There is only 22 lights shown as ordered. This does not sound right to me. It may pay to check with Ric or again check on the webpage under order note.
I really like this and was thinking of doing an MTG2 conversion. A bit concerned that the reflector won’t give the MTG2 all it’s glory and will narrow the flood too much. Thoughts?
I wouldn’t know how to articulate the pattern I’m after. I’ve seen beam-shots of the G2 and it’s great. I just fear the Y3 is the wrong host for it considering it makes the XML beam soo thin.
I guess 30 degree hotspot with the rest flood would be what you would expect with a G2? Otherwise might as well leave it as is.
Think I posted this before, a wall shot of the stock Y3 can be found here: https://budgetlightforum.com/t/-/27258, compared to a few other lights. Looks like the flood area is smaller than a HD2010 - all beamshots taken from same exact distance off the wall (light and camera). An HD2010 has a pretty shallow reflector compared to other throwers show (K40, M12, etc.), so wider flood.
