The last paragraph was measurements taken from the chip on the inductor side with the negative lead on the driver end of the wire connecting to the LED negative, I’m not sure if they were relevant though.
I’m sorry to mess you about with mistakes, and do appreciate your help. I’ve just got readings on medium, but having done a few tests three seperate times I got slightly different results on some pins.
So, clockwise for the chip on the battery positive side I got all three times:
0.8, 2.8, 0.8, 0.05, 0.05, 0.65
On the chip on the inductor side (clockwise starting left to right with inductor on right) I got on two of the three tests:
2.75, 0.05, 0.05, 0.05, 2.77, 2.77
On the one anomalous test I got these for the inductor side chip:
1.4, 0.05, 0.05, 0.05, 3.78, 3.78
I’m not sure why the 2nd test was different, it’s possible the light bumped up to high mode as I flipped the assmbly over, but I didn’t notice at the time.
It was certainly in medium the third set of tests though and they matched the first results so I would go with those.
Just to clarify for absolute certainty, by clockwise I mean: 1. top left, 2, top middle, 3. top right, 4. bottom right, 5. bottom middle, 6. bottom left
