If I want to do this with a zener mod would I replace the diode with the R200 resistor (like normal) and add the zener diode to the now empty C1 pads or does the zener diode have to also have the cap in the factory position?
We haven’t tested it (AFAIK), but the zener mod drivers simply do not have this problem (we assume). Build them as normal but do not bother with a gate resistor (use a jumper instead).
Specifically:
Without the reverse polarity protection diode there is no boost circuit, so the overvoltage condition does not exist
Without the reverse polarity diode in place the decoupling cap (C1) should act to smooth out any spikes generated on B+ by the FET switching.
even with the AOD510 I can get away with building them regular and no gate resistor?
thx
edit Sorry I wasnt asking a repetitive question here about the 510’s working in general, I got that, I have one together now on the bench with a 510- I was asking specifically about zener modded old style 17dd’s with the 510…
YES AOD510 WORKS WITH NO GATE RESISTOR* AFTER MOVING C1 TO B+/GND! All of them work with no gate resistor after moving the cap. Even the 15DD with the IRLM2502 works with no gate resistor after moving C1.
*replaced with a jumper on the versions with gate/pulldown pads, pulldown location left open, of course
Since getting my 858D station yesterday I’ve built 6 17dd’s (5 this new way and one zener modded), 3 of them with the AOD510’s and 2 with the old Vishay’s are working fine however the one with the one FET I have out of an M6 is giving me some issues with the exact same firmware. It’s heving problems when cycling threw the modes, after turbo sometimes it’ll miss moonlight completely and just go back to low (5-mode off-time with no memory and moon defaulted on without the star needing to be soldered), other times it will go to moon but with a bad preflash.
I’m not really complaining, I have exactly one of these FET’s and dont really mind discarding it to the random parts drawer, just reporting my findings.
What's the p/n on the problem FET? Curious to find a datasheet on it and see what it has in the section for gate characteristics. Both the 70N02 & AOD510 have a total gate charge number known to be something the attiny is capable of driving. Above something like Qg=40 they can get troublesome, or at least that's the general number I've heard to stay under.
This is really great stuff you’ve found out CC and precisely the kind of thing that only comes out after new ideas are tried out and someone takes the time to troubleshoot odd behavior. Good job.
So as it turns out the zener modded driver do in fact have the issue, I of course dont have a scope to know if its the very same issue but it was giving me identical behavior where it skipped modes or shut its self down or just overall acted bad when I tried building it with R3 jumpered and C1 populated like normal (with the 10uf cap and the zener diode) and a R200 in place of the protection diode and it did turn on but neither luxdrv fast or phase correct (its known that fet drivers still need luxdrv to run at phase correct PWM) nor my custom weapon mounted UI were usable with it like that. This is in my MT-G2 ZY-T08.
Took it back apart replaced the jumper at R3 with a 130 and populated R4 with a 10k and the light worked perfect with both FW’s!
Brings back the question, can I put the zener diode on the C1 pad with no C1 and put the 10uf cap from batt+ to like with the non-zener ones or does the zener diode REQUIRE the cap to be there?
Most certainly not the case! Only the momentary switch firmwares, that use a different 'sleep' method, require phase correct FW (and that holds true whether it's a FET or 7135s). I built many many lights with FET drivers running luxdrv converted to fast-PWM.
The zener and the cap aren't directly related, they just got piggybacked because they both required connections to the same points. If moving the cap fixes it (which I doubt, since without the normal diode at D1 there is no longer a voltage boosting situation) then that's fine.
Can I send you the exact .c and hex files I have for luxdrv? When I try changing it to fast and putting it on any of the FET drivers it doesn’t run, or can you send me your file so I can try it?
Fast or slow will work on my 105c (and other 7135 drivers) but this version luxdrv fastPWM doesn’t work on my FET drivers.
Currently the light is running with all resistor pads populated and slowPWM and it didn’t run with R3 jumpered. Ignoring for a second the FW issue fast vs. slow, what should I do with it, leave it as-is or move the cap down to where I am using for 3v ones (your v2 pic) and re-jumper R3?
@ CC: Your are my hero. And every other modder wanting to be mean to led lights. I never would have thought about getting this heavy into the electronic part of the hobby if it was not for you. TY :-)
does anybody happen to have screen shots or images that were posted by comfychair? trying to learn more about the whole C1 cap placement decision on the current iterations of the BLF 17DD.
