LED swap
4 posts / 0 new
Belenos
Last seen: 11 months 5 days ago
LED swap
Hi!
So i just bought a Ultrafire f13 from gearbest at 9.99 with a coupon.
I was wondering if i should do a led swap (xm-l u2 included) to a xm-l2 u2 or the diference is neglectable.
Thank you!
Flashaholic at work!
unknown00101
Last seen: 2 months 2 days ago
Pics from Match’s emitter test threads.
These are the output numbers you’ll get from the respective emitter on copper or aluminum (stock) stars at certain drive currents.
The final results depend on what your driver is doing, and the type of star/mcpcb you use.
You’re probably looking at 100lm difference if you stick with the aluminum star and don’t mess with the driver, copper wont make much difference in this case. 100lm is cool on paper, but unless you took a picture before and after you wont be thinking “that is noticeably brighter”.
If you switch/tweak the driver (I cant recall what people were getting by tweaking the driver) to lets say 4A, and you have a battery capable of that current then you’re looking at 500/700lm (Alu/Cop) difference. Definitely noticeable and a before and after picture will be amazing. Smile
Keep in mind these are just rough numbers, there are tons of variables involved.
Rufusbduck
Rufusbduck's picture
Unless you are changing to an led on a copper star it seems a bother for very little realized gain.
Scott
ohaya
Last seen: 4 weeks 1 day ago
On the F13, I’d just go with a couple of mods, e.g.:
http://budgetlightforum.com/node/31213?page=3#comment-595484
