No switch, put in battery & the flashlight will work
Im guessing this is a twisty, lol. http://www.dealextreme.com/p/fandyfire-bt-qs88-xm-lt6-waterproof-1-mode-1000lm-white-led-flashlight-2x26650-2x18650-4x123a-91661
I do not know if the XM-L would benefit from such a flat area around it, like the reflector of the MC-E Torchlite with 55mm head and it appears to be heavy OP.
If you don't mind the double battery format this would make a better host in my opinion:
Anyone actually purchase either the UF-2170 or the UF-2180? Curious to see beam shots and find out if they are equivalent or essentially the C8 that is highly recommended on BLF, but with the 26650 battery.
Is there anyone here that has actually seen/used the shadow? I want one but I am not willing to buy the batteries and a new charger on a whim for one light.
Just in case you did not try, 3AA hosts are normally compatible with 26650 as far as I have seen, the closest I got is a zooming from taobao made for 4AA but this one could have a 32600/32650 instead.
*I am only talking about sizes, drivers might not be compatible and should be replaced.
I have one, very nicely finished, great throw, fantastic levels, for a light of this size and power the medium is perfect for most jobs and the low is really low, the strobe is very fast, nice thing is it doesn’t have memory so you never see the strobe unless you want it. Starts H,M,L,S, I love the settings.
You won’t be disappointed.
I have bought several days ago something I dreamed of, single cell 26650 3x XML flashlight :) 56$ with shipping, I hope it is worth something, but it should be :) Now it is just a question of one cell driver able to deliver 5 or more ampers...
