Great Tome E now I don’t know which zoomie I am going to get I can only afford one, and I don’t know if I should go with Dealmetic s new light of the supfire? Choices, choices Thanks for the heads up on a quality zoomie
Hi Tom, thanks for the review! Looks like a really nice cheap zoomie. I wish it had a clip though.
How does the size of the flood of the SK73 compare to the SK98 clone?
Thanks for going to the effort Tom E.
The SK98 has a slightly larger flood area. I can fit the SK73's flood inside the SK98's. The SK98 always did have a nice wide flood, but the F3's is slightly larger, and the 875 larger still.
Nice review and photos. Looks like a decent value for the price. Thanks Tom E.
Thank you for the review. Such a shame there is no clip. That is a dealbreaker for me. I loove zoomies though and always welcome another review of them. (I cannot count how many sk68 reviews I have read LOL )
Love the quality though. Love it!
Added more info to OP. Driver is 22mm. Will add lens measurements. Based on the shape, looks like you can add a clip with a little work. Not sure of clearance - where to mount.
Okay - finally got the flaky loss of output fixed, corrected, gone!! The replacement Omten switch fixed the problem. This is the Omten switch that fixed it:
https://www.fasttech.com/products/1203605
Since that was my last, I'm ordering 2 packs of two more. Just hope FT doesn't pull a fast one and now ships a cheaper clone (no, they wouldn't do that).
Now it's doing 411 lumens OTF on high, 228 on med, 112 on low -- all tested in full flood mode. You may not think 411 lumens is so good, but, it's at only 1.52A, it is an XM-L2 probably T6 on aluminum, and it is a zoomie -- zoomies are notorious for high % loss's even on their best position of full flood.
thanks for the review. so once modded, would it be brighter than your t6-875?
All depends - hard to compare unless they have the same exact mod done, and I rarely do that . I don't see any reason they would differ significantly, in this case, it would come down to the aspheric optics, and they look about the same width. The 875 is a 20mm driver while this one is 22 mm, so the pill is wider. For the 875, for heat sinking I used 2 pennies - fit them well - perfect in diameter. This F3 has a pretty nice thick pill top and pennies are too small for it. Ideally, I would want to add some copper, screw down the MCPCB like I did on the 875, and use a 22 mm driver, or piggyback a 17 on it. I did move the stock LED + wire and upgraded the wires to 22 AWG and amps went up close to 4A on an Efest 35A cell, but I lost mode changing after a minute or two, as it heated up. Also, I upgraded to a XM-L2 T6 4D (from FT) - like the tint better than the 875.
I'm really not liking the mode spacing - way too close, the medium is over 50% and the low is probably ~30%, so I'd much prefer replacing the driver for my own use. I try to mod/post about the stock driver as much as possible to save others the cost/time/work, but this driver for me, has got to go.
OP updated with mod details. This the latest mod "for now". I'd prefer a custom driver, but keeping the amps somewhat in control at 3.2-3.5A or so.
ttp://slickdeals.net/f/7713635-supfire-f3-l2-cree-xm-l2-5-mode-led-flas…
https://www.myled.com/p9098-led-flashlight-cree-l2-1100lm-5-mode-white-l…
Use the code “15SD32” for discount.
Just tried the code and it currently works.
I bought two of these so far, no regrets.
EDIT
Just ordered (March 14th) another 6 Supfire F2 L2, total was $36
Mine arrived today, from the BLF Deal Alert Thread. It is indeed a very nice medium sized 18650/3xAA zoomy. It’s bigger than the SK-73 or ZeusRay: thicker battery tube, wider head and lens and longer. Nice knurling. The head slides on two o-rings. Solid pill. Even thermal compound under the star, but it wasn’t spread out, probably because there were chunks of shavings all over the pill, probably including behind the star. I fixed that and switched positive driver outputs. It is most similar to a Smiling Shark SS-100 and others of that style, or even the CNQ Zoomy Host with Ahorton lens, with build quality in between those two. The focal length of the lens is also intermediate between those two.
I payed $6.90 and it lists on MyLED for $10.08, which is still a good deal.
Mine arrived today also and am quiet impressed at the quality for such a cheap light.
I would like to swap the + wire on the driver but I want to make sure I understand correctly where it goes. Does it go just to the left of that square thing with the 8 legs?
Yes. That looks the same as what I just did. The spider is the control unit. I unsoldered the red LED+ wire from the top left and soldered it to the pad to the left, in the picture, of the 8 legged IC. First, I checked that my cheap multimeter reads only around 0.2 Ohms between these two points.
Ok, thanks
I am a little confused and a newbie, is just moving the wire good enough as a simple mod?
Will the lights modes not work after the mod, or only if also upgrading the wire? Not sure what to make of these 2 statements.
“This is the style where you can easily bypass the current limiting resistors by moving the + LED wire to the pad on the left that is before the resistor bank Simple way to boost the amps. Mine went up from 1.52A to 2.2 or 2.5A on a better cell, keeping the stock wires. A very simple amp boost mod!! —>”
“Ok - got some more modding done, keeping the stock driver. I tried moving the + LED wire before the resistor bank and after upgrading to 22 AWG wires, and amps went way up, getting close to 4A, but in further testing, it would only work in hi mode after it heated up, then cools down - back to normal modes. ”
Welcome, I can only answer the first part, moving the wire was good enough for me, made a big difference, the modes are still in tact after the wire move. The light is just as bright as the zeusray now, just wish I would have bought a few more.
I saw the same problem - mentioned it in the 8/01 section in the OP...
