I'd be interested in one. RaceR86's suggestion sounds very good to me.
EDIT: _the_'s TheStar FW sounds interesting too. I plan on doing a mini review of it tonight.
Sounds good to me! I’d likely be in for one, depending on price.
+1 for wider mode spacing
I’m in for one CW!
+1.
3 or 4 modes, NO STROBE OR SOS.
I wouldnt mind having a 50% mode
Put me down for 1 for sure. Maybe 2…. if the price is right
I would say 4 modes..!
Why don't you try to get the BLF group buy driver that THE is working on?
Just connect the star by yourself to get the set of modes you like the best.
I’m interested in 1 or maybe 2 in NW. Not sure yet. 4 modes with moonlight or 3 modes. Just follow the majority here.
I am more of a 4 mode guy and I like a mid mode with50% so that if a light is modded to 5A the mid is 2.5A which is almost a normal guy high…but if the price gets low enough I will order one anyway…like always.
A current boost makes only sense with a decent(copper)star and if I replace the star I can resistormod it also….
+1
I am in for at least 2 if these are achieved.
I’d be interested if 4 (incl moonlight) modes.
In the OP, you said they’d agreed to “up the power”, but to what?
Also, is the lens AR?
Thanks,
Jim
2mm thick piece of glass, no AR.
If I were to perfect on the modes (in my suggestion) id probably want medium to be more like 17-20%, but I understand that some might want it higher.
I consider default Qlite to be pretty much the benchmark. Many seem to like that.
100%
20%
2%
I would not mind if low were a bit lower like in my example. As long as the mode spacing is somewhat decent im happy.
I’m in for 2, with the driver as RaceR86 suggested.
I agree this is best mode choice.
Thanks RaceR86!
H 3A (100%)
M 0,75A (25%)
L 0,035A (1,2%)
Quick off time mode memory
Low voltage warning from 2,7-3V (A double blink every 60sec or something like that)
Cut off below 2,7V”
Could they make it tail stand from the factory with out raising the price?
I’ll buy them either way.
The glass is good the way it is, as long as we can get that head apart to clean it if necessary.
I’m in for 1 at least, NW if possible. I agree with RaceR86’s mode choice.
I'm good for qty 2 for sure, maybe more. I'm good with the 3 mode ballpark figures RaceR86 proposed. A 4th mode at 50% is fine also, but again, just knowing from other guys and feedback I get about keeping the modes simple, mode count low preferred. Even for myself, I like 4 modes typically, or even 5, but it does get difficult to keep track, so I find myself cycling thru them all to be sure I'm on the one I want.
Ooops - forgot this: Must have assurance no threads are glued (thanx troisanh!)
in for one in CW NOT glued.
Forgot to add. Count me in for 1 light. Maybe two depending on price and how it turns out.
I would also like to see no glue, ability to tailstand and nice even anodizing (same color) on all parts if possible.
+1
neutral white if possible too
in for 1 light
I’d like to see a 50% mode, and hidden strobe. Other modes as RaceR86 suggested. Tailstand would be great. I don’t care about AR lenses or perfect anodizing, certainly not at this price range. Also would like to know how much they are going to increase the driver current. Is that up for discussion, or do they have that number?
Edit: For a good price, if we get at least a few of these mods, I’ll be in for one. For a better price, I’d get at least two.
I’d be in for one with the modes suggested by the OP, so long as it either has mode memory or starts on high.
Would prefer NW, but would accept CW.
One thing - tail standing. The review says it doesn’t tail stand due to the switch boot. Would it be possible to rectify this?
