I think you're deliberately making a false comparison. By your own account, where the XP-L is able to do 200lm/W, the XM-L2 is doing 194lm/W. You're still acting like XM-L2 is only 100lm/W and then acting amazed at how the XP-L is such a great leap forward. Apples and oranges. They're also different flux bins even though there's absolutely zero evidence they use a different die - except for the bump up in flux bin. An XM-L2 V6 bin would be virtually indistinguishable from a XP-L V6.
Is it just me or does it appear that the tiny fragile bond wires are missing in this new version? If it indeed has a post for the bond wire, might it also handle current better? Higher?
Looks like the Vf is right between XM-L2's and XP-G2's -- that's a disappointment. I think comfy is right - not much to get excited about. Only nice jump would be lumens if it must be done on a XP-G/XP-G2 footprint, and the lower Vf compared to an XP-G2. If you had to de-dome to make it fit optics, you'll lose lumens of course.
Actually I would love to drop one in my T10... I have the stock XP-G in there now.
No, I'm making a mathematically accurate comparison. It's like you're selectively reading to prove your point. Like I said, the XM-L2 U3 is virtually impossible to acquire, and even if it were, the XP-L V6 is still brighter and more efficient everywhere on the data sheet. That's why I didn't put the U3 on the first chart, and apparently I shouldn't have put it on the second chart because you've misinterpreted why I put it there. Sure, there's a data sheet for the XM-L2 U3, but good luck acquiring that unicorn. There's no such thing as a XM-L2 V6 at this time, although the news djozz pointed out may change that very shortly. I'll stick with comparing what I can get my hands on. That is at best a XM-L2 U2 and a XP-L V6, and the XP-L V6 is undeniably brighter and more efficient. Whether or not it's perceivable by eye is hardly the point. I'm talking hard numbers here.
You're wildly misinterpreting how you think I'm acting. Better is better. If you are waiting for revolutionary improvements, improvements that are readily determined by eye, you wouldn't even be using XM-L's yet, much less XM-L2's. Maybe that's all you care about, and if so, good for you. I can understand that aspect, especially if the older emitters are much less expensive. As for me, if I can get the brightest and most efficient emitters for an application, then that's what I want even if I can only tell the difference with a lux meter.
It is possible to misinterpret the significance of a mathematically accurate comparison, you know. The difference between any one XM-L2 flux bin and its one-step-higher or -lower flux bin shows about the same difference in total lumens and efficiency and everything else as the chart shows between XM-L2 U2 and XP-L V6. It's nothing but a single-bin bump XM-L2 die stuck on a smaller substrate. That's not a bad thing, of course, but it's nothing particularly remarkable or revolutionary.
So since you're all about the math, how does a dedomed XM-L2 compare to a domed XP-G2, since that's what started this whole thing? Of course dedoming loses some output, but it will still be more than the XP-G2 with very similar beam characteristics. You seem to be saying that a dedomed XP-L would be a step backwards from a domed XP-G2 and that's just not supported by facts.
Qty 2 of the V6's ordered from IS... Gotta try em out. Your both right - it's a bump, not a big bump, but could be the best available for what it is... The Vf is closer to XM-L2 than XP-G2, so should make a nice replacement of XP-G2's. I'm not planning to de-dome them - I'll let some other sucka, I mean modder, try that .
Right on the homepage. The top-banner changes news automatically, it is not there, but below that there are three more items, one of them is 'Xlamp Leds Are Even Brighter'.
It looks like we're getting closer to being on the same page, except for the second part. Let's look back at what I actually said.
I don't see how that could be any clearer.
I am truly interested in those facts though. I've seen many claims of lumens being lost to dedoming, but I haven't seen a formula for it. There's some data here and there, but I haven't seen it tabulated. I'd really like to have a better look at those numbers so I can come up with a decent prediction of how much of the gains would be lost. Is there enough information to estimate a data sheet for a dedomed XP-L? That's academic though. As I said, I don't have plans in the near future to put it under a Carclo, and if someone doesn't try it by then and there's still no XP-L Carclo, then I'll go ahead and take that gamble myself.
Actually, I may have been mistaken when I listed the XP-G2 S3. The S3 is pretty hard to find too. The S2 would have been a better fit in that chart. Anyhow, I don't feel like pulling up the S2 data, so I'll stick with the S3. The XP-L V6 has 26% more lumens at 1.5A than the XP-G2 S3. How many of those 152 lumens would be lost when dedomed? I predicted that the loss would be <152, but >76. Note that I used ">" instead of ">=".
I think the next thing I will be interested is, when kaidomain or fasttech or such gets these in stock. Cutter.com.au is a bit pricey for hobby builds or any series of builds.
1. Cree claims the smaller size means they are cheaper to make than the xml2. I want to see this in action at that checkout.
2. Pretty much a small, but important, improvement on the xml (in efficiency and beam discipline), not xp-g2. (The xpg2 is still what I would want in anything sub 2x18650, like 1x18650 or 4 aa).
3. I got my willbuying xml2 u3 in like 7 days from order to usa. Really would like to see the xpl against this led. I haven’t done anything yet with my u3. I am thinking of building a tripple goose neck (3x hydra neck of about 3ish inches long each, pointed seperately—not too long and bouncy, but long enough), maybe xpg2 in center, mounted to a 4x 18650 pack with ledsupply 700 ma cc dimable controller, and velcro straps for mounting on a paint roller pole &/or bike.
I've seen ~20% in loss of lumens from de-doming with XM-L2's, maybe slightly less, using the gas method. I've heard of lower percentages but I just haven't seen any much lower, maybe 18%, but don't think less than 15%. This is several lights, including Super Shocker triples, but several XM-L2 singles as well, like HD2010's, C8's, etc. Can't guestimate XP-G2's - didn't do enough to see apples to apples. With the de-domed XP-G2's I always seem to lose amps, thinking from a higher Vf - others seen this too.
I’d also like to have a better feel for efficiency lost by dedoming. Sounds like a lot of work for somebody though, so I/we may have to make do without.
I was going to reply that I wasn’t so sure about this. I thought I’d looked into this previously and concluded that even a cut XM dome would not fit. Turns out that after reviewing the facts again, it seems clear that comfychair is correct. I don’t know what went wrong the last time I did this, but here’s the deal: The XM-L dome is approximately 4.4mm. I roughly measured this myself just now. The diagonal of an XP- sized package is ~4.737mm. My math isn’t so good these days so I used a calculator to get the diagonal. As you can see, this leaves plenty of room for the little spaces we’ve got in the corners of the XP-L (>0.15mm for each corner). Clearly comfychair is correct about the dome size.
I think they may have sharpened up the area where the dome joins the plain of the rest of the package. Previously there seemed to be sort of a small curved transition, this seems to be gone for the XP-L.
