The smaller package allows more LEDs to be tightly packed together. Remember flashlight use only accounts for a small amount of LED sales.
According to cree’s specs, thermal resistance has not been reduced. 2.5 °C/W same as is listed for XM-L2
What? Look at the chart again. 200 Lm/W is right there at the top. If has an efficiency and output lead throughout. Maybe that will change at higher currents. In my near time mods, that's not going to be an issue.
Bins don't matter here since the XP-L V6 bin is currently available, and the highest bin XM-L2 is the U3 and is virtually impossible to acquire. The V5 is almost the same as the U3, so there's still a gain even if the availability of the V6 goes away
If it can't be overdriven to 2000 lumens due to the smaller footprint, hopefully Cree comes out with higher bin XM-L2 or XM-L3. The problem with XM-L3 is that there aren't any triple or quad direct bonded copper mcpcb's, or Carclo's to put over them.
I thought the typical well known (to us) X-lamps were actually designed for things like flashlights.
Up to now i haven’t encountered them anywhere else.
There is at the moment (no date added) an announcement on the Cree homepage that they have improved the XP-G2 (7% brighter), XM-L2 (18% !! brighter) (and MK-R and CXA leds as well). We'll see when those become available.
I think you're deliberately making a false comparison. By your own account, where the XP-L is able to do 200lm/W, the XM-L2 is doing 194lm/W. You're still acting like XM-L2 is only 100lm/W and then acting amazed at how the XP-L is such a great leap forward. Apples and oranges. They're also different flux bins even though there's absolutely zero evidence they use a different die - except for the bump up in flux bin. An XM-L2 V6 bin would be virtually indistinguishable from a XP-L V6.
Is it just me or does it appear that the tiny fragile bond wires are missing in this new version? If it indeed has a post for the bond wire, might it also handle current better? Higher?
Looks like the Vf is right between XM-L2's and XP-G2's -- that's a disappointment. I think comfy is right - not much to get excited about. Only nice jump would be lumens if it must be done on a XP-G/XP-G2 footprint, and the lower Vf compared to an XP-G2. If you had to de-dome to make it fit optics, you'll lose lumens of course.
Actually I would love to drop one in my T10... I have the stock XP-G in there now.
No, I'm making a mathematically accurate comparison. It's like you're selectively reading to prove your point. Like I said, the XM-L2 U3 is virtually impossible to acquire, and even if it were, the XP-L V6 is still brighter and more efficient everywhere on the data sheet. That's why I didn't put the U3 on the first chart, and apparently I shouldn't have put it on the second chart because you've misinterpreted why I put it there. Sure, there's a data sheet for the XM-L2 U3, but good luck acquiring that unicorn. There's no such thing as a XM-L2 V6 at this time, although the news djozz pointed out may change that very shortly. I'll stick with comparing what I can get my hands on. That is at best a XM-L2 U2 and a XP-L V6, and the XP-L V6 is undeniably brighter and more efficient. Whether or not it's perceivable by eye is hardly the point. I'm talking hard numbers here.
You're wildly misinterpreting how you think I'm acting. Better is better. If you are waiting for revolutionary improvements, improvements that are readily determined by eye, you wouldn't even be using XM-L's yet, much less XM-L2's. Maybe that's all you care about, and if so, good for you. I can understand that aspect, especially if the older emitters are much less expensive. As for me, if I can get the brightest and most efficient emitters for an application, then that's what I want even if I can only tell the difference with a lux meter.
It is possible to misinterpret the significance of a mathematically accurate comparison, you know. The difference between any one XM-L2 flux bin and its one-step-higher or -lower flux bin shows about the same difference in total lumens and efficiency and everything else as the chart shows between XM-L2 U2 and XP-L V6. It's nothing but a single-bin bump XM-L2 die stuck on a smaller substrate. That's not a bad thing, of course, but it's nothing particularly remarkable or revolutionary.
So since you're all about the math, how does a dedomed XM-L2 compare to a domed XP-G2, since that's what started this whole thing? Of course dedoming loses some output, but it will still be more than the XP-G2 with very similar beam characteristics. You seem to be saying that a dedomed XP-L would be a step backwards from a domed XP-G2 and that's just not supported by facts.
Qty 2 of the V6's ordered from IS... Gotta try em out. Your both right - it's a bump, not a big bump, but could be the best available for what it is... The Vf is closer to XM-L2 than XP-G2, so should make a nice replacement of XP-G2's. I'm not planning to de-dome them - I'll let some other sucka, I mean modder, try that .
Right on the homepage. The top-banner changes news automatically, it is not there, but below that there are three more items, one of them is 'Xlamp Leds Are Even Brighter'.
