Hey yes! The 3T6 runs on 1 x 18650! Haha! My Sky Ray does not run on 1-cell, just does not light up. So the drivers are different definitely.
2.65A on 1 x 18650 with Solarforce battery at 4.23V (!!! tends to overcharge on the WF-188...hmmm). The value should be somewhat wrong (due to DMM voltage drop inside the meter), but not too far off. 2-cell is 2.1A actually with fully charged cells and 1.37A on 3-cell.
How to run on 1 cell? Just put coins at the back. Or if you want, magnets. You can do it safely here. DO NOT USE THAT AT THE POSITIVE END, esp with unprotected cells, sure short out in an accident. (eg hard knock)
1 x 18650 @ 2.6A does 87 lux reflected ceiling measurement. Compare this to 130 lux with 2-cell operation, drop of 33% well...not too bad. How much is that 87 lux?
Right after this, my Ultrafire P60 XM-L does 3.1A with the same battery in a L2T with wrapped aluminum foil, got 54 lux. After 30 seconds it dropped to 41 lux. 25% drop due to heat. :D And it continues to drop.....
Compare this to TK70's 250 lux, and the DRY triple at 310 lux initial and 250 steady. (if you are in sub-zero with a light breeze you probably do about 290-300) Those lights haul ass.
Nope...but nobody cares, it is small enough to put into your pocket and its like 15mm longer than your C8 and you don't have to buy 18500s. And the 18500s don't pack as much energy into the cells while i am sure most have good 18650s here. A Panasonic 2900 / 3100 should be a piece of cake even at 4A.
The Sky Ray can do 2 x 18500 and be a bit brighter (not sure how's the status of the reliability now + ordering from the stores, mine is rev 0), but definitely cannot do 1 x 18650 coz I tried. You can order a pair of 18500, but at an extra cost though not much. If you have lights like Sky Ray STL-V2 or Fandyfire STL-V6 (both are same light), then your 18500's investment is not wasted as they can use that as well.
The same one which HKJ evaluated as the cheap meter as in the one you get in MF or DX (DT9205), but the leads are 10A AWG18 ones from my Uni-T. The Uni-T (low-end about $30) went haywire when i measured HID ballasts, you know when a 100W starts up it goes above 10A.
Probably a Uni-T 58E, I think the local electronics shop is selling at $50. Actually most models are around there for our really simple usage in this $$ range. For Flukes you really need to go the really high-end range.
i have not tryed my TR-3T6 3 x 18650 on 1 x 18650 only the normal 2 x 18650,s and the 3 x 18650,s im happy with running two most of the time, i didnt buy this cause it was a pocket torch i have others for that.
its the same as my TR-1200 it can run two or three 18650,s and the battery tube, extention tubes, glass lense and tail cap are all the same.
the only diffrence is the alloy ring inside the bezile on the TR-3T6 is where the TR-1200 drop in screws into and the head has less fins and the TR-3T6 head is larger and made for a screw in, the TR-3T6 it better handled for heat, but ive ran my TR-1200 for many 30 to 50 mins runs on high and one 85 min run on high and its current is pritty steady.
so the TR-3T6 host is just a modded TR-1200 host thats seams to be pritty common on the budget lights use in alot of torches from all over.
internal resistance of the batteries 150 mΩ but you have to take into account my soldering the rare earth magnets and the 18 awg main charge leads.
at the start of the test 2.6 amps at the tail cap (i get readings from 2.6 amps to 2.9 amps with my trust fire flames depending on the Ir of the batteries) for the test i used the lowest current draw of the batteries i have.
starting temperature was 19 degrees c (66.2 f) on the torch head between the bezel and fins and i used a small desk top fan on high to act as active cooling, i would of done this test with a bush walk with the torch on high but the weather has been crap.
run time of the test is 30 Min's timed on an iphone 4 the torch was ran on high mode the whole time.
end temperature of the torch was 29c (84.2f) i unscrewed the drop in (screw in) as quick as i could but by the time i got it out it was 22c (71.6f) all temp readings where done with a digital laser point temp gun at a distance of 300mm (12 inch)
at the end of the 30 min test the current draw had rose to 2.92 amps and the resting voltage of both cells where 3.76v.
i used an old fluke and a cheap DMM to confirm results
i will repeat the test using 3 x trust fire flames over a 45 min period
