Anyone worked with either of these drivers from Lightmalls?
156 posts / 0 new
ohaya
wight wrote:
It’s definitely a buck driver. Your earlier description left the possibility of a malfunctioning buck driver. We now know that it’s a properly functioning buck driver. Smile
I’m curious about something?
On the other thread about the Cofly light which appears to use the same driver, nofearek9 reported 1.4 amps at the tailcap with 2xLi-ion. So I guess that’d be like 1.4 × 8V = 11.2 watts, right?
On the emitter side, let’s say the Vf was about 4V, so if the power-out was ~11.2 watts, then emitter current should be about 2.8 amps?
But, from the testing I did initially with the bench power supply, even though I didn’t go more than say 5.5V, current at the emitter didn’t increase to that level (seemed to go down instead)?
Shouldn’t I have seen, say, 3 amps at the emitter?
I’ll need to test with the single XM-L again, but this time, bump the Vin to the driver to maybe 8V (yes, I’m willing to lose that emitter)…
EDIT: I just tested again, both with a single XM-L U2 (I think) and a new XM-L2, and am seeing the same behavior I saw before. With Vin up to 8V, the current both at Iin and Iemitter were dropping to about 0.7 – 0.8 amps. I also measured Vemitter (just in case) and was about 3V with the XM-L2 (I didn’t make a note of it for the XM-L, but I think that Vemitter was about the same, i.e., about 3V).
So I’m still puzzled!
I understand this is a buck driver, but where the heck is that power/watts disappearing to? Is the driver soaking up all the extra power/current?
I SHOULD be seeing about 2+ amps Iemitter, correct :(?
EDIT:
Although this is not the right chip, just to get an idea, I found this:
http://andrewpearson.org/?p=643
So, assuming that this driver is using a similar chip, I am guessing that the answer to my question about where the excess power is going is to the sense resistors in the R1/R2 voltage divider (fig. 11 in the above page), and probably the reason I’m seeing lower than 3 amps is that the sense resistors’ values are controlling that.
So that’s why you all are looking for the board without the toroid, to try to figure out which resistors could be/need to be changed to try to bump the driver output current?
wight
Last seen: 2 years 6 months ago
Your description of whether emitter current (Iout) stays constant keeps changing! I asked for clarification earlier and you clarified by giving an example where it did not change. Sad
Iout should stay the same once Vin is above a certain voltage. Your most recent description of Iout dropping shows a problem of some sort.
Let’s really make sure we are on the same page now. Are you saying that Iout stays constant with 2*XM-L but changes with only 1*XM-L?
In the most recent scenario you described [With Vin up to 8V, the current both at Iin and Iemitter were dropping to about 0.7 – 0.8 amps. I also measured Vemitter (just in case) and was about 3V with the XM-L2] all your losses are in the driver.
After your good find in nofearek9’s COFLY KX-T21 review we are left with 2 or 3 possibilities (that I can think of):
  1. You got a bad batch of HX-1163c drivers, nofearek9 got a good one in the COFLY light.
  2. The version you got is on the same PCB but uses different components to support higher Vf than the one in the COFLY light. And it’s just a crappy driver after those modifications.
  3. The version you got is on the same PCB but uses different components to support higher Vf than the one in the COFLY light. And the particular items you got are defective.
Without component values from a working board it’s going to be difficult if #2 or #3 are the case. I could not find specifications for this driver on Lightmalls, they don’t even list that it’s a buck driver, the input range, or anything.
I think your interpretation of where the extra power is going is probably wrong. If the sense resistor(s) was burning off 3.5W you’d know it ;-). One or more things should be getting fairly hot though. Once you move the inductor out of the way we can check.
Basically this board is nothing but a (broken, non-functioning) mystery right now. Werner and I asked to see clear pictures of the board without the inductor because of that. We don’t know the parts in use, their configuration, or anything. I doubt that there is a magic button under there, so there’s only so much good to be had by guessing what we want to see under there… if taking the inductor off and showing pictures on the forum generates results you’ll learn from that! A list of all legible component markings would also be useful – sometimes those chips are very hard to read even in good pictures.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
wight
Oops. As a follow up, I took a slightly closer look at the blog post you linked to. Figure 11 is… not relevant. It shows a constant voltage configuration, not a constant current configuration. I’m no guru, but I strongly doubt that the modifications Andrew Pearson suggested to Fig11 work correctly. I would hesitate to use his blog post about a probably failed project as a learning resource. (no offense to AP, I encourage everyone to try and make high current drivers!)
Note that there’s no followup post with a success story. I’d say it’s a safe bet that this project was abandoned because it did not actually function.
ohaya
Hi,
Sorry, I was running to do some Sunday stuff earlier, and just got back.
Re. the AP page and Fig. 11, I was just pointing to that for some info.
ohaya
I think that we may be working at different purposes, or maybe more accurately, for the same purposes but doing different things towards that.
What I’m (still) hoping is to get this driver pushing 3 amps to the emitter, if it can do that. I suspect you (all) might also want that.
I’m assuming that the driver should be able to do that (yes, I know what A-S-S-U-M-E stands for), so I keep thinking that I must have something “incorrect”, i.e., maybe a wrong emitter with a wrong Vf, or whatever, so I’ve been doing a lot of switching things around here, using different emitters and number of emitters, different wires, etc.
At the same time, I don’t have (easy) access to what I’d need to pull the coil off the drive… or more precisely, I’m not very good with solder wick or with the solder suckers, so I’ve been putting off doing something that would potententially destroy the driver.
I think I understand the more methodical approach that you and Werner are taking, though, so I’ll give that a try at this point, since I have some time with what’s left of this weekend. I’m actually thinking of just cutting that sucker off of the board, because that’d definitely be the fastest way to get it off. I’ll post back if I can get some pics of the bare toroid-less board.
Later, and thanks,
Jim
LowLumen
Last seen: 50 min 55 sec ago
No – Wait – Stop – Don’t Cut. …just melt the solder at the joint and pull it loose from the board with needle nose. (just lurking here, waiting to see what this board is doing…)
wight
LowLumen is right. Cutting is fine, but I was not suggesting cutting, sucking, or wicking. There is plenty of slack available to remove one leg of the inductor at a time. Just heat them up and pull them out, one at a time.
I see nothing to indicate that you’ve got anything wrong unless it’s wire placement, and that sounded fine. You’ve already tried several different LED setups and you’ve tried a range of input voltages. Continuing to plug at it in that way is a waste of time IMO.
ohaya
I don’t know why I missed this, but I found that I can re-position the toroid well enough to get some pics that might be good enough, so I’ll post those in a bit, then, if it’s still not good enough to help, I’ll do what I need to get the darn thing off.
Some new, hopefully better info:
I used some new heavier leads from the driver to the emitter (an XM-L2 on Noctigon) and re-tested and I think that this is the behavior I am seeing (and I tried it several times):
- As I increased Vbat (Vin to the driver) when it gets to somewhere around 4.5 – 5V, the current to the driver (Iin/Ibat) starts dropping, and basically continued to drop as I increased Vbat/Vin.
- I have my clamp meter on the emitter lead, and watched Iemitter more carefully this time (sorry about earlier), and also measured Vemitter. I did these Iemitter and Vemitter measurements at Vbat/Vin at 5V – 9V at 1V increments. For all of these measurements, Vemitter stayed almost exactly 3.00V, and Iemitter stayed at 0.89 – 0.90 amps.
In other words, it looks like above a certain Vbat/Vin:
- Iemitter stays at 0.89 – 0.90 amps and Vemitter stays at 3.00V, but
- As Vbat/Vin increases, Ibat/Iin decreases.
I’ll post the pics that I can get in a bit…
ohaya
Some pics from different angles. Some are duplicates, but just in case, and some have components labelled in RED:
EDIT: These pics are from the 2nd copy of the driver, which I haven’t actually used (notice no emitter leads on it yet). This board appears to have a solder bridge (you can see the big blob of solder in the 2nd pic), which I’ll have to remove and then add the emitter leads and then test, so I’ve been focused on using the 1st board.
ohaya
If I just pulled one leg out, I think that the through hole would probably just fill when I pull the leg out. I’ll do that if needed, but let me know if the pics I posted are not good enough…
ohaya
Hi,
Can someone sanity check me?
I was just looking at the pic of the driver from the Cofly thread that I mentioned above:
And, I don’t know if I’m imagining it, but it looks like the hole where the toroid leg goes into and the hole where the positive emitter lead goes into on the above image is reversed compared to the boards that I have (well, the toroid leg hole anyway) – some new pics below where I tried to take the pics in similar orientation to the above pic, so you can compare:
In the pic from the Cofly thread, it kind of looks like the toroid leg is going into the left through hole/pad and the red emitter lead is going into the right through hole/pad, whereas in the 2 pics of my board, the toroid leg is going into the right through hole/pad and the red emitter lead (which I added because the toroid was already in the other hole/pad) is going to the left hole/pad?
It’s kind of hard to tell from the 1st pic, so I’m going to post and see if nofear can post a clearer picture.
LowLumen
Looks like that R200 resistor is your sense resistor: so… I = .18 / R or therabouts if your LED current measures are correct.
ohaya
ohaya wrote:
Hi,
NVM the above, I think that is a false alarm. It looks like the two pads where the toroid leg and the emitter lead go to are shorted together anyway, i.e., so it doesn’t matter which pad the toroid leg and the emitter lead are soldered onto :(…
ohaya
nofearek9 has posted info on news test he did with tailcap current on his thread:
Quote:
i got from both 1amp on high 0.5 on med and 0.25 on low have in mind now i have moded the flashlight with xpg2 on copper pcb
The above was with 2 different pairs of batteries. I don’t know what emitter voltage he was seeing, but let’s just say it was also about 3V, so then his input power would have been:
1 amp x (2 x ~4V) = ~8 watts
If his Vemitter was ~3V, then his Iemitter would be (assuming no power loss between input vs. output):
8 / 3 = 2.67 amps. Good.
Whereas, in my latest measurements, I was seeing about .9 amps Iemitter at 3V Vemitter, or about 2.7 watts at the emitter end.
It definitely seems like the driver I have is underperforming compared to the one in nofearek9’s Cofly?
LowLumen
Just bump up that R200 sense resistor to the formula: I = .18 / R
ohaya
Do you think I should try bridging that resistor with something in parallel? If so, what value would you suggest? I have some resistors, but I don’t remember what values, but maybe I can pull something from one of the drivers in my junk box?
Also, earlier it was not recommended to short across the current sense resistor, but what about jumpering just for a short test? Would that cause a problem (like “poof”?)?
LowLumen
Just me, but I would never short a sense resistor. Also, the SS34 diode is rated to 3 Amps.
wight
First thing; sanity check: the orientation of the red wire and the leg from the inductor do not matter. They don’t even need to connect to the PCB, just each other. The location on the PCB is provided for tidiness and physical strength.
The circuit does not look familiar to me.
The markings on [what I assume is] the buck controller look exactly the way QX9920 is marked. I don’t know what the markings mean, but the numbers change – maybe it’s batch numbers? The pinout may not match, it’s very difficult to tell because many traces go under other components.
The unmarked chip is most likely just some crap “flashlight modes” chip. It’s not very important, assuming I am correct. If it’s a familiar model you might be able to short pins on it in order to change mode groups.
Do you have a multimeter? If so it would be a good thing to do to check voltage at all pins on the “LEDA” chip in both “High” and “Medium” modes. Check them against ground.
ohaya
What if I find another R200 resistor? Would soldering that in parallel be ok?
What exactly is the value (ohms) of the R200 resistor?
Thanks,
Jim
wight
I agree about bumping R200, but I’m not quite sure where that formula is coming from? It doesn’t match the current results, so I think we should not use it.
It seems that the formula in a QX9920 datasheet is reasonably close. 250mV / Rcs = Ileds (250/200 = 1.25)
ohaya, don’t you have two of these? You can try to rob an R200 from one and stack it on the other. (250/100 = 2.5A)
wight
Thanks,
Jim
200 Ohms. [EDIT: wrong. Seeing a pattern here?] Putting two in parallel is good, that’s what I suggest doing next.
ohaya
I think that where LowLumen was coming from was .18/200 => .9 amps (at the emitter), which I was seeing in the last set of tests (which are hopefully correct now :().
Yes, I have 2, but in the end, ideally, I’d like to end up with 2 working drivers (optimally), so if I can rob an R200 from another board, I’d rather do that. I’ll do some digging around my junk box(es).
Thanks,
Jim
wight
Also, I don’t see any solder blobs that are obviously a problem. The short leg of the inductor, one leg of the SS34 diode, and one leg of the 151 power resistor are all probably supposed to be soldered together anyway, or that’s how it looks from here…
Are they not all connected on the other driver?
ohaya
Re. your last paragraph/sentence: You are correct, those pins/leads are NOT bridged/connected on the one driver that I added the emitter leads to yet.
Those pins/leads are only bridged/connected via the blob on the one driver that I haven’t added the emitter leads to yet (and haven’t tested yet).
I was going to post about this: I chose to add the leads to the board that I did add the leads to because that blob didn’t look “right”. At various times, I’ve been thinking maybe the blob SHOULD be there, and maybe the board that doesn’t have the blob is the one that’s “wrong”, and maybe I should test the blob-ful board also and maybe that one will give me 3 amps, but then I decided to focus on the blob-less board first.
wight
Thanks,
Jim
OK, but that math is not correct. 0.18/200 = 0.0009 [EDIT: wrong]
If you can’t find any R200 in the junk box, do not despair. I’d just grab one from the other driver and keep rolling, replacing it will not be a big deal. R200 is cheap – 50pcs/$1 shipped [EDIT: wrong, I linked to 200R – the digikey/mouser info should be right] I’m assuming that it’s 1206 sized, but I could be wrong. Anyway you probably won’t end up wanting R200 since that’s apparently a much too high number! 1206 resistors of a more known quality are about $0.10-$0.25 each in QTY/10 on Mouser or Digikey, but you’ve really got to get your order together for it to make sense because shipping is $6+.
wight
I probably was not 100% clear, I shouldn’t have posed that the way I did.
I suspect that all 3 of those leads are connected regardless of the blob. Do you have a continuity test (beep) mode on your DMM? You could check them that way on the blob-less board. You can also just use a resistance mode. Taking a close look at the blob-less driver PCB will likely show that traces connect all 3 leads.
So what I’m asking is this: have you verified beyond a shadow of a doubt that they are not connected via PCB traces on the blob-less driver?
ohaya
Correction to what I said above: On the one board that I have leads soldered onto, the leg of the toroid is soldered to one end of the 151 component, but they are not solder bridged to the larger brown component.
On the other board, the one I haven’t tested yet, all 3 components (one leg of the toroid, one end of the 151 component, and one end of the brown component) are all bridged.
ohaya
To your last paragraph, no, not yet, but I will do that.
ohaya
Thanks,
Jim
If you can’t find any R200 in the junk box, do not despair. I’d just grab one from the other driver and keep rolling, replacing it will not be a big deal. R200 is cheap – 50pcs/$1 shipped I’m assuming that it’s 1206 sized, but I could be wrong. Anyway you probably won’t end up wanting R200 since that’s apparently a much too high number! 1206 resistors of a more known quality are about $0.10-$0.25 each in QTY/10 on Mouser or Digikey, but you’ve really got to get your order together for it to make sense because shipping is $6+.
Here I go… dumpster diving time :)!
LowLumen
R200 is a 0.2 ohm resistor.
