I wouldn’t mind playing with your BRD file for a few minutes
Trapezoid, you want a trapezoid…fine i give you a steenkin’ trapezoid
No change in price
2 layer board of 0.99x1.58 inches (25x40mm). $7.80 for three
Top
Bottom
On Oshpark all pricing is based on a bounding rectangle which your design fits inside.
Also, what female USB connector part is this designed for? eg do you have a link?
working on the 2 up stacked USB…if I can locate the .lbr
And just like that I find a BETTER IC…the TPS2511!
Well…this one above is more or less being fed a well regulated 5vdc for charging…the TPS2511 IS the regulator…daggumit!
Gimme a few…working on somethin’ somethin’
Here is what I found…a thru hole stacked USB 10 Watt regulated board
https://forum.sparkfun.com/download/file.php?id=2338&sid=22c452779513127260ea948fefeca628
Is it adding anything you need? Seems like you’ve already got well regulated 5v, so no need to add cost…
Truthfully it’s not, the chips are about 1/2 the cost of the TPS2513 though, and it does offer some sort of regulation
For a quick snapshot of what it looks like (would like to make it a SMD variant)
I would like to import that part (stacked USB ports)…care to edumicate me on how to do that
I haven’t seen the part, I’m tired of RAR files and don’t have anything that opens them installed. So I’m not sure what needs to be done. It should be as simple as adding the library to your Eagle and then adding the part…
A single port chip that’s 1/2 the cost of a dual port chip… waste of board space?
I still think your 2-port board can be smashed down to around $3.50 with no loss of functionality and similar mounting provisions.
well…here ya go if you want to tinker with it…remember I am an amature at this (not like it doesn’t show…haha)
USB connector like this
http://www.mouser.com/ProductDetail/Wurth-Electronics/62900416021/?qs=sGAEpiMZZMulM8LPOQ%252bykwes9nghi1yU8hWfntl28MRV975KuTb9Ug%3D%3D
What are you looking to do? Itseems you already have the part.
I use it where ever I have twelve volts, with my solar set up for instance to charge Ipad and wife’s and my own Iphone.
Have you guys tried Dirty PCBs ? You have to wait for shipping from China but $14 for ten 5cm x 5cm boards is dirt cheap. I tried to upload an OSHPark design to their site but they must need a different format. Complains about a lack of a drill file.
Gerber file extensions are listed on Dirty PCB's about page. They provide a cam job and .dru design rules.
Gerber file extension | Layer |
GTO | Top Silkscreen (text) |
GTS | Top Soldermask (the 'green' stuff) |
GTL | Top Copper (conducting layer) |
GBL | Bottom Copper |
GBS | Bottom Soldermask |
GBO | Bottom Silkscreen |
GML/GKO/GBR* | Board Outline* |
TXT | Routing and Drill (the holes and slots) |
It was on the brd I downloaded but not in my .lbr directory, I wanted to copy from that stacked one that ones mine, so I could replace the single one on my board with a double stacked one…this way the board could like wight said it could be less than 1/2 the size it is now
Wait time from OSHPark is bad enough, and they are made here CONUS…I just like the purple board goodness
However it might help to get the SRK boards made in 2mm vs 1.6mm (the OSHPark boards are thinner than stock boards and sometimes lead to issues with continuity between the driver and battery tube [aw crap…they charge and extra $20 for the 2.0mm upgrade…fooey])
I wonder if those triple and 7*XML Scaru boards would do better on .6mm thick boards heat wise…hmmm
I wonder how many BLF15.17DD would fit on a 5x5cm panelized board…hmmm
To get the parts from a board you have downloaded: File > Export > Libraries
Sweet…I’ll try it when I get home!
Thanks for the heads up! I will try them. I’ll continue to need OSHPark for my rapid prototyping needs, regardless of how many filthy little PCBs I get shipped from China.
Also, I figure they’ll probably have similar routing restrictions to other things like Seeed: you can’t break-route panelize w/in your 5x5cm boards. If that’s the case it’s a horrible deal for small round PCBs and a good deal for larger ones or ones that you can cut apart yourself (rectangular boards).
I’m sitting here looking at an Anker USB 3.0 7-Port Hub with Charging Ports (5V / 2.1A and 5V / 1.5A). This is $30 at Amazon. What were you looking to charge with yours with that high current bad boy?
I have dual port 12V, 2 amp cig chargers for the truck for iPhones, SLR 1amp and for Xtar
500ma.
Curious.
1 amp and Xtar
500ma. Curious.
I was looking for a way to have the device auto range and draw max amps and use a cheapo ATX powersupply, make it scalable, and say hey “I did that”
Pretty much you can take a cheap’o whatever, and solder a 100ohm resistor (or even short) the D+ and D- and it will automatically pull up to 1A, but if it can pull 2A (10 watts) why not have it do it automatically
Beautiful thing…with an ATX powersupply, 5vdc is the rail is where the most “available” current is at, but it also has a 12vdc rail, and a 3.3vdc rail, the 12vdc rail I can plug into my Nitecore I4 and possibly reduce the heat generated internally due to the transformer changing AC to DC to run the charge portion, and HKJ even reviewed a NiCD/NiMH charger that uses 3vdc wall wart…well if I had one of those I could then tie into that rail…it allows a throw away power supply to be used for quite a few other things…and they usually do have very good regulation (as long as you have a load resistor on the rails [in most cases])
It all boils down to…I’m a tinkerer, and I just wanted to see if I could do it and fiddle futz around a bit (this is my hobby after all )
wight have you tweaked it up any?
I think I might order me a set of the trapezoidal ones and see if it works out…use the charge doctor to see what kind of current different devices can pull
With the cost of the board down, I should be able to build a single dual unit for pretty cheap…
TP2513 $1.87 x 3 = $5.61
TERMINAL BLOCK EUROSTYLE $0.80 x 3 = $2.40
CAP CER 0.1UF 0805 pennies (I think I have a bunch for off time caps for BLFDD drivers) I will calculate at $1.00
SMD LED RED 0805 $3.83 for 10
Resistor 150Ω 0805 $0.21 for 10
USB Type A SMD $0.77 x 6 = $4.62
Boards $7.80 per set of three
Total = ~25.47 so each unit will be roughly $8.90ish a piece
Question? Would you put some mount holes like in the original for “stackability”?
