting two lights but one light that counts as two pieces. That extension is the other half of the two pcs description.
I know this is a sales thread, but what exact light is this? There are at least a couple of UF 12X light form factors. Where is it from?
Since it's not mentioned, I assume you kept the stock LED's and stars? Kept the stock wires between the LED's? Just trying to figure out how you achieved this without resistor modding, unless it's one of the lights that are DD effectively...
The info I was given:
http://www.lightscastle.com/product/ultrafire-lw-12l2-cree-xm-l2-t6-7920…
It’s got great heat sinking and a very simple driver that is FET based so it cranks. I could actually crank it higher but it’s pointless. It gets screaming hot when it’s cracked up any more. It’s good right were it is. When I bumped it up more it didn’t do any good because thermal sag just dragged it back down. This seems to be optimal for it. It handles this heat well.
The emitters are just the old T6’s but they have a nice cool tint. The de-domed ones mix well with them and give it a cooler neutral. So it’s not quite neutral but close. It’s over 7,000 lumens with good batteries. King Kongs or Sony Green 30amps anything like that. Don’t bother trying to use protected batteries though. The amp draw is so high that it will pop the protection on them. But good high amp batteries run it great.
The low on it is right at 1,000 lumens and medium is about 4,000 lumens. Which is still unreal bright.
The emitters are actually on one large round star so it was really fun pulling six off and de-doming them and reflowing them back on. But I have it down now so it’s no problem. Just time consuming making sure to get them all on correctly.
It does get hot but surprisingly it handles it with no problem. But even so I would only use high as a turbo a couple minutes at a time at most.
The throw is surprising for a flooder. Some of it is just raw power but after de-doming it really added a bunch to it.
Ahhh, thanx! Ok - this is one of the new DD lights - useless on protected cells. This explains a lot... No resistor mod necessary.
This thread: https://budgetlightforum.com/t/-/25099 mentions the 9X and the 12X -- over 13A at the tail on the 9X! Sounds like fun Wink. Looks like 18sixfifty posted the order from this thread.
This seems like the best deal, only 8 left: amazon.com/SUPERNIGHT 12X
Justin - please be careful.... 18sixfifty did some nice tweaks, but the output is from sheer incredible power draw from the cells...
I'm trying to hit bout 5.5A tail on a 9X, and be happy with that...
Uh Tom… that amazon link showed 2 different version of the supernight 12X…black and grey on different body too… I wonder if the driver is the same for both?
Thanks for the heads up.
I have kinoko 26650 rated to 20a continuous discharge and also sony 26650 rated to 50a :slight_smile:
The link should just get you to the gray version (3rd pic). Choosing other pics is choosing completely different lights. My guess is the black 12X in the same style is probably the same driver, LED configuration, etc., but it's only a guess. The different 12X body style is probably very different.
Hmm. If that’s the case there’s a lot of misleading phrases in the description.
I got two of mine from Lightscastle and a third from an e-bay seller. They all had the same FET driver in them. It's this one.I have no idea if they all have this good driver though. So like any light it's really a crapshoot.
OK I sold two of these and now I’m going to sell the third one and buy a few more before they go and switch the driver out to a junk one.
Do you think ordering this: fasttech-ultrafire-lw-12l2-12-cree-xm-l2-t6 will get real XM-L2's? Looks like the same design/light but described and shows XM-L2's. I'm thinking it would be another crap shoot...
Lightscastle sent me the first one to review and it was supposed to be XM-L2. They said the supplier messed up so they had the supplier send me another one for free. Nope same XML’s in it. So Lightscastle gave up and changed their listing. It’s very hard to tell that there is a XML by looking at it. On first glance all you see is the little silver square that is right around the emitter. You have to take it apart or look kinda sideways and catch a reflection of the green board. It would be really easy to sell this as an XM-L2 and never know you messed up. It says something good about lightscastle that they changed their listing.
As for fasttech, who knows? You could try and contact them and make them look for the green reflection before sending it out. You seem to do pretty well with them when it comes to customer service. It would be nice if it was, so let me know if they confirm that they have the XM-L2’s.
edit: Looking at their picture it clearly has different spacers than the ones I have gotten.
