BLF17DD Info Thread - Reference
Please post pictures when you get back to it. At one time, there were so many different versions and revisions with no coherent naming scheme that it's possible the person who placed the Oshpark order is the only one who knows which one it is.
Make sure the capacitor is properly soldered. I had one that constantly gave the low voltage warning blinks & step-down no matter what, everything looked perfect, but after re-soldering the R1/R2 resistors it was cured.
Comfychair was just cross posting the info in that thread. This is the main thread for that testing project: FETs and gate resistors - scope images. [Post #1045 ~= Post #55 there]
Just to be clear, the post you referred to contains two configurations (marked V1 and V2 in red text in the upper right corner). Which one you are you using?
Regardless of what you have now I’d try the other config! V1~~V2 or V2~~>V1. They aren’t really versions, just different configurations.
I assume that you are using 1s, not 2s or more (zener setup). If you are using >1 battery in series you should let us know. What current level are you achieving on your highest level? Higher currents should create a larger field resulting in a larger spike as the FET turns off. This may require more capacitance between B+ and GND.
Wight, I’m using the v2 config., single cell. I know it’s all still work in progress…that ‘v2’ config seemed to be the latest solution from what I read.
That’s right. Depending on your drive current you may need to increase the capacitance, but that’s really just speculation.
If you don’t know your drive current you could just post what LED you are driving off of what cell.
Nice effort FmC. Good luck with the fix.
The board I have is identical to the one in the first two pictures in the OP of this thread. For testing, I'm using an XML, powered by a single Samsung ICR18650-28A laptop pull. It was at 4.2v at the start of testing. Using fairly thin long jumper cables, going through an Omten clicky. I was initially using short 22awg, but changing to the jumper cables/switch made no difference either way to the problem.
This morning, I re-soldered each component on the back of the board (CAP, Diode, & the two resistors), one at a time, & tested each time, with the problem persisting. I also tried the tweezers bridging over the diode.
I previously mentioned that mode memory didn't appear to work - to clarify that, it had 'next mode' memory.
I bridged star 4 to ground, then it would only operate in medium mode - nothing else, no pulses, flashes, or mode changes.
Not really getting anywhere, I decided to move the CAP back to C1, & replace the bridge on R3 with the 100 ohm resistor, exactly like in the first two pictures in the OP of this thread.
Problem is now gone...
I would have liked to get a more definitive result using the 'v2' cap arrangement, but this driver is going into a light for a workmate, & right now it's working, allbeit with the spikes that only me & you know about....
I'll put together another board, using the same layout I had the problems with, just to see if the same thing happens.
Does anyone know of an equivalent to http://www.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=155125628&uq=635430913889454363 (AOD510 MOSFET) on mouser.com? Their prices are a bit better for the rest of the components for this build and I only want to pay shipping once.
Nevermind. Ordered from Digikey.
Forgive me if I missed it while reading the thread, but the boards that I bought from OSHPARK have 5 resistor placements.
What resistors go where? The Digikey cart that I ordered from has:
Atiny, Schotty Diode, Cap, 19.1 Ohm, 4.7 Ohm and 130 Ohm components.
Hhmm - I know the OSHPark thread points to this discussion thread for the Zener version but I have no experience with them, none on order either. "-Z" I'm guessing means Zener mod? No idea what version you got there - is the current one, Rev 2? There's a ton of resistors on that board you got there. It looks like an older design though - the R4 and R5 should not be there anymore, and the cap should be between Batt + and ground now - that board has the cap in the old position.
If I had this board, I'd trace all components to see how it's wired, and then the resistors will make sense -- I think??
Sorry - hope someone else can chime in. Probably buried somewhere in the big OSHPark thread, but would take me hours to find something - wish there was a search capability in a thread...
Yes, Zener Mod Rev 2. Looks like I have some research to do. Maybe I would just be better off buying the right boards...
Thanks for the quick reply.
In the middle of piggy backing this board to the eswitch on the Y3. I don’t know exactly where to put the eswitch on the blf17dd though.
I noticed cerial had it on tiny13a here in this thread?
Also I’m not up on setting the modes using the connects on the bottom. If there’s a thread for that appreciate it! :slight_smile:
The 'stars' are on the topside, you connect the MCU pin to the little adjacent solder pad.
Switch goes to MCU pin 2.
edit: I don't think there are any options to set with the momentary version?
E-switch goes to MCU pin 3, directly to the pin not to the pad. Just like in CK’s pic you linked.
And yes, you have to use the “stars” on the MCU side. Which means you have to pull the driver if you want to change something. 4 is for High to Low mode order. 2 is to pin 5 for moon mode. 3 is for the e-switch, which of course must be on the pin itself. Not sure what the pad for star 3 is supposed to be for.
Switch goes to MCU pin 2 unless it's been changed in the firmware. Momentary version of STAR has no options to set via grounding pins & doesn't use the off-time capacitor so that's irrelevant. Only the clicky versions ground the pins to set options*.
* ToyKeeper's SRK version uses pin 3 to reverse the mode order, I don't recall seeing any other momentary versions that use them to set options.
And every e-switch light I’ve put a BLF17DD in works with it on pin 3. My TK-61 has both e-switches hooked to pin 3 with the BLF board master to an HX1175b1. My Couri’s, both of em, pin 3. My little magnetic base light, pin 3 as well as it’s 3 siblings. And every other light I have with e-switches. Was frustrating figuring that out, when the C file showed what you posted above.
If it works on pin 3, someone has changed it. All mine that are flashed with code as shown above work only with the switch on pin 2.
The Roche F6DD driver uses the same pin for the switch and works with the same firmware builds. That one has indicator LEDs attached to pins 3 & 5. Switch goes to pin 2 unless someone has deliberately changed it in the firmware.
Works like that with the original untouched 'SRK_no_ramp_1.0.c'
If it has the switch pin defined as PB3, the switch goes to pin 2. It's not possible for it to work attached to pin 3 unless that line has been changed to read PB4.
2 or 3… guess if it works on 3. I’ll do it in the morning to make sure.
Interesting on the stars too DBC… Thanks guys
I think maybe you're mixing two things here. If you're using the momentary switch firmware, the 'stars' are not used, there are no options for them to change (they are defined, but nothing is assigned to them). Only the clicky firmware in a light with a clicky switch has anything assigned for the pins to do. The momentary firmware won't work in a clicky light and the clicky firmware won't work in a momentary light. Forget about stars/grounding pins since you've got the momentary version there.
Ah- well wired up the eswitch to pin 3 and nothing changed with the modes on click. It works with the tail switch using on/off though. I was going to try pin 2 but thought check back here. I’ll mess with it some more. So you guys probably flash in your own firmware I take it for the eswitch to work or it should work with pin 2? I’ll give it a shot or maybe I’ll get some sleep.
