More photos added to case postā¦ worked on it a bit more before work this afternoon nearly ready for connecting stuff inside and seeing how it looks onā¦
yay I should be finished in a few more daysā¦ unless I find Iām missing something else! YAY.
okay, warm white tube all wired and ready to connect, finishing the cool white tube tonight. more stuff goes in this one. so more to do pondering how I want to attach them together. for now I might use ziptiesā¦ as the hose clamps I wanted to use are too shortā¦ gotta get 2 small ones to make em just a bit longer
then may have to lengthen the power wire as wellā¦ eventually I might use a hobby lipo pack. but for now. external 4500mah 12 volt gel cell
yup. its not as good as your light but it worksā¦ I should have bought a 100 watt led and a driverā¦ maybe Iāll make another one with a 100 watt led and driver in itā¦
this one is good for ceiling bounce during a power outage.
thank you i hope not too. but I know the power grid in this area. a good thunderstorm/windstorm and its almost 100% likely to fail. sometimes for as much as a weekā¦
Sweetness. I haven't been here for long time. Love the active cooling solution. I haven't read all your posts, so please excuse me if you already covered this question. Have you thought about cutting/grinding the corners off the fans and putting them in the tubes?
