Why not just have them build 1000 drivers using the BLF-17DD design files? Once you get up to that many 7135s the runtime before it falls out of regulation is so short there's not much benefit there to offset the higher parts count needed and the resulting bulky double-sided driver.
The current (probably final) revision of the 17DD works with only 6 components, 7 if you add an off-time capacitor. Gate & pulldown resistors have been eliminated since we changed the MCU's power supply circuit (it uses the same parts, just with the capacitor moved from after the D1 diode to before the diode).
Because it’s not regulated. Contrary to popular believe, not being regulated is actually a disadvantage. Once you install a BLF17DD you can’t just hand someone a light and assume they won’t acquire an IMR cell or 4.35v cell/charger down the road. You can blame whatever happens after that on them (whether it’s minor heat issues or poofing the LED), but it’s really on you (me/18sixfifty/whoever). If I build a light with 7135’s I can be pretty confident about what’s going to happen with all the batteries we know about right now. (Grrr)
But even when connected to a triple in parallel and the hottest single cell currently in existence, you won't get much more than 8.5-9A. The many-stacked-7135 drivers aren't really 'regulated' in the true sense, they just have a maximum limit. Their output starts falling (no longer 'regulated') after just a handful of minutes.
That’d drive up the costs because the company has a stockpile of NANJG drivers and all they need to do is flash the MCU and piggyback 4 more AMC7135 chips.
On the flip side, I don’t think it’s possible to blow an LED with direct drive to a 1x li-ion cell, whether it be IMR or charged to 4.35V. Plus, we won’t be randomly handing out flashlights with these drivers anyways.
It may not be possible to blow the LED, but it’s certainly possible to achieve undesired results. Many people using FET drivers seem to use lower drain cells in order to “tame” the FET driver. That only works while you still have the thing in hand, once it’s in someone else’s hands (depending on the person of course) there is a good chance they’ll change cells eventually. Especially if they are getting advice from some random vaping-shop guy (do you guys not see the writing on the wall here? People we sell flashlights to now may eventually walk into one of the currently-ever-increasing numbers of vaping shops for replacement 18650s), he has no idea that the flashlight is entirely unregulated.
And I thought the point was exactly that we’d be handing these things out. I know some of you guys have large flashlight collections, but we’re talking about ordering 20+ of these (identical, mostly single-purpose) things per person… that’s not for a personal FL collection, to me that seems clearly angled at resale or gifting.
comfychair, you can call it what you want… the current limit is unachievable with the DD drivers we have now. I don’t have a better term for it. Any further improvements in 4.35v cells will result in 20-60min of actual regulation I think.
I don’t think the price would be very good going with a fully custom driver, at least not from these guys.
So for now it’s going to be the two sided NANJG style driver with “The Star” modes. Maybe if this actually works out I’ll try and find someone to do the BLF driver in bulk for us.
These sound really good for people who can’t or haven’t got into the driver programming game yet, or those like me that have a problem soldering those pesky 7135 chips.
Only problem i can see is, once you install one of these drivers you’ll probably want to do all your compatible lights with them!
Do people really know what SOS is (the flashing is what catches their attention, not the actual letters)…would be cooler if it just flashed Morse Code “BLF”
Any comments on the mode spacing or hidden modes? Let's make it near perfect before producing hundreds of these.. :)
Especially the order of hidden modes is important. LowLow must be the most used hidden mode, so that's #1. I feel strobe might be the second most important, maybe not most used though. How about other modes? Are they in a good enough order?
Anyone (with the ability to flash drivers) willing to join and help in beta testing of the firmware?
I would agree that LowLow should be first on the hidden. I have never used strobe. I think 90 seconds on the turbo stepdown should be fine as well.
I forgot today was already Saturday (pitfall of being retired) so I won’t hear from the supplier until Monday. I did e-mail and ask them the basic questions. Can they flash, will other people also be able to flash theirs as well, etc.
This looks great but do we really need all the blinky modes? I understand they’re hidden but it’s still too much.
I would be happy with just these modes in hidden:
1. LowLow
9. Turbo that stays on (no timer)
2. Disorienting strobe (randomly alternating 13-19.5Hz 60-40% duty cycle)
4. Beacon with background (1Hz - 50ms Turbo / 950ms Med mode)
8. SOS
My thinking is that extra hidden modes do not bother, as you never have to cycle them through. The firmware is using "short cycle memory" for hidden modes: Route from Strobe to another strobe is: Strobe -> L -> M -> T -> L -> M -> T -> LL -> Strobe -> Strobe2
They just need to be in a correct order, most often used ones first.
[quote=CRX]
1. LowLow
8. SOS
[/quote]
Turbo that stays on is the last hidden mode on purpose. It's potentially dangerous, so it must be the hardest one to get activated.
