Iām losing my mind, Wight! Thanks, Comfychair, I am subscribed to that one you posted as well. They say the mind is the second thing to go. Now if I could just remember what was first to goā¦
That was indeed what I was hinting at :-) . The optic that fits that board is the Ledil Cute optic, which is 35mm diameter. It could be shaved to 32mm of course, but you will loose some beam quality and a bit of output.
sinner has a thread about a new host that heās making and might offer, and Iāve posted over there about possibility of using his host with the quad setup:
Anything with an attiny13 MCU can be flashed with momentary firmware. The BLF-17/20/22s will do 8.5-9A from a single 20R/25R/VTC5 into 3 parallel XPG2s, with 4 LEDs I'd guess that would go up to 10-11A.
By now many of you have probably seen my quad RGBW A6ās
Notice all the extra wiring? Think wiring one of these for series is a lot? Try wiring them individually addressable.
Has anyone found any other suitable clicky switch hosts for these? What I donāt want is empty space around the optic.
Also Iām using a 35mm cute in both my new EA41 builds (one the production version of pukelight, the other a white only (using a boosted factory driver) triple Iāll be calling the EA41_ck.
Note all of these lights (plus the quad SC02_MELDās Iām doing) all require custom spacers, the optics are shorter (some by quite a bit) than the factory reflectors*
*i was able to shorten the A6ās instead of building a spacer/new pill.
