Dont. Use emitters located below black body locus (Edit: 1 and 4A and D tinted emitters). Less chance of getting a messed up green. I have said that for a long time. Still sticking to it and the findings above shows the tint shift towards green too. Even with the tint shift seen from 1As and such, im often not happy with them after de-doming. Often too greenish. But in theory better than de-domed 2C.
Correct tint mixing can fix bad green tint though.
I was not too pleased with my XM-L2 3A that I de-domed. Only did one though.
There is also some randomness when it comes to de-doming and tints. So If you de-dome 10 emitters, you are more likely to get one or some with a not so bad tint.
Amazing test. If this is the quality of your posts, I'm going to have to check out your other 4 posts. I'd love to know how you did the first test. I was looking at some sensors on Sparkfun a couple days ago and thought they might be able to create results like this, which is more incentive to start playing with Arduino.
I held the sensor directly towards the LED at a distance of about half a meter, but distance is not critical. I had to pay attention not to twist it at all as the results were drifting then, perhaps due to some effects in the perforated plastic grid front of the very sensor. The sensor gets along fine with the illuminance, even at very high amps. It has problems though with the much higher illuminance if you point at it with a flashlight (that is, LED with reflector or lens), unsurprisingly. More distance, or a good gray card and indirect illumination is required then.
Difficult, especially if the actual chroma coordinate of your LED is at the upper end of "2C".
It might be important that 1A is much cooler and the shift is more high-angle than for 2C.
Best conditions: It's both below the black body curve and relatively warm (that is, low angle and shorter shift).
By the way, while doing the above tests I searched the forums (most results here in BLF) and found positive reactions about all 4C/D, 3A/C, also negative reactions about 3C (surely both a matter of taste and the variation within one bin), as well as negative about all 1* and 2*, and 2B/C, 3B.
I would be happy to test them all if you send them to me :) (should mention that this means germany). I'd send them back to you at my own cost, for reasons of curiosity. However, both color bins don't seem to be "promising"...
I've got an XP-E2 R4 1C that I installed in a reflector with a pinhole type opening. The tint is really green. Is it possible that the dome got cracked or damaged at the base to produce such an ugly tint?
The tint is not as green in real life as in the photo, but it's pretty ugly.
I ordered red another XP-E2 R4 1C just to find out if this emitter is damaged or flawed. It's just makes me feel like it's been dedomed with the dome still on.
Thanks djozz. Read that way back when, but missed or didn't understand this paragraph at the time (from linked thread in djozz's above post):
"Another observation can be explained by this: XM-Ls have quite some angular tint shift, i.e. the light emitted to the side is substantially more yellowish, while with the dedomed LED this effect is greatly reduced. The YAG phosphor has a refractive index of about 1.8. the critical angle agains the dome (~1.5) is about 55°, which means that such a ray to the very side has traveled a 74% longer distance through the phosphor compared to a perpendicular ray and more blue photons get converted to yellow. Without the dome, the critical angle against air is 33°, resulting in only 19% longer distance in the phosphor and thus much less angular tint shift. See these nice images by Tecmo: https://budgetlightforum.com/t/-/11595?page=8#comment-254514 (post #431)"
Apart from being injured by overheating as abovementioned, it might perhaps just be an LED from the upper "green end" of the 1C area?
I really believe you would see mechanical damage with a magnifier or even the naked eye.
Indeed. I guess, strictly speaking they should only be used with a calibrated chain (camera, software, graphics card+monitor).
Absolutely! It both covers tint shift and increased luminance. That's why I also had linked it at the very beginning of my post:)
His post was the first time I learnt the real explanation, instead of the idea "same lumens from smaller area".
I’ve also read his post several times. Even if we set all of his other work aside, that one post is and has been a huge asset to us!
Like ImA4Wheelr, I don’t think I really absorbed the tint shifting business DrJones presented until looking at it this most recent time (which was after reading SMA’s great post showing where the rubber meets the road!).
