I dont want to build a light with a 20 minute run time on high. I did do a run on medium as well at 2.65 amps and ran about double the time it did on high. I'll try an XML. It should get substantially longer run time but it isn't a MTG-2 if you know what I mean.
Maybe a triple XML for that battery pack?
Speaking of triples… I finally put together one of Scaru’s triple XML’s and nada. They worked before I reflowed them to the board then nothing on the board. Reflowed them to different MCPCB’s and they work fine. Is it possible that I messed up the file transferring the file through my computer before having Oshpark assemble it? And something is wrong internally? I am at a total loss. Any suggestions?
Here is a picture of the boards, the dots are supposed to correspond to the dots on the top of the XML. Is the positive and the negative reversed on the mask?
Right now I’m trying to figure out the DMM buzzer…
Did the DMM show continuity between + and - without the LEDs populated?
I just downloaded the files and took a close look in GerbV. Everything looks OK to me on the board. It seems to me that you have polarity/orientation correct.
I’d re-install the LEDs and test them using diode test, which should make them glow.
Some may recall the old saying that God looks after fools and drunks… With that in mind it occurred to me that perhaps I was using only half of my true potential. So after some home made pesto pizza with artichoke hearts, some Pliny the Elder and lively conversation I returned to the curious MCPCB and I used a new one. Bingo, I see spots! Seriously I still see spots, but it/ they work. The MCPCB is soaking in gas right now. Well it’s two stroke mixture as that was what was available. So the light that comes out should be well lubricated.
Also, I think I might solder better tipsy. Or tomorrow I will see my work and be appalled, swearing off drinking and soldering forever. Not unlike the great calculus event of 1996 when I swore I would never drink and derive again!
BTW, guys- thanks for the helpful input. It’s been a tough week. Perhaps it sounds silly but it means a lot to me that I can cry for help here and get quick useful answers from people I respect and enjoy hearing from.
Ok great success followed by a Chernobyl like moment.
Ingredients were gathered.
Used a dd17 harvested from an S6 of Dales (soon to be replaced in the S6)
Pretty…
One that is different after cooking off one of the original 3 replaced with what was on hand.
It got hot, really hot! Started like 4000 Kelvin then started to drop toward 6500-7000 and get dimmer. Melted the optic onto 2 of the emitters and popped the ground joint. It was way more hot to the touch than my MTG2 in an S3. I don’t think that aluminum spacer was up to the task, it also put out a lot of power. Might be too small even with copper. I guess this is what I get for being cheap. I didn’t do the XPL’s that Dale and I had conspired on as RMM had some cheap used XML emitters of uncertain bin. I need better tools and to clean my bench as well.
I’m thinking of replacing this reflow station with something a little more precise…
Sweet jebus that got hot! What base is that copper wrapped around? What optic is that? What host eas it in? A host and a tightly wrapped pill is definitely needed to help shed heat.
Direct driving 3 XMLs will do that to pretty much everything...
