Thanks. I will try to get a better set to check if mine is not up to the task.
I have those leads BTW: http://www.dx.com/p/multimeter-test-leads-probe-cables-90cm-33451
oh yeah, those leads are woefully inadequate
I took an 18ga automotive wire, tinned about 3/4-1” of one end, folded it over to make it double thick re-tinned together (this is the end I slip down into the multimeter plugs) other end I put banana clips, leads are about 12-14” long, those will give you MUCH better readings for sure
Wow, good job with those wires
We have some Flukes at work, I will try to see what one of them shows.
EDIT: Nope, still 2A. What else can I check? Battery? Or just try running it from a DC supply @ 4,2V?
Stock Fluke leads are no good as well - sorry. Not made for high amps. Quality of the meter has nothing to do with it.
Seriously? Meter rated 10A produced by an established brand is not able to measure 3A using included equipment?
Sick.
I bought a budget DMM and the stock leads could never measure things correctly. I soldered 22awg wires on banana plugs and using this I can measure up to 5.8A, maybe higher but don’t have light driven >6A yet. Perhaps I will upgrade it into 18awg next time.
Oh ya, I completely abandoned the stock flukes, everytime I just put my 22awg “leads” directly on the measuring points and that’s it.
Sick.
I’ve seen quite a few people come to this same realization.
Just grab some 10-14 guage wire, pair of banana plugs, and make some leads. I think I spent like $5 on mine and $20 for a DMM and I get very accurate measurements. 2.6A was as close as I could get with the stock leads measuring a 2.8 driver.
Seriously? Meter rated 10A produced by an established brand is not able to measure 3A using included equipment? Sick.
I believe that is not a correct statement. Any enthusiast person with the basic knowledge in electronics know Ohm's law and can expect that long and thin leads not to display the correct current on low voltages.
You have to understand that flashlights have many weak point, springs, wires, switches, etc which all add resistance on a low voltage power source (4.15V).
Now, try to measure 3A on 110V power supply, you wont say that a meter rated at 10A is not able to measure 3A with the included equipment. So and establish brand is able to measure what it says, but not in any condition.
I’m waiting for this flashlight, but with SMO reflector. I think that will be delivered tomorrow
14 AWG silicone multi-strand wire works great for me. Very flexible, about 12" or so. I simply solder the ends I use to measure. The other ends are heavily soldered into banana plugs. Once in a while clean-up or re-solder the working ends.
Today i received my convoy c8 xm-l2 u2 1A from banggood. Just one word… wow! With protected cells (both trustfire and panasonic) is brigther than my lightmalls ultrafire c8 xm-l2. Wider hotspot due to the op reflector but also overall more lumes. I think the lightmalls c8 draws no more than 2.5A… bad driver or just bad batch. Much better value than any ultrafire c8 around.
Glad you like. And I concur. My C12 wasn’t as bright as the Convoy. My hat goes off to this meaty little budget brand.
Thank Fabio123 for the sharing. When did you order your Convoy C8? Looks like you are receiving the older version of it though.
By the way the C8 on the right is the Ultrafire? I thought the new Convoy C8 also has similar centering piece like that.
Ordered mine from BG on the 10th got it today and it's the new version. But mine fits protected button tops!?
Ordered mine from BG on the 10th got it today and it’s the new version. But mine fits protected button tops!?
That could be a game changer for me. Convoy says they wont. Must be a tight fit?
Yes a little . I have a Tenergy in it now and it works fine . I put a 3100 Keeppower and its a tight fit width but length is ok . I would like a little more room.
BG might be using a different driver hence the extra room.
i ordered an old one from FT tonight because I wanted the old style. I like the new style but not what I really wanted.
Does the new version of convoy c8 have a pill that accept 20mm star base plate? Or is it still uses 16mm pill?
Ordered this today to replace a 502b I sold to my stepson.
Thanks for the great reviews!
20mm aluminium pill
