Well, I was wondering if anyone would recognize the plug on the old Styx song…
My sanity is pretty well known around here, or the fact that it’s mostly gone. (I turn 52 in a few days, my daughter turns 19 the day after, and my son turns 7 10 days after that. Not only is my hair greying, it’s also falling OUT!)
The HD2010 does give the MTG-2 a nice hotspot without being all flood. Hopefully this being a bigger reflector that this may improve again, hope that makes sense.
Stop bragging, youngin!
Mine turned grey and started falling out at 24. Right after my first child was born.
Looked like Jesus when 16 . . . Don Rickles at 35.
Styx? Hmmm, think I’ve got a RECORD of their’s around here somewhere.
I’m pretty sure I bought a diamond needle to mount in the stylus….been a while, I’ve forgotten far more important things since then…
I used to buy a new album, slice the clear wrapping with a blade on top, slide the cardboard cover case out, slide the sleeve out, play the album while recording it to a cassette, then put it all back together carefully, sleeved album slit up in the cardboard case, slit up on the cellophane wrapper. Then I could listen to the cassette to my heart’s content and have a once played album safely stored away. TDK 90 minute tapes, an album on each side. Ah, those were the days! I had 13 speakers in my ’74 Comet, Alpine deck, triple amps, Altec Lansing amplified sub-woofer…first of it’s kind in Temple. That little car rocked! Let’s see, Jensen Triax II’s on each side of the Altec in the rear deck, Sony full range 6 1/2”’s in a custom install in the front floorboard kick panels, Jensen separates glued to the windshield, covered on the outside by black and gold stickers that read “This vehicle protected by Smith & Wesson”. I know one of my amps had a 12 band dual channel EQ, One had a single 10 band, and one had dual channel 5 band, but I forget what brand they were. This was …hmmm…’77-’78?
Did I have a flashlight? LOL A bit later, in ’87, I had the first MagLight D’s that came out. Wasn’t there a yellow Ray-O-Vac with black bezel before that? 2 D’s, exquisitely designed to catch the acids from the alkaline cells? Would I have bought a “Yezl Y3” back then? Probably would have tipped a Jack n Coke and laughed at the name.
Oh well, I’ve definitely got one coming NOW! And a few things to add to it when it gets here. Now, if I can only remember the plan…
Steve, make sure I don’t fall in the ice chest ok?
I hope you don't mind my foot in the ice chest as I sprained it again in that darned hole in your backyard. Just look out for the muddy spot near the hole now.
I plan to do a straight led swap to start with and compare it to the HD2010 which should be running around the same current. Last time I checked it was around 2.7 amps at the tailcap. If I'm happy with it I'll do nothing more.
It’s so hot he likes digging into the earth to get a cooler spot to lay in. Sorry bout that!
Hey guys, here’s some clothespins for your noses while you’re drinkin, Steve’s got his foot in the dang ice chest again! <cough…ugh!
I’m wanting to try that new bin for the MT-G2, so I’ll put one in it when Richard get’s a hold of some. If I can remember to keep checking. I might try another SBT-70 if I get a wild hair. And find all the coin Steve keeps losing in the yard when he falls. Gonna have to charge up the electric scooter for you dude, you’re dangerous walking around loose.
