ThruNite T10 is a nice light but the silver cap just puts me off, the lack of knurling to aid in turning one handed is another negative for me. I did see in another thread someone attached a Fenix E12 head to the T10 body that looked good.
I still have a stack of Fenix E11’s that i still use 4 x MKI and 5 x MKII, i use to give the E11 and a eneloop 4 pack and a charger as a gift alot. Bought 1 x E12 tried it disliked it gave it to my boss, who i also dislike.
When i heard the L10 was to have a clicky i thought great, but my hopes where crushed. The search goes on.
It’s hard to find the perfect EDC, especially since everyone has a different idea what that means. I hope you find it!
I don’t really care for the aluminum T10 either, but the T10S and T10T are nice. I don’t find that the lack of knurling is an issue for twisty operation; the grooves on the head are plenty grippy.
As for gift lights, I try to get a variety so I can sort of tailor each one to the person receiving it. I haven’t chosen anyone for my extra L10s yet, but they’ll be for relatively special gifts since they’re one of my favorites.
If you want a combination twisty+clicky in one light, you might be searching a long time… they’re rare. The original L10 is a great twisty though, if twisty-only is okay. And the L10C is a good clicky too, if clicky-only is okay.
Is the L10C a good light to gift to non-flashaholics, who won’t be using rechargeables?….How does the output with an AA compare to that with an Eneloop? (Apologies, if I missed a comparison on an earlier post…….)
I would say it is. It has regulated output at all levels even with an alkaline. I would suggest getting the 3 mode for a non-flashaholic though since they likely won’t make use of the moonlight mode. Refer to selfbuilt’s review of the L10 for runtime charts with alkalines (they are the same as the L10c).
Wow, that’s big. I have 1x18650 lights smaller than the P1A.
Looks like it uses a forward clicky for activation and a head twist to toggle between high and low. Can’t turn it on using just the head though. If that’s a design you like, you might want to consider an EagleTac D25A. It’s quite a bit smaller, has both higher and lower modes, and has several emitter choices. The UI is very similar (tighten head for highest mode), except it uses a reverse clicky instead of forward clicky.
Wow, I’ve never seen a D25A for that much. My titanium one was about $64 IIRC, and my aluminum XM-L2 one was $36. Both were the clicky model though (which usually costs more than the mini), since the twisty model doesn’t have a moon mode.
Yeah, I’m familiar with the Saber. I don’t really like it. The T10S / T10T is the only Thrunite EDC-sized model I’ve ever liked. Just a matter of personal taste though, and I still have complaints about the T10S / T10T.
Thanks for adding your thoughts. It’s really unfortunate that you got one with a flaky switch. Are you going to try to get a replacement?
I agree the clip feels a bit weak, definitely near the weak end of the spectrum as far as clips go. It should work fine for some things, but it’d need to be stronger for a really secure grip.
It’s good to know the Xeno is brighter, and activates in a non-low mode. Those are both things I wouldn’t like, along with its larger size (I have a 1x18650 light the same size as the Xeno E03). According to selfbuilt, its modes are 5.4 / 44 / 130 lm, compared to the L10’s 0.1 / 4 / 30 / 120 lm. Personally, I prefer the lower output… though I’d still like to make “medium” a bit lower (20 lm instead of 30). But I might be atypical since I’m photosensitive. Everything looks brighter to me.
Thanks. But I bought it to gift. I would be reluctant to give something when I don’t trust the clip or the clickie, which presumably they checked before sending this one. Plus, I wish it were brighter and turned on at high.
I can’t tell if the Xeno E03 with 219A is brighter than the L10 219A. The beam profile is quite different on the two, the E03 having a tighter hotspot and it seems brighter. Would be nice if the E03 had better modes on a 14400. High and medium (low they call it) run at 1.5A and 1A so visually, you can’t really tell the difference. Very low is about as bright as high on a NiMH. The L10’s got the spacing right.
Just going to add this… L10C and L10 with their Maratac peers and my most compact 18650 lights (Zebra H60w and H600w MkII) for comparison. All pocketable in my book.
I like the L10C, but I also like running 14500s, so it will probably get a lithium cell and live in my backpack or center console.
Thanks for the great review. Can you tell me was the original L10 4000K, and L10C is 4500K? how accurate are the tints measurements of manufacturers? i really want real 4500K, not 5000K…
