Thanks for the review! A pity that this light does not perform as you hoped, I like it very much.
I have this same light, but the 2013 xp-g version, and that one can toggle between two low modes, one pwm-controlled, not really moonlight, and one much lower one without pwm. To toggle, with the head loose you cycle three times through the modes. I wonder if that is build into your light also.
Yes, to switch between the “moon mode enabled” mode group and “moon mode disabled” mode group, the process is: loosen the head a bit. Turn the light on. Quickly tighten and loosen the head three times, making sure to go all the way to turbo and back each time.
This is how I obtained the two different groups of measurements in the review.
The light can also toggle mode memory, by doing sort of the opposite. Tighten the head, turn the light on, then loosen-tighten three times. I haven’t tried this though, since I don’t want mode memory. (or so the manual says, anyway… but I just tried it and it doesn’t seem to enable mode memory on either the regular or turbo modes)
Edit: Though the printed manual said it had an option for mode memory, the web site says this is D25C only.
I think this would be a much, much better light if I were to replace the double-AR-coated lens with a plain sheet of glass (assuming I can get the lens out somehow). It’d also be very nice to have a moon mode, but I don’t think that’s something I could fix on my own.
Just guessing away (I'm a mere onlooker on what the electronics guys are doing at blf), the moonmode is current regulated, so perhaps there is a physical path on the circuit board taking care of that, and a resistor might be replaced by a higher-ohmed one to lower the moonlight?
Thanks for the review, ToyKeeper! I had considered one of these until I heard of it having poor anodizing.
The blue halo, is the lens AR coated? I get the same halo on my Rustu 108S after switching the lens to AR coated (it is coated on both sides). It only appears when the light is pretty close to the wall:
Chloe, yes, the lens is AR-coated on both sides. I think that is probably the cause of the blue ring and lower-CRI beam. The AR coating may be acting like a prism, splitting different wavelengths of light to emit at different angles. On a high-CRI light, this is a Bad Thing. It seems to lower the CRI by like twenty points, to the level of a typical Cree LED.
I have other lights with AR-coated lenses though, and none of them make a bright blue halo. The worst is my JB RRT01, which has an extremely faint tertiary corona with a blue-ish tint, but I hadn’t even noticed it was there until I went around checking all my lights for halos.
djozz, you’re probably right about the resistor but I don’t think I can get at the guts of the driver. I don’t even know if I can get the pill out. I’m hopeful that I can at least swap the lens for something less blue though, since the specs state it has a user-replaceable lens. I think that means the pill is supposed to unscrew, though with just my hands it won’t budge. It’s probably glued in place.
I’ll probably try to contact EagleTac before attempting to break the glue. I’ve also asked the vendor if they might be able to check other units for the bright moon mode and blue ring, but I’ll understand if they don’t want to turn mint-condition stock into tested-once stock.
Thanks for the review ToyKeeper. If you manage to get the head off, I’d be curious to hear what the tint is like with the lens removed. Do you think the bezel depth could have anything to do with the blue corona you’re seeing?
Also, I’m sorry to hear the moonlight mode is as bad as it is. I don’t expect something as good as a Zebralight in terms of output and runtime, but I was hoping it would at least have a sub-lumen moonlight mode, especially considering it’s a limited edition light.
About the blue ring, it is on my ET too. I don't think it affects cri in a negative way. It is a bit of double reflection happening to a minor portion of the light that strikes the lens at an angle (light coming direct from the emitter going to the edge of the lens), almost all of the light (more than with a non-AR coated light) , and especially light coming from the reflector forming the hotspot, just goes through the lens unaffected: all wavelengths equally well.
Thanks for the review. I got the Ti XM-L2 version and I’m not sure what to make of it. Mine won’t work on regular Eneloops and only works on 14500, which is OK I guess.
The moonlight mode on mine is only about 5 lumens, so it’s still acceptable as a low-low to me. It’s also got an ugly, ringy beam with a blue-ish tint. The output is impressive, though, and it’s super-lightweight. And of course they make the best deep carry clips of any manufacturer. So I have definite mixed feelings about it.
Still trying to get a good stacked focus shot of mine:
You could try cleaning the knurling with a mild abrasive like toothpaste or jeweler’s rouge and a small brush (if you will keep it, with all the flaws).
Thanks, it’s interesting to hear that other units also have the no-moon and blue-ring issues. Sigh. I’m glad mine works with Eneloops, at least. No Eneloops would be an immediate deal-breaker.
Also, how many pictures did you stack? Looks like maybe about 8 images?
My early 2012? version ones on moonlight mode w/ a AA do what a zebralight h31 does on it's lowest low . On a 14500 I like how it becomes a 2 mode light . it runs about 25 lumens low and 600+ on high . Even though i know it's coming I'm always impressed when I change modes .. If I had to change one thing I'd change tint and cri .. overall I like them.
I was expecting something more like the 2012 version; reppans posted a pic of its moon mode compared to other lights. It’s a bit on the bright side (maybe 0.6 lm), but it was still under a lumen and pretty close to spec.
that’s a great review.
i don’t think the weight diff justifies
the price jump from alum to titan.
i EDC an alum d25a xp-g2 and i can’t find anything about it
that i would change. i love the ease of twisting the head to get to the hidden modes. i love the beacon mode way at the end of all the hidden modes. i think the beacon mode can flash for months. it is so small that sometimes i can’t find it in my front pocket. why carry an AA light that’s big as a 18650 light ?
i have an ultrafire AA light that has the same head twisting -
mode changing feature. it would be a good host
Anyone know how to unscrew the head on a D25A? EagleTac support told me to try that to see how the beam looks without the lens, but it’s glued in place and the usual padded-pliers trick didn’t work.
I think I’ve heard about melting the glue first with heat, but I’m not sure how to heat it up without causing any damage. Just hold a clean soldering iron on the head and slowly rotate to different spots to heat somewhat evenly all around? Maybe roll it around on a clean pan on the stove/range? And then, I’m guessing, pick it up with gloves on and try to unscrew it by hand? How likely am I to damage parts inside, like melting the lens O-ring or damaging the emitter or unsoldering things?
Pour boiling water over the head from a kettle, maybe put it in a ziplock first if you’re not confident about waterproofing.
Some people boil the whole thing in a pan after freezing it.
I don’t know why all Eagletac flashlights use the same type blue AR coating.
I tested the T25C2 some time ago and it has the same blue corona.
I don’t think it’s something that should exist in high price/quality lights.
By the way T25C2 is the worst flashlight I have tested.
