If I had a mill I’d mill out the star from the back to expose the pad from underneath, then bore the appropriate guage size hole in that pad trace. I’d run the lead wire into this hole from the bottom and solder the wire into the trace hole like a via, then cut it off and sand it smooth on top. A painted on layer of mask and the surface of the star would be smooth and unobstructed.
Then again, if I really knew what I was doing I’d use connectors and make the entire assembly plug and play.
No tracking number here either. But the email I got with the invoice is a confirmation plus invoice attached. At a guess, maybe they are waiting to ensure the details are correct? Giving it some time for people who have incorrect information to respond.
That makes sense, but it also said no need to respond if all is good. Perhaps a confirmation email needs to be sent. I’ll wait to see what Bella says to Ryan though.
All these guys getting a K50 in the mail is making me itchy all over.
Well, I would, but when someone edits a post on the first page of a multi-page thread, the first view of the edited post resets the 'new' flags of the actual new posts on page 3! J)
Ummm. That might be a problem, for bicycle use I can foresee a new rule about light intensity. Especially if your are from the Netherlands or close to the Netherlands. They like to make many rules for bicycles.
On the road it needs some consideration using high powered lights. It can be very dangerous, blinding people. So be careful with what you are actually doing. Please behave a bit mature on those occasions.
