I'd be in. Watching...
If possible could the tail cap thread be 7/8-20 or just left at .875” I could thread it myself. As a personal option? Oh by the way the Cypress Cu is just amazing!!! Thanks!!
I'm in for one. Sounds great based on your other work. ;)
I cant thank you guys enough, I appreciate the support and patience I really do. I better stop being lazy and do it asap. This past month have been a very busy at work but I’m catching up on everything so far.
Following design upgrades are in process, I will reveal the final product very soon.
Upgraded switches to Judco 10A for every host (Pre-Installed)
Brass battery contacts (Zero resistance)
Screw-In Driver Pill
In for 1 if still available. Thanks
Excited!! Thanks for the update.
Personally, I appreciate that you're taking the time to do it right, rather than rushing it for the sake of doing something quickly. I can't speak for everyone, but I'm in no rush and would prefer quality (within reason, given the proposed price range) over having something asap. Looking forward to seeing what it looks like!
Great news, thanks for the updates.
Among the many eagerly anticipating, munching popcorn and sipping suds awaiting pics…
Hi,
Anyone (sinner?) know if what sinner is making would work with one of the Carclo quad optics:
and a new quad star like the one IS has started selling? I have the optics now, and some of the boards coming in, but haven’t selected/found a host yet (yes, I’m aware of the other thread).
EDIT: I think that the diameter of the optics is 24mm.
EDIT 2: And, the diameter of the star ([Feeler Thread] Copper direct-connected 20mm triples and quad universal MCPCB boards) is 20mm.
The 24mm carclo lens will not work right away but a few custom modifications will be required obviously a spacer to account for the reduced length of the mount, and a custom head with 23mm or 22mm aperture so the optics dont fall off. Currently the bezel/head cap is 32mm OD 24mm ID. Hope this helps.
I was imagining that the quad optics would just rest against the lens and a spacer to take up the slack space left over.
Most likely, that would definitely work.
Another (add’l) possibility maybe is some kind of washer (black) that would sit against the lens and have an inner diameter slightly smaller than the OD of the Carclo? It’s a bit of a hack, but it looks ok if the washer is nice.
Washers and spacers can be sold as add-on’s , just need dimensions but only once everything else is sorted out.
I think best would be a heatsink made for it that is thicker to get the star and optics to the front of the lens instead of having them sit back with a spacer stealing lumens
I remember this guy that disappeared had a quad drop in that well, dropped into p-60’s.
So they should fit. Also in the realm of gaskets, there is a guy that used to sell custom GITD gaskets. I dropped him a PM to see if he is still in play. I’ll check to see if anyone else still makes them in blue. Green is so pedestrian.
Assuming that that’d be the case, i.e., that you’d be willing to potentially offer washers and spacers for a quad setup “after-market” :), put me down for 2, pending what the shipping costs to U.S. would be!
Hi,
I agree that that’d be optimal :)!
They will ship from US so the standard first class $3.50 (or $5.15 in case of multiple hosts and priority shipping)
