After using it only a few times (less than 10 minutes of total use), my SC01 has started to flake out on me, flashing and turning itself off. I need to find something to pop out the pill assembly without destroying the driver. If I can do so, I may as well do a driver swap.
Also, in case anybody cares, the TIR optic that fits in the Convoy S2+ fits really well in the SC01, as long as you reuse the lens and replace just the reflector.
Thanks, it was much easier than I expected. I just used the biggest socket that fit in the battery tube and gave it a couple light taps with a mallet. Now to troubleshoot the flakiness.
Has anyone replaced the lens on their SC01 yet? I gifted mine to a friend, but the lens has broken and I want to order a replacement for him... I don't have the light available to measure... Anybody know the diameter so I can order spares?
The SC01 I purchased and gifted to a friend in June has died this month, only lasted for three months. The light was operated using NiMH cells only, no 14500s. When he brought it back to me, I tested using both known-good cells and a 14500 but it wouldn't function either way. I completely disassembled the light, which turned out to be much easier than expected.
Press the head of the light firmly against a rubber surface, (e.g., old inner tube, shoe sole, etc) and twist CCW to remove bezel.
Remove lens/reflector/o-ring
Press pill out of body; I used a couple of stacked sockets of the correct diameter to fit the battery tube, then used a large C-clamp to press the pill out through the head.
On removing the driver from the pill, I noted corrosion on the components. It looked similar to what you would see if liquid had entered the light, but it's been kept dry. I cleaned and checked the LED and solder joints, but the driver is definitely dead. I'm fairly disappointed with how long this light worked.
Second note, the lens is an odd 22mm diameter. The light had been dropped once before, and the lens had cracked. The lens size isn't common, and I was unable to find a replacement lens through normal sources. I could have purchased a flat glass watch crystal cut-to-size via an ebay auction I found, but it would have been over $6 after shipping. That's the only option I had found after a cursory search...
flashlightlens has UCLp lens in that size, and close sizes as well. Just have to check the thickness, if it will work out. It's pricey but better than the stock for sure...
I haven't modded mine.. But think the driver can be replaced or piggybacked...
My SC02 NW from BG died as well. But I don’t think it’s the switch - after pressing for 7 seconds it turns on in strobe mode so switch itself it works. There’s something wrong with the driver.
EDIT. I disassembled it, tightened everything, assembled again and it works! I don’t know what was wrong, driver was 0,5mm our of the pill so I pressed it flat but I don’t know if that was a reason. But I can see beam isn’t perfect now, there’s slight donut hole. And now lowest mode turns on after 2 seconds, not 4!
I have lost some hope in the sc series of lights. I was selling them for a while but i had too many returns. The driver died in a few from heat after they were ran for extended periods. When the light was off. The led would stay faintly lit. All the other bad ones had problems with the side switch. Bad design. The switch solder points are way too close to the pill. Sometimes the switch shorts out on the pill. And you have to press the button super hard to get the light on. It is too bad though because it was a neat little light.
So far the three i have been working great & used often. (SC01, 02, 03) i hope they stay working or the manufacturer fixed the issue people have been having as i like the design and form-factors of these. My SC01 with a Nichia 219 get used quite a bit and is my current Jacket EDC.
I got my SC02 last week. It worked the first time I tried, but now suddenly not working. I have no clue why it stops working after a week unused. Battery voltage still full.
What could be the problem ? Bad switch ?
From what I’ve read , it seems fixing this is a very delicate process.
This is the worst $15 I spent on a flashlight. Even my cheapest $2 worked for at least 3 weeks.
