Based on his post above, I think Slim Pickens may have been specifically interested in the size of the toroid itself (the donut shaped piece) without the wire wrappings.
I see what you mean. Maybe an accurate figure for wire thickness would be useful instead?
I think 4 amps could be a bad idea. The freewheeling diode (SS34) is not OK for that current, and I think the little shrimpy FET is also not going to be a fan of the higher current. You may be able to run this thing that way, but your losses will be high and if you get a failure it won’t be a surprise. Also, pushing a buck driver too far can zap LEDs due to spikes in the current. In short: no, do not do that.
I wouldn’t sweat ~3A, whether it’s 2.8A or 3.2A or whatever. Not everyone agrees with my decisions though and I certainly don’t know everything. There is a lot of unknown stuff happening in that driver.
Those tiny parts just don’t look like 4A would be their friend. For that matter they don’t really look like >1A would be their friend though, so who knows.
Yes, 3 & 4 are the pins farthest away from the dimple.
Unfortunately I’m not 100% sure what’s going on there. We’d better start by measuring everything against the outer ground ring, but we may end up measuring against that big crescent shaped trace that everything* seems to hook up to. I don’t really understand the purpose of the separation between the “true” GND ring and the other one unless it has to do with implementing the Zener diode.
*This is what I mean by everything:
303 resistor
104 resistor
cap
W8 diode S4 diode (err, I guess it’s not hooked up to the crescent)
cap / white thing
R200
AOEC #2
Toroid OD (NOT incl wire, I think): 8.05 mm
Wire diameter: 0.30 - 0.40 mm (I took several measurements, I think some parts of the wire was near where it was soldered)
Voltages to (emitter side) ground ring with driver in medium mode:
Pin 3: 4.18V
Pin 4: 0.115V
EDIT: My resistors shipped from Digikey (25 0.1 and 25 0.2 ohms)
I haven’t been able to get all the voltages on the 6-pin chip yet (couldn’t get to the one side w/o possibility of shorting something), but here are voltages to the (emitter side) ground ring with driver in medium mode that I have so far:
Pin 3: 4.18V
Pin 4: 0.115V
Pin 5: 3.12V
Pin 6: 0V
FYI, the resistors arrived, so I put 2 x 0.1 ohm resistors (R100) in parallel, and the current to the emitter goes to 4 amps at about 5V and above. I have one of those laser thermometers, and checked various points on the driver, and temperature seemed about 80F.
I tried a short test where I cranked the Vbat/Vin up, but I thought that I saw some smoke, so I shut it down.
The driver still worked after that, and I visually inspected with a 30x magnifying glass and I didn’t see any obvious (to me at least) signs of damage. Also, there wasn’t any “burnt smell” that I noticed, so maybe I was just imagining it.
We know the SS34 Diode is only rated to 3A max continuous, so that is one part I would be watching for the magic smoke to get out. Maybe look for some bigger diodes in the parts drawer.
I kind of suspected the SS34, since that’s the part that got kind of lifted off of the board when I pulled the R200 earlier, but it (the SS34) still looks ok (no blistering/bulging, no burnt odor), but it’s possibly on the underside, that I can’t see.
Would these work, both electrically and size-wise:
I was just thinking of something (it happens once in awhile), and have a stupid question: How is it that the MCU on the 16mm driver doesn’t just get fried when I, say, put 9V input?
I’m not sure MCU is the proper term for that thing. Regardless of the terminology, I think the answer is that a zener diode is used to power it. Google has simple diagrams for a zener and resistor together, that is the arrangement I’m referring to.
Ahh. Ok, so it’s similar to what comfy does with the 7135-based drivers, i.e., use a zener to drop the Vbat/Vin to a voltage that the MCU/controller can work at.
Any idea if that diode I linked at Digikey could be swapped into the driver and let the driver work at 4amps?
