To the best of my knowledge there's only one base unit, you can buy it with or without extension tubes. I have a 1 cell and a 3 cell version from WB, either base unit works with 1,2 or 3 cells without visible output variation.
+1 same here. Pretty sure the 1 cell versions I bought from WB were with buck driver circuitry. The 2 cell might make a nice MT-G2 host with a zener mod driver. Not sure of the reflector opening - will check this eve.
They do. I just bought four of them from WB and they are all identical. Only difference among the samples was one had orange o-rings instead of red.
Speaking of the light, I did some measurements last night, and the emitter shelf is up to 8mm thick! I’ll take some pictures of the light and post them here… now just to figure out how.
This was bought as a single cell - note the big inductor for buck circuitry. Nice flat pill top, single piece uni-body style and easy access to the pill top. Massively thick pill top I might add...
In this thread: https://budgetlightforum.com/t/-/24076, post #77 has stock measurements I made, post #86 has the prelim mod #'s and post #117 had final #'s, after the UCLp upgrade. My #'s may be a little high (optimistic?) but I use the very best cell I have, actually the Powerizer may be the best cell in existence - too bad you can't buy them anymore.
Thanks for the great pic Tom. It looks extremely robust. Is the stock mcpcb thicker than a noc or sinkpad? If so, any issues with reflector seating after the swap?
Oh boy - the mod was done a while back, this pic is from back then. I'm thinking it worked ok - using a lower profile centering piece, and possibly thicker MCPCB, but I believe these bigger MCPCB's are already fairly thick, in the 1.5mm range, close to a Noctigon or SinkPAD. For some stupid reason, I don't have many pics from the mod and the light is sold off to a relative, hunting/fishing activity. I can find out a little more from the stock lights I have.
Stock Yezl Y3 white wall beamshot here in the M12 review in the OP: https://budgetlightforum.com/t/-/27258. Don't think you can tell much, but, it's a wall beamshot...
