I think that we may be working at different purposes, or maybe more accurately, for the same purposes but doing different things towards that.
What I’m (still) hoping is to get this driver pushing 3 amps to the emitter, if it can do that. I suspect you (all) might also want that.
I’m assuming that the driver should be able to do that (yes, I know what A-S-S-U-M-E stands for), so I keep thinking that I must have something “incorrect”, i.e., maybe a wrong emitter with a wrong Vf, or whatever, so I’ve been doing a lot of switching things around here, using different emitters and number of emitters, different wires, etc.
At the same time, I don’t have (easy) access to what I’d need to pull the coil off the drive… or more precisely, I’m not very good with solder wick or with the solder suckers, so I’ve been putting off doing something that would potententially destroy the driver.
I think I understand the more methodical approach that you and Werner are taking, though, so I’ll give that a try at this point, since I have some time with what’s left of this weekend. I’m actually thinking of just cutting that sucker off of the board, because that’d definitely be the fastest way to get it off. I’ll post back if I can get some pics of the bare toroid-less board.
No - Wait - Stop - Don’t Cut. …just melt the solder at the joint and pull it loose from the board with needle nose. (just lurking here, waiting to see what this board is doing…)
LowLumen is right. Cutting is fine, but I was not suggesting cutting, sucking, or wicking. There is plenty of slack available to remove one leg of the inductor at a time. Just heat them up and pull them out, one at a time.
I see nothing to indicate that you’ve got anything wrong unless it’s wire placement, and that sounded fine. You’ve already tried several different LED setups and you’ve tried a range of input voltages. Continuing to plug at it in that way is a waste of time IMO.
I don’t know why I missed this, but I found that I can re-position the toroid well enough to get some pics that might be good enough, so I’ll post those in a bit, then, if it’s still not good enough to help, I’ll do what I need to get the darn thing off.
Some new, hopefully better info:
I used some new heavier leads from the driver to the emitter (an XM-L2 on Noctigon) and re-tested and I think that this is the behavior I am seeing (and I tried it several times):
- As I increased Vbat (Vin to the driver) when it gets to somewhere around 4.5 - 5V, the current to the driver (Iin/Ibat) starts dropping, and basically continued to drop as I increased Vbat/Vin.
- I have my clamp meter on the emitter lead, and watched Iemitter more carefully this time (sorry about earlier), and also measured Vemitter. I did these Iemitter and Vemitter measurements at Vbat/Vin at 5V - 9V at 1V increments. For all of these measurements, Vemitter stayed almost exactly 3.00V, and Iemitter stayed at 0.89 - 0.90 amps.
In other words, it looks like above a certain Vbat/Vin:
- Iemitter stays at 0.89 - 0.90 amps and Vemitter stays at 3.00V, but
Some pics from different angles. Some are duplicates, but just in case, and some have components labelled in RED:
EDIT: These pics are from the 2nd copy of the driver, which I haven’t actually used (notice no emitter leads on it yet). This board appears to have a solder bridge (you can see the big blob of solder in the 2nd pic), which I’ll have to remove and then add the emitter leads and then test, so I’ve been focused on using the 1st board.
If I just pulled one leg out, I think that the through hole would probably just fill when I pull the leg out. I’ll do that if needed, but let me know if the pics I posted are not good enough…
I was just looking at the pic of the driver from the Cofly thread that I mentioned above:
And, I don’t know if I’m imagining it, but it looks like the hole where the toroid leg goes into and the hole where the positive emitter lead goes into on the above image is reversed compared to the boards that I have (well, the toroid leg hole anyway) - some new pics below where I tried to take the pics in similar orientation to the above pic, so you can compare:
In the pic from the Cofly thread, it kind of looks like the toroid leg is going into the left through hole/pad and the red emitter lead is going into the right through hole/pad, whereas in the 2 pics of my board, the toroid leg is going into the right through hole/pad and the red emitter lead (which I added because the toroid was already in the other hole/pad) is going to the left hole/pad?
It’s kind of hard to tell from the 1st pic, so I’m going to post and see if nofear can post a clearer picture.
NVM the above, I think that is a false alarm. It looks like the two pads where the toroid leg and the emitter lead go to are shorted together anyway, i.e., so it doesn’t matter which pad the toroid leg and the emitter lead are soldered onto :(…
nofearek9 has posted info on news test he did with tailcap current on his thread:
The above was with 2 different pairs of batteries. I don’t know what emitter voltage he was seeing, but let’s just say it was also about 3V, so then his input power would have been:
1 amp x (2 x ~4V) = ~8 watts
If his Vemitter was ~3V, then his Iemitter would be (assuming no power loss between input vs. output):
8 / 3 = 2.67 amps. Good.
Whereas, in my latest measurements, I was seeing about .9 amps Iemitter at 3V Vemitter, or about 2.7 watts at the emitter end.
It definitely seems like the driver I have is underperforming compared to the one in nofearek9’s Cofly?
Do you think I should try bridging that resistor with something in parallel? If so, what value would you suggest? I have some resistors, but I don’t remember what values, but maybe I can pull something from one of the drivers in my junk box?
Also, earlier it was not recommended to short across the current sense resistor, but what about jumpering just for a short test? Would that cause a problem (like “poof”?)?
First thing; sanity check: the orientation of the red wire and the leg from the inductor do not matter. They don’t even need to connect to the PCB, just each other. The location on the PCB is provided for tidiness and physical strength.
The circuit does not look familiar to me.
The markings on [what I assume is] the buck controller look exactly the way QX9920 is marked. I don’t know what the markings mean, but the numbers change - maybe it’s batch numbers? The pinout may not match, it’s very difficult to tell because many traces go under other components.
The unmarked chip is most likely just some crap “flashlight modes” chip. It’s not very important, assuming I am correct. If it’s a familiar model you might be able to short pins on it in order to change mode groups.
Do you have a multimeter? If so it would be a good thing to do to check voltage at all pins on the “LEDA” chip in both “High” and “Medium” modes. Check them against ground.
I agree about bumping R200, but I’m not quite sure where that formula is coming from? It doesn’t match the current results, so I think we should not use it.
It seems that the formula in a QX9920 datasheet is reasonably close. 250mV / Rcs = Ileds (250/200 = 1.25)
ohaya, don’t you have two of these? You can try to rob an R200 from one and stack it on the other. (250/100 = 2.5A)
I think that where LowLumen was coming from was .18/200 => .9 amps (at the emitter), which I was seeing in the last set of tests (which are hopefully correct now :().
Yes, I have 2, but in the end, ideally, I’d like to end up with 2 working drivers (optimally), so if I can rob an R200 from another board, I’d rather do that. I’ll do some digging around my junk box(es).
Also, I don’t see any solder blobs that are obviously a problem. The short leg of the inductor, one leg of the SS34 diode, and one leg of the 151 power resistor are all probably supposed to be soldered together anyway, or that’s how it looks from here…
Re. your last paragraph/sentence: You are correct, those pins/leads are NOT bridged/connected on the one driver that I added the emitter leads to yet.
Those pins/leads are only bridged/connected via the blob on the one driver that I haven’t added the emitter leads to yet (and haven’t tested yet).
I was going to post about this: I chose to add the leads to the board that I did add the leads to because that blob didn’t look “right”. At various times, I’ve been thinking maybe the blob SHOULD be there, and maybe the board that doesn’t have the blob is the one that’s “wrong”, and maybe I should test the blob-ful board also and maybe that one will give me 3 amps, but then I decided to focus on the blob-less board first.
