Yes, I just mean what it looks like on the wall/in use. Lots of people seem to have gotten the impression the 10507 is the 'throwiest' of the TIRs... it's far from that. It's just a big fat circle that's the same intensity from the center out to the cutoff. Like a mule with a restrictor on it! ;)
I've not seen a TIR that gave a defined hot spot, with a little spill. They are more like Comfy says. Some type of spot, but it blends out to be just one large beam. That's what they are designed for. They are not really for spotlights. They are for indoor use and they do direct light better than an incandescent does. They do make a spot, but it's not harsh like a reflector, it's more mellow and even. They do what they are intended for, but we try to make them do what they are not intended for.
The 10511 comes with the front face frosted, and in stock form does have a very large fluffy center spot as you'd expect with a frosted TIR. But if you polish it with jeweler's rouge, it turns into something along the lines of a domed XML2 in a 17-18mm OP reflector.
This is the 10507. It's the clear one I always use. The center holes, (from the bottom side), are straight wall and flat up inside. The top holes are straight wall, but are shaped more like an aspheric inside. That way the lens sort of works like an aspheric and produces the beam the way it does. Kind of like a de-focused aspheric lens, which looks like a controlled mule.
Agreed. a front-face polished 10511 produces the best beam pattern by far of any of the Carclo triple optics.
I wonder if Carclo will sell us 10511 optics without the frosting? Is the frosting a final step that they could just omit from a batch sold to BLF? if that’s the case, then there might not be any need for tooling costs.
This won’t help with the problem of fitting an XPL inside, but could produce a more pleasing beam than polishing with jeweler’s rouge.
Thanks. I’ve only tried the “narrow spot” optics myself, laboring under the impressions you described. I don’t have a 10511 but I will now proceed to get one and try that out! Have you found that this also applies to the 20mm optics?
Hmm. Sounds legit, I doubt that the frosting is part of the mold.
I like the idea of the 10511 without the frosting. Anyone know what is the difference in dome height between the XPG2 and the XPL? I had entertained the idea of printing or shaping from small plastic tubing some extensions that would place the optic at the correct distance. Could we do an order of 10511s without frosting and slightly longer legs?
Comfychair, you wrote about experimenting with extending the legs of triple optics and there were issues. What were the problems that you encountered?
The optic doesn’t just hover over the dome, there is a hole in the bottom that the dome must enter. If the dome isn’t enveloped by the optic, you aren’t going to get the desired result.
I think you missed post #19. The reason is an estimated $15k-30k of tooling costs.
We are hoping/assuming that unfrosted triples can be made simply by omitting a step in the manufacturing process. The idea is not directly related to using XP-L emitters in a triple.
OK, but the frosted one is the same as the clear one, except it’s frosted. I don’t get it. The same 10 degree spot, so why does everyone think it’s better? 10507 is 10 degree narrow clear and 10511 is a 10 degree narrow frosted.
The clear 10507 has a different shape directly over the emitters, including the 3 sunken holes. The frosted 10511 is completely flat on the front with no recessed holes.
The beam patterns they produce are quite different from each other. This can be immediately seen when you compare a a rouge-polished 10511 to a standard clear 10507.
Never keep quiet. You had a different understanding of how their shaped. It’s not like you were trying to deceive. And the answer that your post provoked helped me understand why the beams are different. So keep up the good work.
