Yeah I realized I may have misunderstood in the first post. Based on your reply, I may be misunderstanding something different: are “hidden” modes enterable from “off”? If this is true, a Turbo (never stepping down) would be a useful hidden mode just like the disorienting strobe, and used more than at least 7 of that list of 9 modes and should be easier access than #9 priority. Thats what I was getting at. If not…I’m confused…
I see what you are getting at now. Based on my current understanding, here’s the situation:
to initially get to never-step-down-turbo rather than regular turbo you need to click through the standard 3 modes twice, then click through LL and the blinky modes. So approximately 14 fast taps after the initial turn on in order to get to never-step-down-turbo.
I assume that never-step-down-turbo will be memorized just like the blinky modes are (see post #72). So as long as you don’t change modes it will stay in that mode the next time you turn it on.
My assumption is that this firmware is geared towards having the ability to set a small-bodied light down and then pick it back up without getting scalded.
I’d holler at 15-20 at the right price. Already having the 7135’s added would save a ton of time. As far as modes, simpler would be more preferable. 4 modes (moonlight~~low~~>med->turbo), turbo ramps down to med after 90 or 120 sec. Blinky modes are utterly pointless. Especially a hidden strobe. For a strobe to actually be useful it needs to come on first always, or at a minimum come on easily by holding down (or somehow otherwise preselecting it). An assailant/intruder/giant murderous bad guy isn’t going to wait for you to cycle through to access your strobe mode. Are there any other uses for strobe (I can’t think of any)?
Anyway. That’s all to say that at the right price with simple UI, I’ll take 15-20 pretty please.
The hidden blinky modes are potentially useful as beacons. For that purpose it generally would be OK even if it took you a few minutes to get it into the mode you wanted… (Several of the ones in TheStar are even called beacon. :-p)
My dad said he saw a wrecker guy using his to get peoples attention at night…but I guess the HUGE truck with yellow flashy lights did a better deal than his blinky light
Truthfully if you could build a two group Nanjg style setup, one group L>M>H, 2nd group L>M>H>Blinkies but fix the daggum PWM on it…if people want other than “custom” let them flash them themselves
Maybe a “faster” blink can be programmed instead of the long wink, if someone can program it, or instead of a light interrupt, maybe a slight throttling from low to a moonlight blip so the light doesn’t drop out but for a split second dims (I guess flicker would be a better word)
I hate the long group-change-blink too but like the ability to have flashies if needed…but for “stock” drivers should be simple
I like the 2 group option, would like better PWM and a really fast mode switch blip…
Either or…I will probably just flash em out anyway
OK I ended up getting an early response from them tonight.
It’s yes on the firmware and they will be sending a sample so we can check them out. They are not Nanjg105C they are made in Taiwan but supposedly the same.
Most importantly 18sixfifty, have you anticipated the potential workload involved? 1000 drivers shipped out under the most ideal scenario of 20-25 per order is still a lot of trips to the post office, packaging, printing labels, organising. It’s a big workload and you’re not going to make any money from it. We would all appreciate it immensely because it would be a good deal but I don’t want to tire you out either.
A more realistic scenario would be that your average orders would be 10 or so. That’s a lot of work!
I actually ship from home now so it won’t be too big of a deal. I retired and this is my hobby so it keeps me busy and out of my wife’s hair. :bigsmile:
I’m more worried about actually getting enough people interested so that it’s a go. Well that and making sure that they get it right on their end.
I'll be interested in this one to supply the Euro zone modders too.
If there is any interest in the BLF17DD that I started offering I'll pick up 50 of these. If not then... Substantially less :-(
But I do hope they can be ready made to have off time memory. I am trying to figure out how to make a "scroll one mode back" for clickie switches like Werners UI for momentary switches.... So that'd be cool if the off time memory hardware was there already :-)
I wanted to see how 12x 7135’s would fit. The spring pad I cam up with is nearly the right diameter. 7.5mm is what I got away with in this arrangement. I also got 5x 7135 on the opposite side with the MP and 4 discrete comps. No stars, but that can be solved at the MP. After all, stars are just shorted outputs. Anyone see a problem putting the 7135’s to the edge to maximize the spring OD at the base? This is one thing the 105C limits… spring deflection.
Just another update. They have agreed to do more than one set of modes. So one is going to be THE’s firmware and another set of mode selections my flashpilot.
Did you ask about adding a 1uF capacitor for supporting off-time memory?
Edit: Please don't get me wrong. I'm not forcing or pushing anyone to select TheStar. If most people want a simpler/better/less hated FW, I'm totally ok going with a single batch with that FW. [I don't have any problem flashing my own drivers with TheStar]
