Got one yesterday. As expected, the housing feels really cheap, like it would with any low end fluorescent housing. That's probably exactly what it is.
From about 5 feet away it has at least 200 lux out to about 45° out. That's enough to work in, but I want a very brightly lit workspace, so I'll get one or two more to put directly over my main work table.
This is a bit of an odd case, but does anyone know if these suffer with voltage drop like fluorescent units do? (Last weekend, I was out in the middle of nowhere with long extension cords connected to a noisy generator, and the fluorescent units were a bit flaky… I’m not positive it was voltage drop that made them flaky, especially since the first 100’ of about 150’ was 12AWG but I have suspicions.)
I'll let you know tomorrow, but I might only have 100 feet of cord to experiment with unless I kick the spiders out of their extension cord home in the garage.
I'm very much liking this light. I keep forgetting to turn it off because it seems like it's just a bunch of natural light filtering into the room. If there's PWM, it wasn't a problem with the 70 pictures I took under it today. Normally pwm will result in a few underexposed pictures. One odd thing is that it takes a moment to turn on, much like a fluorescent light. So LED shop light strobe rave parties aren't going to happen.
How about opening it up and telling us what the guts are? If it’s a fluorescent ballast inside, that would be hilarious! But, it might explain the slow startup. Could be someone got the (not so) bright idea to just package the fluorescent fixture with LED replacement bulbs for a convenience sale. In fact, I suspect that would be the only way this light could exist. If you think about it, LED tubes are made to replace fluorescent tubes, which take a high voltage. If there was an LED driver in that fixture, the tubes would have to be made differently, thus making them proprietary and incompatible with all the LED tubes that are already on the market. I bet you could put a T8 tube in those sockets!
Yes, I would like to know also. I’m guessing that there will be a constant current driver in there and that it will look similar to the solid state ballasts used in most of the new, cheaper florescent fixtures. I have found that those new SS ballasts are the weakest link in the cheap 4’ florescent shop lights. Hence my interest in this LED
2 weeks ago I was able to go back to the Costco store in Waterbury, 40 miles away, where I snapped the pics in the OP. They were completely out. I asked customer service about them and they told me they were a 1 time thing, they were not going to restock. I asked them why, was there a problem with them, were they pulled from the shelves? They looked it up and said “they sold through”. I asked them to check the other Connecticut store in Enfield, 35 miles from out house in the opposite direction, and they had 27 still in stock. By the time I was able to get there a week later, they too were out of stock. I was able to see the display model, still hanging and still shinning brightly. Grrrrrrrrrrrr.
Anyway as a consolation I will put up this as an imitation shoplight. Is 3 feet long and with 6 LED screw in bulbs it will have 4800 Lumen, about the same as the LED shoplight. The light will be spread out along the length of the fixture to reduce shadowing. It will do until I get another chance at that Costco light. The 6 screw in LED’s came from Costco and they were 3 for $10. Not the best bulb, a little cool and the light is not quite omnidirectional. But for this usuage both of those “flaws” are actually good features because for a work light I prefer a cooler light and also because the bulb will be upside down, all the light will be directed downwards were it is needed. I have used this kind of fixture before in work areas mounted to the ceiling with CFL’s and they work quite well. They look funny installed but they get the job done. Besides, when a bulb glows, it is easy and cheap to replace. I got the fixture free.
They’re back, I shot these pics the other day as I did a quick walk through my nearest Costco. When I am out that way I always do that as it isn’t often that I get a chance to visit there.
Last time they had these I passed on them and when they ran out regretted that I didn’t get one. Funny thing is, now that they are back, I passed on them again! I now regret that too, I need to replace the innards of a 4’ florescent kitchen ceiling fixture. The tenant is complaining that it “hums”
Sorry about the last pic, I used the “pano” function on my new iPhone and I didn’t pan smoothly enough for the phone to stitch the picture correctly. LASTS 45 YEARS!
ROFLOL!
45 years?
it is possible but highly improbable .
some of mine are older than that.one in my bedroom is from 1946!and i trust its safety over that cheap led thing anyday.
I bought some of those 60 watt LED bulbs from Lowes for $6.97 a while back…they too have a slight delay when you flick the switch on, maybe a few tenths of a second…but definitely a slight delay (but no flickering)
We bought 50+ of these “LED Shop Lights” and replaced all of the fluorescent tubes in the office with the hopes that they will last longer without needing bulbs or ballasts to be replaced.
I strongly suspect that there will still be a ballast to eventually change out, if you got this same kind, since it appears to just be using off-the-shelf LED replacement tubes, which were made to directly replace fluorescent tubes in a working fixture.
my guess is its a cheap capacitive ballast driving a full wave bridge with a cap to knock the ripple and thus the flicker down.
most gensets will run it ok but squarewave inverters might damage it.
its going to be a very cheap n nasty thing.i saw one at the flea market a few weeks back and its color rendering was poor.
definatly optimised to look bright with that big green spike in the spectrum.
i will pass……
I had to create an account. Bought 4 of these yesterday. The first thing I did was take one apart. They’re basically a led light strip in each acrylic tube with the electronics for each at the beginning and end. So you can separate them if you want. Forget “tubes” and “ballast”, the tube is only there to diffuse the light, it’s plastic, and when you unclip the electronics the led strip slides right out. They’re on sale for $32 right now. Seemed a good price for what you get. Thinking about making valance style lighting in the kitchen with a few, using an old vacuum cleaner cord instead of the 6’ one supplied.
