The star is custom made by member Dsche. He has a thread about it: https://budgetlightforum.com/t/-/22412
The optic is a Carclo optic, available in many places, bought mine at Conrad.nl
Racer: I have of course looked around for hosts too, there's not many, another host that I l found (and bought) is the Fandyfire P03. I'm on my phone now, I will post some dimensions tonight.
Wow, I was wondering the same thing with those quad MCPCB’s. I was hoping to find a way to get the lens into something smaller in diameter than a Solarforce /P60 format. Needless to say I’ll be following this thread.
I found this I hope it has a momentary switch! Then it could use the STAR firmware with strobe and other niceties. Quad XPG2, FET driver with STAR firmware, 26650 battery. Would make a nice camp light.
That looked so nice, then boom, non anodized tailcap threads.
Comfychair has a post showing how to make an adapter ring to fit smaller optics into bigger heads. It should be doable with a drill press. I have a milling bit in the mail, so I'll be giving that a try soon.
On the UF-T50 & 'PH-08' clones, the bezel thread ID is 26.3mm, bezel front opening is 23mm.
Roche F6 uses a 24mm lens. The bezel opening is small (~20mm) though that can be enlarged. Great quality on those as a host. Not much space in the driver compartment, it would have to use the stock driver or a dedicated redesign of the BLF-20DD.
I’m losing my mind, Wight! Thanks, Comfychair, I am subscribed to that one you posted as well. They say the mind is the second thing to go. Now if I could just remember what was first to go…
That was indeed what I was hinting at :-) . The optic that fits that board is the Ledil Cute optic, which is 35mm diameter. It could be shaved to 32mm of course, but you will loose some beam quality and a bit of output.
