Group Buy for the GearBest Ultrafire F13 - Closed?
312 posts / 0 new
hank
hank's picture
Last seen: 1 month 2 days ago
> amber
PC Rebel Amber, vF 2.55-3.5
http://www.luxeonstar.com/assets/downloads/ds62.pdf
But yeah, I’d welcome suggestions for a replacement for the driver, I’d want 350-700mA
ideally with moon mode. I’ll probably make it a floody light with a diffuser.
Yeah, I have thermal paste, I’ll be using a bit.
> 26650
I’m using King Kong 26650 4000 mAh – ICR26650 Protected Button Top from Mountain Electronics, which seemed the conservative choice. He’ll have more in stock soon I expect.
Dang, now I’m wondering if I want another of these lights, so I can do one with a high CRI Nichia.
Arrrrgh.
EDIT — surrendered, ordered another one, and put a Nichia in the first one. Let’s see, six weeks delivery time, the next one ought to be here by, um, September.
Patience….
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 6 months ago
cpfdaniel wrote:
cpfdaniel wrote:
one month today since i ordered the goddamn flashlight and still no sight of it
It arrived today, 46 days from ordering. I guess it’s ok, body could have been a little thicker. I’ve managed to nick the dome of the led but the beam looks ok to my eyes. Hate the driver, strobe+SOS? Going to change the emitter and driver pretty soon. What 26650 battery would be ok for this?
Quick fix for that…do the pencil lead across the capacitor trick…then you can go H>M>L>off, reset in a few seconds to H>M>L so you never have to get to the epileptic seizure modes Big Smile (but they are still there if you need em)
Suncoaster
Suncoaster's picture
Last seen: 2 weeks 2 hours ago
Location: Where the girls are green and the grass is pretty.
Suncoaster wrote:
Still waiting for my first two. Ordered 9 May. Not the slowest delivery, not the fastest either..
Arrived today – 1 July.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
Suncoaster
Also got a refund (they said they would in response to my PM query some days ago)
from Gearbest today.
Now I will refund their refund.
Aside from the slow shipping, it was a good retail experience, good customer service, good website.
TheFlasher
Last seen: 5 months 2 days ago
Ordered mine with tracking number. One light, nothing else. I placed my order on the 7th of June and received it around the 25th of June, might have been up to 2 days before.
Tracking number was pointless as it was never updated, it stayed on pending the whole time and is probably still there…
Everything about the light is as stated by other members. I tried burning out the led but got bored so I swapped in my XM-L2 T5-6B1 on 20mm Noctigon, BLF17DD driver, and 22-17mm adapter ring from oshpark, courtesy of RED’s shared projects. Also using some leftover Arctic Silver 5 from my pc build.
Very happy with the light, and the heat-sinking it offers. The quality is very surprising to me for the price, everything is in very good order. Does not look like I payed so little.
It is a bit bulkier than I imagined, and it’s making me question if I like it more than my C8 clone. Also gets heavy with a 26650 cell.
It throws slightly less than my C8 with the flat around the emitter on the reflector, most likely since it is a slightly smaller diameter, but it’s a very little difference.
Shipping, quality and pricing, 9/10 would do again.
All I have left is to copper braid the tail spring, since it is fairly thin and quite long.
downlinx
downlinx's picture
Last seen: 1 year 9 months ago
Ordered mine on 6/02 and still have not had it show up. wondering where my order is.
BLF Community Battery Pull Thread http://budgetlightforum.com/node/32720
jmpaul320
jmpaul320's picture
Last seen: 4 weeks 20 hours ago
mine got here yesterday – it took 41 days
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
downlinx
downlinx's picture
hoping mine shows up today or tomorrow, thanks for the reply.
WarHawk-AVG
Did the basic upgrade this morning
Solder braided both springs, put in a XM-L2 U2-4C on 20mm sinkpad, 22ga wire soldered before the resistor bridge, thing is CRAZY bright now!
downlinx
downlinx's picture
Good news, I can’t wait to start on mine.
ohaya
Last seen: 11 months 1 week ago
Do the move the emitter lead to the other pad thing – that should give you a good bump in current…
JohnnyMac
JohnnyMac's picture
ohaya wrote:
WarHawk-AVG wrote:
Did the basic upgrade this morning Solder braided both springs, put in a XM-L2 U2-4C on 20mm sinkpad, 22ga wire soldered before the resistor bridge, thing is CRAZY bright now!
Do the move the emitter lead to the other pad thing - that should give you a good bump in current...
Sounds like he did Wink
WarHawk-AVG
yes, it removes the resistor bridge (thus making it full current out of the IC), plus soldering in 22ga wire vs the thin wire that was there didn’t hurt either Silly
wight
Last seen: 2 years 8 months ago
Has anyone done any extensive / definitive testing on focusing this flashlight?
I removed the stock centering ring and replaced it with one from IOS. This left the guts loose, so I cut a paperboard ring for now (like from a cereal box) and placed that between the lens and reflector. One ring was enough to keep things from rattling, but I wouldn’t say that it made things tight. I’d do a thicker ring next time. I’m using a 20mm noctigon with 24AWG wire and had to move the wire to the outside of the solder pads to keep the reflector from shorting them. The hotspot is now much wider, but I’m not sure that it isn’t in focus.
Hopefully later I’ll take a little time with a light meter and see where focus is.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
MRsDNF
MRsDNF's picture
wight wrote:
Has anyone done any extensive / definitive testing on focusing this flashlight? I removed the stock centering ring and replaced it "with one from IOS":http://intl-outdoor.com/cree-xml-led-reflector-positioning-gasket-10-pcs.... This left the guts loose, so I cut a paperboard ring for now (like from a cereal box) and placed that between the lens and reflector. One ring was enough to keep things from rattling, but I wouldn't say that it made things tight. I'd do a thicker ring next time. I'm using a 20mm noctigon with 24AWG wire and had to move the wire to the outside of the solder pads to keep the reflector from shorting them. The hotspot is now much wider, but I'm not sure that it isn't in focus. Hopefully later I'll take a little time with a light meter and see where focus is.
I haven't pulled the bezel and lens of mine but it looks like there is two o'rings in this area. One above and one below the lens. Could be wrong here though. If I had the same problem you had I was going to look here at adding a thicker oring. I did a bit of testing with different thickness isolators and took measurements along the way in my modded thread on this light. Good luck.
carry16
carry16's picture
Last seen: 8 years 4 months ago
Still waiting. PP case filed.
Velectron
Ordered 9 Jun, arrived today 23 Jul.
Stock current on high was a measly 1.7A. After spring braiding, changing to 20AWG wires and rewiring the LED+, the current went up to….2.2A? I guess my newly purchased meter is really shot… Flat Stare
I am using a freshly-charged KK ICR by the way.
wight
Stock current on high was a measly 1.7A. After spring braiding, changing to 20AWG wires and rewiring the LED+, the current went up to….2A? I guess my newly purchased meter is really shot… Flat Stare
Make sure you’re using thick/short leads. That’s typically the key. DMM quality doesn’t have much to do with it.
downlinx
downlinx's picture
got my f13 yesterday, have not had a chance to tear it down yet.
MRsDNF
MRsDNF's picture
I'm not sure if its been reported but the last five I received on inspection had XML-2 leds. They also had XML-2 on the battery tube in place of the XML-T6. On a very quick test light output is similar so they must be a very low bin. When I have time I will look into it further.
leaftye
Last seen: 12 hours 16 min ago
Mine arrived a couple days ago.  It also has an XM-L2 emitter, but the battery tube still says XM-L T6.
The low mode should be lower.
LANTUS
Last seen: 8 years 1 month ago
Hi .
I am willing to give 3A to my F13 but i cant have access to the driver and i would like some help ( im a noob ) .
Do i have to push hard 2 or 1 ? Is it ok to push it with a hammer+a screwdriver or a hammer+a spanner wrench, or should i buy something like this : https://www.fasttech.com/products/0/10002694/1200101-rewin-snap-ring-pli... to open it ? ( i have read someone did it with it )
wight
I recommend using sturdy tweezers to turn the ring.
LANTUS
Thanx for the information, i will try .
harry218
harry218's picture
Last seen: 2 years 4 months ago
Don’t forget to wrap the tweezer handle with a thick cloth. Will make it easier to turn.
WarHawk-AVG
Mine was a pain to get the driver ring loose, I ended having to hook a flat tip screwdriver into one of the holes on the ring and really hork down on trying to spin it, once it popped loose it is easy to take in and out
Gj
Gj's picture
Last seen: 4 months 1 day ago
Fairly easy with needle-nose pliers from Harbor Freight. I bought a bunch when they were on sale for $1.29.
http://www.harborfreight.com/5-3-4-quarter-inch-needle-nose-pliers-40696.html
Naturally you have to pick through the bin at the store, some are ground finer than others, some are rounder some are squarer.
No horking required. Laughing
WarHawk-AVG
but…but…but I like to hork Smile
Gj
Gj's picture
But you wouldn't enjoy it as much if it was required.
ohaya
What is “hork”?
