I'm excited about those mcpcb's. I ordered them directly from dsche and they were supposed to be delivered today, but I'm not sure what happened. XP-L Carclo optics are coming, but I don't know anything else about them.
So these are called “20mm quad optics”, but the actual diameter for the lens array is 24mm? So, this star + optic would require a pill that takes a 20mm star, but the head inner diameter would need to be at least 24mm?
So these are called “20mm quad optics”, but the actual diameter for the lens array is 24mm? So, this star + optic would require a pill that takes a 20mm star, but the head inner diameter would need to be at least 24mm?[/quote
Sorry you are correct, the optics are actually 24mm Quad Optics, my error.
I’m probably being a bit obtuse. I get the (1) and (2) configs, but I don’t understand the (3) config (4P). Why are there 3 “wires” from the right side (battery side) to the left side (star)? I probably would just want the 4P config, so how do I wire that “normally” (= only 2 wires from the driver to the star)?
Does anyone know the answer to my question above, per a more conventional 4P configuration (4 emitters in parallel) and just 2 emitter wires (+ and -) from whatever driver I use to the star pads?
Thanks, I’ll do that. I have a couple coming also from IS. I saw that thread earlier, but it seemed like it was an older thread and all the links don’t work (for me at least), so I wasn’t sure if it was still active.
If you do figure it out, please post, and I’ll do the same.
