Tough luck on the components that came off. Putting them back on would be good practice for you…
The buck circuit rapidly switches a FET which puts a current through an inductor. The inductor smooths out the voltage to an intermediate voltage between the full “on” voltage and the 0v off state. The duty cycle of the FET is determined by the voltage drop across the sense resistor. Duty cycle means what percentage of the time it’s turned on. Shorting the resistor will produce negligible voltage drop and push the circuit to 100% duty cycle. At 100% duty cycle Vin = Vout and Iin = Iout (more or less). In other words the buck circuit will stop stepping the voltage down and go into DD (direct drive).
Since the purpose of using buck drivers in flashlights is generally to run a much higher input voltage than output voltage (MT-G2 on 3s/4s, XP- or XM- on 2s or 3s), DD is catastrophic for the LED.
Taking those measurements isn’t directly useful to me either, as I don’t plan to run this driver for anything, but I think it would be a nice thing to do for other people. Maybe bridging some of those pins enables even more blinky modes ;-).
Don’t worry about it! Despite the time we find to chat online, I know most of us have limited time for experiments. It sounded like a joke with a grain of truth and I took it as such, but if you never find time to do the test I couldn’t blame you either.
Did you lose any of the stuff for the driver that fell apart? I was at least half serious about putting it back together. It’s definitely doable if you want to, there are orientation marks for all the components with critical orientation. I feel a little bad about that one since I pushed you to steal the resistor!
Based on his post above, I think Slim Pickens may have been specifically interested in the size of the toroid itself (the donut shaped piece) without the wire wrappings.
I see what you mean. Maybe an accurate figure for wire thickness would be useful instead?
I think 4 amps could be a bad idea. The freewheeling diode (SS34) is not OK for that current, and I think the little shrimpy FET is also not going to be a fan of the higher current. You may be able to run this thing that way, but your losses will be high and if you get a failure it won’t be a surprise. Also, pushing a buck driver too far can zap LEDs due to spikes in the current. In short: no, do not do that.
I wouldn’t sweat ~3A, whether it’s 2.8A or 3.2A or whatever. Not everyone agrees with my decisions though and I certainly don’t know everything. There is a lot of unknown stuff happening in that driver.
Those tiny parts just don’t look like 4A would be their friend. For that matter they don’t really look like >1A would be their friend though, so who knows.
Yes, 3 & 4 are the pins farthest away from the dimple.
Unfortunately I’m not 100% sure what’s going on there. We’d better start by measuring everything against the outer ground ring, but we may end up measuring against that big crescent shaped trace that everything* seems to hook up to. I don’t really understand the purpose of the separation between the “true” GND ring and the other one unless it has to do with implementing the Zener diode.
*This is what I mean by everything:
303 resistor
104 resistor
cap
W8 diode S4 diode (err, I guess it’s not hooked up to the crescent)
cap / white thing
R200
AOEC #2
Toroid OD (NOT incl wire, I think): 8.05 mm
Wire diameter: 0.30 - 0.40 mm (I took several measurements, I think some parts of the wire was near where it was soldered)
Voltages to (emitter side) ground ring with driver in medium mode:
Pin 3: 4.18V
Pin 4: 0.115V
EDIT: My resistors shipped from Digikey (25 0.1 and 25 0.2 ohms)
I haven’t been able to get all the voltages on the 6-pin chip yet (couldn’t get to the one side w/o possibility of shorting something), but here are voltages to the (emitter side) ground ring with driver in medium mode that I have so far:
Pin 3: 4.18V
Pin 4: 0.115V
Pin 5: 3.12V
Pin 6: 0V
FYI, the resistors arrived, so I put 2 x 0.1 ohm resistors (R100) in parallel, and the current to the emitter goes to 4 amps at about 5V and above. I have one of those laser thermometers, and checked various points on the driver, and temperature seemed about 80F.
I tried a short test where I cranked the Vbat/Vin up, but I thought that I saw some smoke, so I shut it down.
The driver still worked after that, and I visually inspected with a 30x magnifying glass and I didn’t see any obvious (to me at least) signs of damage. Also, there wasn’t any “burnt smell” that I noticed, so maybe I was just imagining it.
We know the SS34 Diode is only rated to 3A max continuous, so that is one part I would be watching for the magic smoke to get out. Maybe look for some bigger diodes in the parts drawer.
