MTN Electronics: LEDs - Batteries - Lights - Chargers - Hosts - Drivers - Components - 1-Stop-US Source
Richard, is the triple xp-g2 spacer you sell the same one you use in your builds? How solid is it (how much is hollowed out in the center, if any)?
I apologize if this has been brought up before. :slight_smile:
The S3 EDC triple doesn't use this spacer, just the S2 and S6 (normal length) if the customer requests it. On the S3 I fill the pill with solder, sand it flat, then reflow two copper MCPCBs together for the spacer.I can't remember the exact diameter used, but it is machined from solid bar stock and the hole in the middle is enough to fit two 22 AWG silicone wires through but not much more.
Richard, Your new tax system keeps adding tax to my order (I’m not in Washington or Utah).
2 small flat rate boxes with 18650’s inside. Also got a backup proprietary Li-ion for my camera before we go on vacation. So there were 4 Samsung 25R and 8 Panasonic NCR18650B plus the camera battery. Also 3 other packages. A small 14500 sized Maxtoch in SS and an extension for my new TK61, along with some Kester soldering paste.
Why is all this important? 13 Li-ions in my mailbox, raining, and the mailman stuffed so much in there the door would’t close! The packages were wet and crushed and looking like easy pickins to everybody that drove down our road! Crazy mail carrier!
No harm though, so I guess no foul. Those little plastic boxes come in really handy in these situations…
Thanks Richard! :slight_smile:
Clearly you're going to need a bigger mailbox so you can fit more flashlight gear in there in the future. Do I see a mailbox mod thread in the near future?
I got the $40 kit: http://spectralworkbench.org/
and have posted some spectra from various LEDs, e.g. SpectralWorkbench
Back in stock:
  • 18 AWG Premium Silicone Wire
  • 14x6mm Black Silicone Boot
  • 20MM & 42MM AR Lens
  • 20MM Forward Clicky w/ PCB and Spring
  • Cree Multi-Color XM-L
  • XM-L2 3C on 16mm Noctigon
  • XM-L2 4C on 14mm Aluminum
  • XM-L2 U2 1D Bare LED
  • XP-G2 R4 5A2 Bare LED
  • Gold Plated Spring B
  • LC-2C Driver
  • 3XP MCPCB
  • P60 Dropins - OP and SMO Reflectors
New:
  • Cree MT-G2 M0 4000K on 20mm Noctigon
Lower prices:
  • 18 AWG Premium Silicone Wire ($0.20 less)
  • Triple Nichia 219B on Noctigon ($2.00 less)
  • Triple XP-G2 2B and 3C on Noctigon ($2.79 less)
  • XP-G2 R5 3C on 16mm and 20mm Noctigon ($1.50 less)
At the beginning estimation, or at the end when you actually go to check out? For some reason it keeps on trying to add tax at the beginning, but when you get to the bottom of the page (before you actually check out) the tax will be correct.
Also, if I click estimate shipping and tax initially it removes the tax. I'll get it figured out.
Its been doing it both ways. Sometimes it adds tax at he beginning. Another time it didn’t and I went all the way to the end of the checkout process and then it added the tax right before I was about to pay with Paypal.
Clear your browser cache and try again. It should be fixed now, although I've never seen it calculate incorrectly at the end of the line and I've tried dozens of addresses and zip codes.
I cleared the browser cache - still happening. Total should be $86.85
Step 6: Confirm Order
Product Name Model Quantity Price Total
XTAR VP2 Charger - 10440 - 14500 - 16340 - 18350 - 18500 - 18650 - 26650 - LiFePo 4.2V 4.35V
  • Add Car Charger: Yes XTAR-VP2 2 $40.75 $81.50
    Sub-Total: $81.50
    US Envelope Shipping: $5.35
    Total: $86.85
    Sales Tax 6.85%: $5.58
I had no problem with yet another order. :slight_smile:
(Had to test the new system, don’t ya know!)
Good to see those pcb's back in stock.
Just figured it out! My account address didn’t have a Zip Code. Even when entering the zip on checkout screens – the sales tax still appeared. After modifying my account address to include my zip code – the order process didn’t try to charge me tax. Just placed the order with no problems now. -Steve
Ha ha ha. Even though I know some of my lights are 3000+lumens or have a tight beam I’m still going to look into the business end while it’s on full power one way or another. I know it’s dumb in the back of my mind, but I can’t NOT look at it. I have to do it at least once with each light.
Cool, thanks!
Richard,
Could you sell me all the components necessary to build the triple s3?
Time to borrow from the digital cameras, and add “face detection” and “red eye” feature to flashlights?
If the lens is pointed at a human face, give a preliminary couple of low level flickers so the pupils contract before full power ….
Or borrow from the laser labs, and provide a stencil that prints on the forehead in mirror-lettering
CAUTION DO NOT LOOK AT FLASHLIGHT WITH REMAINING EYE
…challenge …accepted.
By the time I put in all of the work reflowing, sanding, drilling, adding chips etc. the labor is already almost done, so in my mind it doesn't make sense to sell it in kit form.
If you want to buy the parts to do it yourself, here's what you need:
  • S3 Host
  • 17mm Driver (your choice)
  • Triple Noctigon LEDs (your choice of tint)
  • Noctigon 3XP Bare MCPCB (to sand mask off and reflow)
  • Carclo 20mm Optic (your choice)
  • Copper Braid
  • Thermal Paste (do not glue MCPCB to pill!)
  • Patience
