In the meantime: OSH Park ~ Shared Projects by Mattaus
No prob. I just edited my post as I misread a post above. I haven't been keeping up and now I'm a bet overwhelmed.
So these are the latest and greatest right now. Right? Just making sure because the say version 1. The post I read sounds like the version numbering may have started over?
EDIT: Cross posted with wight. Ok, so they are the latest. Thanks guys.
Yes the decision was made to use a standard numbering system from now on, no more rev vs. version vs. whatever else.
Makes me want to buy an SRK.
I've removed the Medusa PCB for the time being. There is a repairable error in the ground plain. It can be fixed but I'll correct it properly this weekend and upload a fixed version later on.
The Tiny10DD and Tiny12DD links are down. Are there revisions to replace them?
Not the linear boards but the DD versions are down.
Oh...they're not mine so I can't help sorry. I think they were WarHawk's?
He’s sent me the links. I’ll update the op ASAP.
sorry…they are under my profile…Rufus is going to fix the links…I did a revision tweak like on the BLF17/20/22 and moved the C1 capacitor (for the mode change stability) and removed the load resistor
Sorry about that…
RBD - I have released my 22mm 16*7135 driver for F13 flashlights.
[image] [image] This driver is 22mm in diameter. It is sized specifically for the new monolithic-head (no-pill) F13 flashlights such as the Ultrafire F13. The retaining ring threads on top of the 7135 cases. The 7135’s on top of the board have a setback such that the cases should clear the ledge inside the head, although the tabs may not. This should ensure good ground contact. I used ~20.5mm for the ledge. On top of the board is space for the MCU, an SOD-123 package Zener diode, and a 0805 pa…
Can anyone give me the voltage divider resistor’s the CAP and diode values for the MELV2? I’m building my next board now based of everett’s PIC MCU but dont know what the values need to be.
Have you checked his discussion thread? If it’s not there, you’ll have to pm him as it’s not a nanjg component set. You’ll find his email there too.
I havent checked but I email the crap outta him (I’ve already sent him 3 emails today lol) so I was hoping someone here would know so I dont have to bother him, he’s already working on a few projects of mine as is.
I can start designing now using 0603 pads, I just need to know before ordering parts.
You might need to send out an APB on the general forum then to find someone who’s assembled one. Good Hunting.
Hold up I'll tell you.
EDIT: Wait - you mean the component sizes or the actual resistance, capacitance etc?
I think he wants the actual R values and Cap values.
Does this help: https://www.dropbox.com/s/p95zp9rls8i7o1f/MELD%20v2.pdf
I can't actually see a voltage divider on that circuit...
That may be, that would mean the MCU could monitor the voltage all by its self then? Since his UI offers voltage readout by flashing one of the channels how else could it do that?
Before I started eagle he built me a single li-ion, 3ch driver using 7135’s, the ONLY components are the MCU, the 7135’s and one single cap so I guess it can do it internally.
