When I make any changes at all I put the light completely back together to test it, save for leaving the reflector out in order to clamp the meter on the wire loop at the emitter (most of the time)
So the power supply is the battery carrier in the TK61. I have 4 Panasonic NCR18650B 3400mAh cells in it. I’ve also got the extension tube with 4 more but don’t use that when testing.
And yes, I connected pwm at the MCU side of the 30,000 resistor, just off the pwm leg of the mcu (mcu removed of course) so I’m bringing the pwm back in where it was originally coming from…the signal then goes through the 2 resistors on the way to the controller just as it was originally set up.
With the Zener mod to the Qlite board, the MCU cannot get over 4.5V. Works on a dozen or more drivers I’ve built for MT-G2’s so it should work here, right?
attiny13 just stops working if voltage goes over 6v. Besides, whatever component is getting the PWM signal operates from a digital signal (either on, or off) so more voltage or less voltage on the PWM pin should have no effect on the output. 6 volts is just as 'on' as 4 volts.
I don’t think this is the case. Comfy’s explanation is correct, a higher voltage on the buck controller’s PWM input will not cause the problem DBCstm described.
It’s more likely that the driver produces high voltage spikes at higher currents. We have that problem with other drivers as well. The “big” LEDs seem to cope with this better than the XM-L/L2.
I did think that the hx-1175b was shown to work OK driving an XM- series LED at higher currents than that though… Am I remembering wrong?
I thought some buck controllers do relative voltage adjustment.
Are you two talking generalities, or about this specific buck controller? If generalities, do you feel 100% certain that it's safe to rule out the PWM voltage as the potential issue?
Not trying to cast dispersions on what you 2 are saying. Just trying to figure out what we know for certain in order to figure out how to help Dale.
The driver seems stable, but I have not used an oscilloscope or anything to search for spikes. Given no other options at the moment, I think Dale should grab the voltage from the point I recommend he use in Post 82 and see what happens.
Don’t worry, no offense taken. I just wanted to be plenty clear that we aren’t speculating about the PWM. PWM signals work (provide a duty cycle) or don’t work, but there is no device that gleans something additional from the voltage on a PWM input.
Can you remind us of how far this driver has been successfully pushed with an XM-L?
I haven't tried to keep track of that. I know some people have used it to drive xml's using it in it's stock configuration (7ish amps). It's a popular UF-T90 mod. Driving an xml/xml2 over 7 amps is touchy business with any driver. I did a quick search and saw a couple examples of driving xml's in other lights or just testing of 7 amps and less.:
Interesting. Thanks for the links, that’s the kind of thing I needed. So, while I’m confident about the PWM voltage not being the source of the problem… maybe it would have been better if DBCstm could have tested the stock driver on an XM-L/L2 before doing the ATtiny13A mod. My money is on the idea that he just got a bum driver!
I got 2 and have had the same issue with both. The issue is in the driver giving too much Voltage to the emitter and frying it when using larger wires. Richard has been having the same issue I’ve had and is working on solving it. He’s burned up 10 LED’s to my 5 or 6. So now I know it’s not just me.
So, apparently putting 20 ga wires on it lets the buck converter run the Voltage up too high.
Bummer. Starting to sound like this is an MT-G2 emitter only driver. Thank you for the info guys. I was just about to build a light with this driver and xml2's. Need to go another route, it seems.
I will post some more details soon, but all it needs preliminarily is a little output capacitance. 22uF ceramic is enough to keep it from blowing LEDs with the factory sense resistors.
I also tried swapping FETs, diodes, and adding more inductance, none of which seemed to help at all. I was surprised that adding more inductance didn't work.
I will see how far I can push it with extra capacitance. Unfortunately I don't have an oscilloscope so I can only tell whether or not the voltage is staying within the limits of an XM-L2 but I suppose for our purposes we don't need a perfectly clean output.
Good work RMM. It seems that an inexpensive scope might pay dividends if you are burning up a lot of LEDs in your testing? Just FYI, the PC based one comfychair is using is $75 shipped from the US.
I do have a scope, although I only get one channel. It seems that my QX5241 driver zapps LEDs at 6A, based on one potentially flawed test. I’ll get some more caps in hand and take a look at that on the scope ASAP… starting at 4A of course ;-).
With two 25v 22uF ceramics on the output I can run 50 and 68 ohm sense resistors together with no issues, which delivers over 8A to the emitter with 18 AWG wires. My TK61 is pushing over 2000 lumens OTF now!
I spend much time at the law office these days! If I remember correctly, it was pulling about 5A on the input for over 8A on the output... sorry but I don't remember the exact numbers but I am going to be building some more this week. I'm guessing that efficiency is around the 85% mark when it is run full bore.
I think I am going to order an oscilloscope. There have been a few things that I have been able to pin down by trial and error and lots of online searching, but it could definitely be a time saver (and time is what I am usually short on.)
In a few more weeks I will be done with my law office/internship assignments and back to regular school, which interestingly enough gives me more time experiment, list, etc. I thought I would have more time this summer but I have had significantly less because I decided to take on the second job along with the first.
