ImA4Wheelr
(ImA4Wheelr)
July 17, 2014, 4:10pm
1127
I thought I read that the OP has been updated for the latest DD versions. I get 404 errors when I try to use the links. Can someone link me to them or to the account holder's share page that is sharing them?
EDIT: Ok, I misread. The OP has not been updated. So these are the latest and greatest right now . Right?
Who is going to be the guinea pig tester for this? Sounds all good… I’m using a BLF15DD now, and planning on more in those cheap little AA zoomies and it works well, not crazy amps because I don’t want crazy amps in that little thing… I’m using a Sanyo 840 and get decent amps but still in the 2.n range. Just ordered the Efest IMR 700’s from RMM, so expecting to get more amps. The 15 mm boards are great for little lights, but 5-7 amps is a little insane .
I wouldn’t mind trying it I suppose. I can add qty 2 to the next DigiKey order at work here, hhmmm……
Oh oh [raises hand], I volunteer! Just placed a digikey order sunday so I’ll get some on my next order!
Rufusbduck
(Rufusbduck)
July 17, 2014, 4:07pm
1129
Sorry guys, I haven’t kept up with all the latest revisions. I’ll be updating the op this evening.
wight
(wight)
July 17, 2014, 4:11pm
1130
ImA4Wheelr
(ImA4Wheelr)
July 17, 2014, 4:14pm
1131
No prob. I just edited my post as I misread a post above. I haven't been keeping up and now I'm a bet overwhelmed.
So these are the latest and greatest right now . Right? Just making sure because the say version 1. The post I read sounds like the version numbering may have started over?
EDIT: Cross posted with wight. Ok, so they are the latest. Thanks guys.
Yes the decision was made to use a standard numbering system from now on, no more rev vs. version vs. whatever else.
Makes me want to buy an SRK.
Mattaus
(Mattaus)
July 17, 2014, 9:20pm
1134
I've removed the Medusa PCB for the time being. There is a repairable error in the ground plain. It can be fixed but I'll correct it properly this weekend and upload a fixed version later on.
Rufusbduck
(Rufusbduck)
July 18, 2014, 3:03am
1135
The Tiny10DD and Tiny12DD links are down. Are there revisions to replace them?
Mattaus
(Mattaus)
July 18, 2014, 3:28am
1136
Rufusbduck
(Rufusbduck)
July 18, 2014, 3:33am
1137
Not the linear boards but the DD versions are down.
Mattaus
(Mattaus)
July 18, 2014, 3:47am
1138
Oh...they're not mine so I can't help sorry. I think they were WarHawk's?
Rufusbduck
(Rufusbduck)
July 18, 2014, 3:53am
1139
He’s sent me the links. I’ll update the op ASAP.
sorry…they are under my profile…Rufus is going to fix the links…I did a revision tweak like on the BLF17/20/22 and moved the C1 capacitor (for the mode change stability) and removed the load resistor
Sorry about that…
wight
(wight)
July 18, 2014, 5:15am
1141
RBD - I have released my 22mm 16*7135 driver for F13 flashlights.
[image] [image]
This driver is 22mm in diameter. It is sized specifically for the new monolithic-head (no-pill) F13 flashlights such as the Ultrafire F13. The retaining ring threads on top of the 7135 cases. The 7135’s on top of the board have a setback such that the cases should clear the ledge inside the head, although the tabs may not. This should ensure good ground contact. I used ~20.5mm for the ledge.
On top of the board is space for the MCU, an SOD-123 package Zener diode, and a 0805 pa…
https://oshpark.com/shared_projects/SMkMEXha
Can anyone give me the voltage divider resistor’s the CAP and diode values for the MELV2? I’m building my next board now based of everett’s PIC MCU but dont know what the values need to be.
Rufusbduck
(Rufusbduck)
July 18, 2014, 7:58pm
1143
Have you checked his discussion thread? If it’s not there, you’ll have to pm him as it’s not a nanjg component set. You’ll find his email there too.
I havent checked but I email the crap outta him (I’ve already sent him 3 emails today lol) so I was hoping someone here would know so I dont have to bother him, he’s already working on a few projects of mine as is.
I can start designing now using 0603 pads, I just need to know before ordering parts.
Rufusbduck
(Rufusbduck)
July 18, 2014, 8:18pm
1145
You might need to send out an APB on the general forum then to find someone who’s assembled one. Good Hunting.
Mattaus
(Mattaus)
July 18, 2014, 11:08pm
1146
Hold up I'll tell you.
EDIT: Wait - you mean the component sizes or the actual resistance, capacitance etc?
