Test/Review of Powerex AAA 1000mAh (Black)
Official specifications:
  • Capacity: 1000mAh
  • Battery size: AAA
  • Voltage: 1.2V
  • Dimensions: 10.3mm (Diameter) x 44.5mm (Height)
  • Chemical Composition: Ni-MH
Maximum temperature raise at different discharge currents: 1A:+2,1°C, 2A:+4,8°C, 3A:+7,9°C, 5A:+11,1°C
High capacity AAA batteries with nearly 1000mAh
The battery does very fine up to 1 or 2A, but 5A is definitely to much.
There is some difference between the two cells, this is not a large problems with NiMH batteries.
Conclusion
It looks like acceptable batteries with high capacity, but there is not much difference from 900mAh rated batteries up to these.
Notes and links
The batteries was supplied by Danaco for review.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Thanks for the review, sounds good! If they are priced right they are my next AAA's for the baby phone :bigsmile:
Thanks for reviewing this. Do they make any claims regarding battery life and charging cycles. ?
There is a "Can be recharged up to 1000 times" statement on the dealers website, on Maha's website it says hundreds of times.
Thanks for another great review HKJ!
