My bad - I was the one that posted the Amazon link. Sounds like a different driver than the LightCastle version. We don't know now if old/new batch's or good/bad batch's, or if Amazon's version is simply built differently than the LightCastle version, or you got a single piece klunker. Beam shot compares won't help if it's a different version.
Wait -- the amazon listing clearly states it won't work with protected batteries. Is that true with yours? If it works, you got some false advertising issue then, so can dispute the product. I would think Amazon and PayPal has some protection against false advertising? I'd pursue it if I were you by first directly asking the vendor.
Also, does it have next mode memory, like 18sixfifty's?
I tried it with protected Panasonic 3400mAh, it works sporadically… but with KK or Sony VT it works wonderful and it has next mode memory
edit : I forgot to charge the batteries before I put them in, now it’s much brighter… between all my multiple LEDs light, this light is definitely the brightest one :bigsmile:
but as for 7000 lumens? I need to bring this to Tom E to check it out as he has a light sphere to test this out
I note that the 15x version on Amazon is a four 18650 or 26650 battery light. Has any one taken a look at it yet? Must be a pretty long light, getting into the six D cell Mag-Lite category.
Well I finally got the batteries in mine (I bought the 12T6 grey one off of Amazon that DayLighter listed) and this thing is SUPER BRIGHT. Insane! The modes suck horribly but not unfixable.
How long does it take your lights to heat up so hot you cant touch it? The very top of the head heats up within about 15 seconds on high and the tube is scalding within about 2 to 3 minutes on high. I’ve never had a 12 emitter light before, and I understand that they are supposed to get hot but dang!
Sounds about as practical as a rubber crutch! Sounds like it needs auto step-down after 60 to 90 seconds and a better UI. I note it is listed as 5 modes. Are the strobe and SOS in the main sequence or hidden in any way and is the medium output level low enough so the light can be used continuously in that mode? Any estimates of Lumens outputs in the three output levels?
Sorry guys for missing the comments on this thread. I usually get a reminder but I must have missed it.
Again what the light has going for it is simply insane output. It is by far the brightest stock light I have ever had and I have had all kinds of multi-emitter lights. I’m sure it’s basically direct drive on high with fairly low resistance from the FET.
The UI is annoying but for me I don’t care all that much. Really this light is for waling out of my back door and blasting the back acre or two with light. I don’t expect to be walking around with a light that hits this kind of lumens although you could. Just walk with it on low and then zap stuff with the high when you want to. Skip past the blinkies and go back to walking with low.
It’s primarily a cheap solution for a mega lumen light. Short of modding the heck out of the other lights I don’t see anything around that comes close in total lumens. Another thing, the IO driver that is for sale on Lightmalls and LckLed stinks. You can get this kind of lumens with it and better modes but it is constantly burning out if you don’t watch it. It bumps down and freezes up etc.
Those are boost drivers, you'd have to rewire the LEDs to use one - and the biggest one ('9x') will only do a max of 30V output, so it would have to be rewired 6S2P.
A direct drive driver like in this light has 3 cells input, and LEDs therefore must be wired with 4 parallel sets of 3 series LEDs each. A zener diode version of the BLF-20DD is what you would want if replacing the driver.
I’ll keep that in mind I have a couple other lights that are this size just sitting around waiting for a new driver. I know I’m not about to buy any more of the IO 9x drivers after the last one I had. I’m sick and tired of them.
I got the SuperNight here, loaner from DayLighter, sooo, had to measure it up. On 3 fresh KP 26650 4000's (yes - protected), I got:
10.3A at the tail, lumens: 7,752 @start, 7,140 @30 secs
The fit is tight with the KP's in there - can't believe it didn't trip the protection circuit.
With 2 SONY 26650's and 1 KK, I measured 13.6A at the tail -- yikes!
I pulled the light apart, and confirmed the LED's are wired in 4 groups of 3, confirming my suspicions of why the driver is so simple. It's a straight DD, just like our BLF DD drivers, just that you need the zener mod to reduce voltage to the MCU. It's a one piece star that is super thin, I mean almost unmeasurably thin - why they would do this, not sure, unless they had an oopsie in measurements, and had to cut vertical space somewhere. Also, think I confirmed there is a dielectric layer - found a solder ball form a center pad and checked for continuity with the star base.
Thanks for the measurements. I’m glad to know I wasn’t wrong in mine. It really is a beast of a light. It tripped the protection on my KK protected batteries. I don’t know how they are wired but I was assuming the same thing.
Oops, updated post above. Looking inside, the pill area is cavernous, but looks difficult, maybe impossibe to get to without cutting her open. I see threads inside, and maybe a press fit joint, but those inner threads are usually glued. The pill top looks awfully thin. Just a shame - I don't an easy solution to some issues, like upgrading to copper stars with the flat back reflector, etc.
Think what you did was the way to go - experiment with emitters (maybe some XM-L2's), upgrade the grease, upgrade wires and springs. The springs look like copper, and pretty soft. In DayLighter's, the springs are crushed somewhat - hope I didn't do that with the protected KP's, but doubt it. He abuses these things from using them (wut? he actually uses his lights? -- Yes!). Too bad couldn't easily do some copper backing for the pill top - that would help get the heat lower to the fins, but sounds like your improved grease did that as well.
Dang, I got some sic lights sitting around me right now - Super Shocker, TR-9T6 doing 5K lumens, J18's doing 5K - 9K, a TM36 (extreme thrower) does 350 kcd stock, slightly modded MM15 5.2K, TN31 modded out to 500 kcd or so... Not counting under 5K or under 400 kcd lights .
Did you file down those blocking LED alignment pieces?
