BTW, our eyes/pupils work in such a way....that 0.78A and 2A in closer quarters, is actually quite close. I just tried it last night briefly along a dark pathway in my estate....well my wife is afraid of cockroaches. LOL!
The difference on the lux and DMM is there, but in reality 2A shuts down the pupils somewhat. Of course you'd tell a difference if you are using this for throw, btw this light is not for throw and not useful as a dedicated thrower past 100m, well of course it still works and the output is appreciated, but a Fandyfire STL-V6 would blow this out of the water in throw. Correct tools for the correct use. BTW you guys do know the hotspot size matters a lot for lux (throw)? Twice the diameter drops the light intensity, eg your 4000L just became 1000L.
In a nutshell, if you are basing on paper 3A looks very much brighter than say 1.5A be it close up or for throw, then that is going to disappoint. In fact for lux throw figures, you'd need 4X the lux for twice the throw. So yes, say for my WW driven at 3A, it probably still does not reach 2X farther versus a 0.78A drive. :) (remember the 3A is going to put out a lot more heat)
No offence guys, i'd echo Chicago X and Vin's comments at cpfmarketplace. You guys are thinking and comparing too much, just buy it! Just the WW / NW variants PLUS form factor alone is well worth it. By chance the good solid built is a welcomed plus point as well....it won't beat the quality of Shadow TC6 that i received from Ric/CNqualitygoods, but that's yet for another use and appreciation. When you hold this light, this feels like a mini TK70.
You probably would not get more kick if you get the Big Bruiser from Elektrolumens, which costs 250 before shipping and has the same form factor. LOL! :D
In CPF there are guys who get lights due to this and not absolute lumens. But i can understand about getting too hung up with lumens on paper....but like i said in reality, the diff in a big house between 1800 and 2500 lumens is not really appreciable...too close. Now when i fire up my 4000 lumens Ebay "65W", 1800L vs 4000L, now we are talking.
Thanks 2100 for your comments. I understand what you're saying, and I'm sure you're right that I would probably not notice the difference, at least not as much as I'd notice the diff between the tints. What bugs me is that the NW 4-mode is "leaving something on the table". If it were driven at 3 A, I would be satisfied even if the output were the same as the Skyray or TF 3T6. But since it's driven at 2 A, while the 3-mode is driven at 3 A or 4 A, I would feel gypped. :)
Also, one of my minor targets was to be able to beat a Fenix TK45, and a Maelstrom S12. The CW 3-mode definitely does that, but the NW 4-mode probably wouldn't. How can I brag if I can't beat my friend's lights??? :) (and the S12 is quite a bit smaller than this Dry, so even worse!) In fact, whatever light I buy has to clobber my current brightest light, which is around 650 lm, or else I wouldn't bother.
I can't buy a 3-mode Dry because it has no real low mode. I could maybe try a CW 4-mode, but who knows if the CW 4-mode would drive at 3 A or 2 A?
Oh and lastly: "just buy it"... easy for you rich guys to say!
Oh BTW, 2100, if you have a way to communicate directly with Ric, can you ask him why the 4-mode DRY drives at 2 A instead of the 3 A he stated on cpfmarketplace?
Last favour to ask (for now): 2100, if you ever feel like doing beamshots, I'd love to see your two DRYs' beamshots side by side.
TK45 ..... Hey NW already has that 15% disadvantage to begin with. And like i said, for throw, the hotspot size matters way more. TK45 is more throwy, that 10-15% reduction in hotspot size (from Chicago X's pix) is going to require like 40%-60% more lumens to compensate just by "lumens brute strength". As in, 1800 lumens you need to push to 2500-2800L and that is for both lights with CW, and you factor in another 15% disadvantage of NW, sorry it is really too much.
To see which light is brighter via throw on a 200m target by using lumens is a totally losing battle.
Oh yeah, you do have a point. While the 3-mode 4A with the NW is cool, it lacks a real low. But then again at medium, that is going to run for nearly 4hrs. :)
I'll try. Seriously it is really academic on paper. Why does Chicago X's warm white drive at 3A and mine at 2.8A while it is specced at 4A? heh.... I'll just take things as it is.
I'm actually not interested in throw at all. I have a fairly throwy light (5x XRE) already, and find it not as useful as a floody light would be. From the beamshots I've seen, the Skyray and Dry look fairly floody, which is great. What I want is that good flood, but so much of it that it throws fairly well too. I don't need any more than 100 m.
Yep, they are the same hosts. In fact I am using the SR's tailcap on TF body.... nothing in particular....just for convenience because i had it lying around.
I actually want a low mode (not SUPER low, but around 100 lm would be fine) not for the run-time, but because whatever light I get is going to be one of my two EDC lights. I've already used a 300-400 lm light to read a menu in a dark restaurant, and people were annoyed. :) Yes, one of those people was my spouse.
Anyway, i mentioned above for my Xeno E03 WW is 38 lux reflected and 44 lux NW reflected. In fact i must mention that lux meters are calibrated for 2583k, so the advantage already goes to the WW. Cree specs indicates 240lm/200lm so that is 1.2X, 20% diff.
Check out CPF's testing, there is a big enough sample base. The incans are very close, but LEDs are somewhat off most of the time. Most claim to be close to the CIE photopic curve.
Guys like ma_sha1 mentioned that LEDs somewhat lack the yellow component, even compared to say 5000-6000K HIDs. That partially explains why a 125k SR90 can hang around with a nearly 200k HID. I use a compensation factor of about 1.2-1.3 (as you can see from the figures), others may factor in higher values. This is just talking about PBCP. Look at the R, G, B, totally way off.
Else there really is no way of explaining the differences between HID vs LED phenomenon in lux readings.
If they're cal'ed to 2.8kK, then they're not representative of human eyeballs (photopic), by definition.
The definition is the CIE standard observer function: http://en.wikipedia.org/wiki/File:CIE_1931_XYZ_Color_Matching_Functions.svg
Interestingly, if you look at the cree CW output curves, they match this quite well (peaks at 450 and 500-600). IOW they're more efficient because they're designed to be.
I also read the CPF thread briefly. If that table is anywhere near correct, 3kK is definitely not what the meters are cal'ed at. If they were, the ratio of incan vs LED lux as compared to LSI would be way off.
It's also really badly organized. If you wanted some insight into for example the meterman numbers: http://www.candlepowerforums.com/vb/showthread.php?94232-Light-Meter-Benchmark-Testing-%96-CPF-style&p=1324502&viewfull=1#post1324502
But yeah, we're not really exact anyway. For example, we use inverse squared law "from the flashlight" when we don't even have precise isotropic source.
Heh heh....that is right, the Meterman is really all over the place. But basically we can somewhat see a pattern, the incans are less susceptible to fluctuation and the white LEDs may under read quite a bit. Just to accurately calibrate instruments cost more than our usual entire flashlight collection.
That's why just get the $27 DX meter, no matter what it tells you pretty accurately the lux as well as reflected ceiling "lumens" from the different lights you have, just bear in mind to factor in the compensation. If you can, try to move at least 1m away form the sensor, that affects somewhat as well (your body reflecting/blocking the light. But generally at least for my place which has 3 white boundaries, ceiling + 2 walls, it is pretty ok.
Photos have their own issues (even if the channels are not 255 or clipped, the colour depth limitation + LCD limitations and monitor settings affect perception greatly), that is why I am pretty hesitant to provide WW / CW beamshots, eg WW Dry and CW Trustfire 3T6.
But anyway since Petebaby wants one, allow me to provide the ubiquitous SR3800 (it measured 160s vs 130s for the Trustfire) vs the Dry CW, and as you know some just hate WW while i love WW.
That is why I, Chicago X and Vinhnguen54 told petebaby and the others, you have to buy the lights. Only when you get to play with it, touch it, measured with your instruments, you form your own opinions etc. Different strokes for different folks. I know seven_architect has been looking for his light for several months now, before the SR3800 which you and I pushed.
So a new LED emitter might be coming, and then it starts all over again. This happens a lot of times in the photography fraternity. And the questions/cycle get repeated over and over and over again.
The hobby needs to be truly enjoyed. My 2 most powerful units of HID get me easily over 3 million lux (1.73km of throw, @ 1 lux on the target searchlights standard, not that what ANSI/LEMA F1 standard) and nearly 20000 lumens in 6kg package that lights up the cloud bottoms nicely, and just last night i shone the Neutral White driven at 2 amps. And I still go "Wow that is bright and very nice". The SR3800/3T6 just don't cut it for night outdoor real use even for a cement jungle that i am in. Even my wife noticed and commented that the light quality is nice.
