Makes me want to buy an SRK.
I've removed the Medusa PCB for the time being. There is a repairable error in the ground plain. It can be fixed but I'll correct it properly this weekend and upload a fixed version later on.
The Tiny10DD and Tiny12DD links are down. Are there revisions to replace them?
Not the linear boards but the DD versions are down.
Oh...they're not mine so I can't help sorry. I think they were WarHawk's?
He’s sent me the links. I’ll update the op ASAP.
sorry…they are under my profile…Rufus is going to fix the links…I did a revision tweak like on the BLF17/20/22 and moved the C1 capacitor (for the mode change stability) and removed the load resistor
Sorry about that…
RBD - I have released my 22mm 16*7135 driver for F13 flashlights.
Can anyone give me the voltage divider resistor’s the CAP and diode values for the MELV2? I’m building my next board now based of everett’s PIC MCU but dont know what the values need to be.
Have you checked his discussion thread? If it’s not there, you’ll have to pm him as it’s not a nanjg component set. You’ll find his email there too.
I havent checked but I email the crap outta him (I’ve already sent him 3 emails today lol) so I was hoping someone here would know so I dont have to bother him, he’s already working on a few projects of mine as is.
I can start designing now using 0603 pads, I just need to know before ordering parts.
You might need to send out an APB on the general forum then to find someone who’s assembled one. Good Hunting.
Hold up I'll tell you.
EDIT: Wait - you mean the component sizes or the actual resistance, capacitance etc?
I think he wants the actual R values and Cap values.
Does this help: https://www.dropbox.com/s/p95zp9rls8i7o1f/MELD%20v2.pdf
I can't actually see a voltage divider on that circuit...
That may be, that would mean the MCU could monitor the voltage all by its self then? Since his UI offers voltage readout by flashing one of the channels how else could it do that?
Before I started eagle he built me a single li-ion, 3ch driver using 7135’s, the ONLY components are the MCU, the 7135’s and one single cap so I guess it can do it internally.
Yup its done internally on the PICs. Can be done on AVR chips but normally the higher end ones.
Guys I just want to say a huge thank you to Mattus, WarHawk, ComfyChair, RMM and RBD for all the work they do, everyone please take a moment to check out my 1k post /1 year GAW thread and help nominate the last 2 winners and check out the custom engraved lights they’ll received.
Special thanks to Calvin at Illumn, Ric at CNQG and Richard at MtnElectronics for helping make the prizes what they are, couldn’t have done it without any of them!
The Medusa PCB works (albeit the version I'm testing required a physical modification that will corrected in the next revision). I'm not sure if people are interested but I'll upload the revised PCB to OSHPark later tonight.
For what it's worth I have not used a 70N02 FET. I have used a IRLR8721PBF. Seems to work fine - has no problems performing the diming or strobe functions of tterev3's firmware.
- Matt
