I like the design of this light, and it looks like quality product
Aw-right Tom, nice review.
The SupFire L6 looks like it has a really nice tint and a fat spot.
Fine review, Tom. I have been an admirer of the M12 from the get-go.
Thanks for the review! I love it, it might just become my first 26650 thrower (waiting for the group buy :-) ). I actually like that it just has a tail switch, I'm not into fancy UI's and it makes modding with other drivers nice and easy.
Thanks Tom E. My first question was going to be is the reflector the same as the HD2010. Thanks for the quick responce. I'd be interested in what the beams like comparing the two together at a distance if its on your agenda.
Thank you for a well done review Tom!
Looking forward to see driver, more info about the mcpcb, and discharge result.
Seems like a pretty nice light. Although a tad expensive for a light with fairly classic "mediocre" 5- mode driver. Personally Im not a fan of the forward switch.
If maxtoch or someone is doing a Group-buy. Please make it a proper GB with a properly lowered price. Not just the equivalent of a 10% discount code.
Yes - the reflector is also what I was interested in, compared to a HD2010 - figured many would be interested in these two head to head. The head outer dimension is basically the same between the two, but the bezel on the M12 is thinner, and the reflector design more efficient with a thinner top lip, so that's where the 4.85 mm gain for the I.D. comes in. I wasn't pleased how the white wall shots came out - doesn't show exactly what I was seeing in tint or brightness spread around the center beam.
I have to do some exploration to find an outdoor venue for shots. My backyard is quite small - not much open land locally.
I'll update the OP with camera settings. Also, I got the discharge test running now while I'm at work - should take at least 10 hours... I'm doing the 26700 and a KK ICR 4000 button top.
I'll be adding updates once I crack open access to the driver and MCPCB as well. I pretty much hate the stock 5 modes too -- think many of us feel that way... Amanda -- are you reading? Please take note!! The tactical switch is a tough call - this may suite their targeted market well, but the SOS should go, and debatable about the strobe - some have a use for it, others don't, just wish it could be hidden better, though being the last mode with the modes restting to high when OFF isn't too bad because you never have to see it if you toggle through hi-med-lo-OFF. Lack of mode memory is an advantage in this case.
I would also like to see more aggressive heat sink fins, maybe working higher up the head. There's not enough in mass and surface area. I know it's a trade-off between function and style.
I voted for this one in the group buy and spoke with Amanda about getting one of the first ones, but communications broke down somewhere along the way and I’ve missed out. I must’ve confused her with my SN51 purchase.
I’ll get back on that, as this looks like a very nice light. My shelves are filling up, might have to sell off something to make room, but…
Appreciate the work here, with ticks in all the right boxes it’s pretty much a no brainer.
If it sell for $40 I might take a bite… group buy for $40? :bigsmile:
Why Tom for such a nice review, now I want to buy now. Hope ya got time for another mod haha
Thanx All! I'd love to even see $52 for a group buy - no bag, $12 option for the 26700 battery. Krono is the group buy man of choice for this - I have no interest in doing one -- too much work!
Figure $30 is the regular discounted price on a HD2010, LED/star and AR lens are worth maybe another $12. There's another couple bucks for better quality components, and of course, you can't buy a 25 mm copper star (still to confirm), and so many untangibles, like the centering ring sucks on a HD2010 - they have been loose and so difficult to center the LED, you have to loosen the pill for a tight fit to the reflector, or use the o-ring on the pill (not a good idea), the anodizing finish, water resistance improvements with the high qual threads and o-rings, style, bigger reflector (more throw), better regulation from the driver so you can use quality cells and not worry about smoking the LED or having major heat sag droppage (classic problem with stock HD2010's), no chinese lottery on the driver. Also you don't have to worry about the crappy packaging from TMART, the nicks, finger prints on the lens or reflector, hit/miss quality of the reflector, fogged out lens.... I'm sure I can continue on this, ugh...
Even after addressing most of the HD2010 issues with mods, you are still left with a budget looking light less capable (smaller reflector, can't run 26700 cells) where every component basically has been replaced. I've got around $75 into a couple of HD2010 with copper pills, more closer to $100 considering 2-3 stages of mods over time. Don't get me wrong - I still like the HD2010 (keeps me busy), just the M12 is a different level.
Great review and it sure is a nice light. I’m usually into the ZY-T08 for a light this size but that one is really nice.
Have you seen this driver yet from Lightmalls?
4.2V Single Lithium 5A 3-Mode LED Driver Boar Cree XM-L T6 U2/SST50/MCE/SS-P7 (5-Pack)
Voltage: 2.7~4.5V (factory protection voltage: single lithium in 2.7V,Constant current output when the voltage is higher than the LED VF value)
Temperature protection :55-60 degrees (Change to the low mode and flash one every 5seconds when protection)
Constant current: 5A
Low voltage protection: single lithium in 2.7V (the mode will change to low and flash two every 5 seconds when protecttion)
Modes: 3 Mode (100%High - 30%Mid - 5%Low) Power cut off less than 2 secondschange the modes,more than 3 seconds,keep at the same mode.
This might be a nice option for this light. I bought a give pack a while back but they were not exactly right. More like 5% 80% 100%. I have another 5 pack on the way and they promised me that they programmed it right this time. The output was impressive for sure. I stuck one in a HD2010 and a few other lights. Supposed to get the next batch very soon, I’ll let you know how they work when they come in if you are interested.
It works good in a bigger light, but didn’t cut it in the C10’s that I built. It would go into protection almost right away.
I see what you are saying. Although from a factory standpoint. Adding AR, copper mcpcb, and going from T6 to U2 is probably no more than 5$ over the regular parts. HD2010 GB price was about 20$. That is about 30-40% discount. That is a Group Buy price!
M12 is 67$ with battery and holster. Battery might be around 10-12$. That leaves 55-57$ for light with holster. Remove 4$ for holster and we are down to 50-52$. Now if we could subtract 30% from 50$. Then we are looking at 35$ for the light. Then we are talking GB! :) Or Maybe 45$ with battery.
IMO the whole purpose of a GB is to get a price way below what a typical 10-15% discount would give.
If the light were 52$ then why call it a GB? Its not even a special price or deal. Where is the discount??? Its just regular price minus some accessories that you are not paying for.
The term Group-Buy seems be be more and more watered down lately.
LM Driver - Dang, yes - that driver does look interesting. That temp protection is a concern. If it trips right away in a C10, then it's probably reacting to the heat build up in the pill (housing and/or air). Always wondered bout this - in most conventional lights, we thermally attach the star to the pill top, then on the pill bottom we electrically/thermally attach the electronics... So we built a nice heat path direct to the driver... Hhmm, something seems wrong there. In C8's, I was typically adding copper in the pill, further reducing the air thermal barrier, and getting the pill housing itself heated up even quicker.
It has a hugh pile of resistors! I assume those are current limiting, not sensing. Do you know how the PWM's are with that driver?
Nice figuring Race, except for one thing…the bottom line is ALWAYS going to be about the cost/sell ratio. If the original group buy on the HD2010 saw a 30% net savings, then it was because the HD2010 had that much ceiling. If the MAXToch Mission is already a good price over cost to produce, there’s no way they’re going to drop 30% off it for a group buy and lose money. Would you? So while it’s nice to figure every group buy should have those margins, it’s not realistic. Who knows? Maybe the Mission could be sold at cost for $15, but the quality bely’s that train of thought. And sometimes, when the manufacturer starts listening to the needs of the consumer, more parts have to be outsourced, driving up cost of production.
This is a new light, and the first run sold out quickly. Why should they discount it in order to sell, when they’re selling all they can make at asking price?
I’m in for one as soon as round 2 comes through, with the cell and the pouch. Amanda? Write me up, please don’t lose me on this next round…
Just took the HD2010 into the shower to check the PWM and I couldn’t see any, but then I only notice it when it’s bad. Not too dark in there either. But it’s not bad anyway.
On the heat it’s a good question but I notice that I am most likely to have problems when it’s simply too small of a pill. So it’s probably a little of both. Little too no air and the heat is right there hitting it almost directly.
What this driver did when it got too hot was stick in high and then you had to shut it off to get back the modes and then it would do it again and again. I never did kill it doing that though. But I didn’t have it long, it was for Manxbuggy. He still has it that way I think. That was driving an XP-G2, if that makes a difference.
edit: it had no problems at all running an XP-G2 in a ZY-T08. It really made for a nice light that way.
I replaced it, due to those issues. If that was the same light. Put an BLF17DD in it with the STAR firmware. Don’t remember if that was an HD2010 and I also put one of Ryan’s copper pills in it or not. I’m thinking it was though. I forget too easily. Could it have been in a C10?
At any rate, I’ve always wondered the same thing…how is it we expect the pill to pull mega heat from the emitter, and keep the driver cool at the same time? We need some isolation, separation, freon!
It was a bummer that it wouldn’t work right in that light. I let him know before sending it but I think he just wanted to see what it was going to be like on high.
Did you end up getting to use the driver in something larger?
Yep it was in a C10, just no room at all for it to get rid of heat.
It’s funny but on a lot of lights with larger pills I prefer to just hang the driver from the contact board so it’s not making contact with the light at all. I never seem to have problems with them when I do that.
Want’s maximum overdrive in all his lights, little ones notwithstanding.
