Do you have any pictures of the red light and the assembly?
It’s not super-special, it’s just a standard M1 pill, I chose the M1 b/c it works with 20mm stars. If that’s not helpful, I’ll certainly take pictures…just not quite sure what you’re looking for!
I’d like to see how you put it together as well as how the light looks. I plan on doing a similar light and maybe building a bigger light from an old 3D cell 21LED light that the LEDs no longer work on.
As you can see, the pill is pretty basic—screwed down emitter. I just used AS5 underneath. It’s a shame that this star isn’t offered in Cu (though demand certainly isn’t high enough for SinkPAD to justify the cost of tooling) so soldering the star to the pill wasn’t really an option. But I think a thin layer of AS5 on a lapped star that is tightly screwed to a brass pill is doing the job just fine.
I put kapton tape on the reflector because there isn’t an emitter spacer for the rebel.
Thank you for the help.
I’m not equipped to reflow LEDs onto stars yet (maybe never) but have used Luxeon PC Rebels premade like this: http://www.luxeonstar.com/amber-10mm-rebel-square-coolbase-leds
They drop into the (rare) SK68s with solid pills just fine.
and the 20mm boards also have done fine in a generic 3xAAA light with a solid back to stick the board to.
Drilling and tapping for screws will probably be next for those.
They do get warm — and they’re astonishingly brighter than the old non-PC rebels.
Just learned that they will be available within a few weeks on SinkPAD II boards.
I’m waiting on those for my next experiments.
In email I mentioned and pointed to BLF and CPF and urged Luxeonstar to offer some kind of discount code, since their free shipping cutoff is high. Here’s hoping.
(By the way, the packing is astonishingly high end — mounted LEDs came stacked in little snapcap black plastic cases, labeled, and separated by rounds of antistatic foam. Impressive, since I’ve understood how semiconductors get slowly wounded, accumulating damage over time by static carelessness)
Seems that expressions of interest (and suggestions for improvement) are welcome:
service@luxeonstar.com
in case anyone else wants to ask about those
Would an OSHPark board 20mm w/ vias for direct heat path be a good idea or do we have dedicated copper sinkpads/noctigons yet?
I think someone here already did a Luxeon_T on 16mm
https://oshpark.com/shared_projects/Ss2qkDsS
And with a stinkpad mod it might be able to wick away enough heat
I just downloaded the phillips lumiled Eagle library files as well
i hope someone finds some luxeon TX to play with too.
the low vf is really awesome.
maximum of 1.5A at 85C
they are around the size of the xp-g
I see that some flowers are deep red color, and that they are darker in white light than those that are medium red color.
With white light, these flowers are white at the tips of the petals and then red shading darker near the center.
With a Philips Luxeon deep red led, they are uniform light shaded.
Apparently the dye they use is dark only because our eyes are insensitive to deep red. Red colored artificial objects look equally light under the deep red light, but they look much brighter in white lite. I have noticed this with other flowers, but the white tips show how little this dark looking dye absorbs deep red light. Bees probably see this as a bright color, without the aid of a flashlight.
Another example is red wine. A glass of half wine and half water looks almost black under white light and almost clear with deep red.
I also have a lime led. Colors look sort of normal under it. There is red and blue but there is no purple. If there is also some white light, the lime led shadows look purple.
Flowers, so far, are the best objects to test color rendering.
Luxeonstar now offers the Rebels in colors on Sinkpad2 bases
and other variations
Canadian source, $100 required to get free shipping, so those real good at soldering tiny things will have better options (grin).
I bought several colors on their 10mm square bases — easily centered, on the few solid-pill AA lights I’ve been lottery-lucky to get.
If you contact them, urge a discount for flashlight modders; I’ve swapped emails with some folks there and pointed them to BLF/CPF, so maybe they will look in.
From the prices I’ve seen on the emitters alone those actually seem like pretty good prices (depending on shipping) for the emitter and sinkPAD.
Are there any current rebel sinkPAD vendors? What are they going for alone? I have one Al I’ve been saving (do they even come in Cu)?
Edit: they sell them for cheap
It would probably work better for me to get the SinkPADs separately, because, unlike XM-Ls, they don’t survive my working on the star they are on. Where can one get SinkPADs or other direct thermal stars that fit Luxeons?
A nice source for rebel leds plus sinkpad! thanks for sharing, Hank!
Now, everybody, email their contact, say you read about them here, and hey, they could really get some creative designing done with their products, encouragement all ’round. Maybe they’d consider a BLF/CPF discount, or a one time special buy, or some cooperative effort — their designers ought to be here already (maybe they are?)
I’d bet the 10mm square boards would also make a nice array on a linear or square substrate, allowing whole new shapes.
Anyone tried using a half-cylinder lens over a strip of emitters, say? ”
“Cylindrical lenses … focus light along one axis …. They are used in transforming a point into a line or vice verse.”
The vice versa would be interesting — hmmm, a line of 10mm squares with their output focused into a single point might add up to bright?
And flip then lens away for flood, of course …
A cylindrical lens focuses only in one axis. In the direction of the cylinder axis the light would spread out like from bare leds, so the result would be a line of light.
Seems to me a hexagonal MCPCB would be more useful.
I got early samples of the Sinkpad2s because I asked if they might have Sinkpads some day — they were delighted to say “why yes and very soon” — so I’d bet they will be responsive to questions about buying the bases. They have listed their older bases for sale bare, all along: http://www.luxeonstar.com/rebel-led-mounting-bases and they do say, everywhere, ask if you don’t see what you want.
Thanks.
What optics are avaliable for this?
Glad to see that Luxeon Star has improved their offerings (and prices) it’s still pricey but it was definitely more expensive the last time I looked.
@Dan, see below:
Polymer Optics 7 LED Cell Cluster Concentrator Optic
Polymer Optics 12° 39 mm Circular Beam Optic - Integrated Legs
Polymer Optics 12° 39 mm Diffused Circular Beam Optic - Integrated Legs
Khatod 13° 39 mm Circular Beam Optic - Integrated Legs
Khatod 20° 39 mm Circular Beam Optic - Integrated Legs
Khatod 30° 39 mm Circular Beam Optic - Integrated Legs
Polymer Optics 50° 39 mm Circular Beam Optic - Integrated Legs
Polymer optics and kahtod do optics to suit, they are listed further down the page you linked to.
I preferred the polymer optics offerings. For beam shots do a search on mtbr forums ‘bikelights diy’ should find what you are after.
