2 arrived, in boxes and working!
Just got it (boxed version). And I must say that I am now kicking myself in the ass for not grabbing 2 of these.
Pffffft.....no coupon email for me. :( Will prolly still post my thoughts at some point in the other review thread.
My two arrived today, without boxes, but in good shape. Thanks Semur and Agenthex for this.
I tried one of them with a 14500. It works well, but I was unable to mesure the current at the tailcap. It just does a flicker and no reading was possible. It seems the driver doesn't work when there is a DMM in the loop.
Mine seems to arrive next week together with the UF-2100 XM-L 3 mode bought from DD, hope everything is ok and I´ll made a small review. I received today from DinoDirect order 910S3375-DD that´s a C1 tube SKU:A13930000I and 2 Trustfire Flames with a charger SKU:A06740000K, and for my disapointment one of the batteries are dead. Hope Semur can help me with this problem, I already open a RMA.
Try charging the dud battery. The protection has probably tripped.
Got two without the boxes. No problem, less garbage.
I think the most has been said before and they work perfectly.
Thanks a lot for the deal!
Wow, I should check out this sub-forum more often, this flashlight looks amazing at $16...too bad I missed it.
Ive wanted one in that shape for a looooooooooooong time where the head part is at a right angle. I wish more flashlights were like this because its kind of rare.
http://www.nzrimfire.com/viewtopic.php?f=14&t=1911
did try to set one up here on our kiwi forum, but did not get much support.
Not sure if the coupon still works or not
II'z
Doesn't work anymore.
Dam, i missed this :(. Ordered A KD c8, a DRY and as finishing touch a great headlight as this would have finished it all off :). Gonna check this subforum more often!
Hi
They should do a group buy again for this baby. Im sure will be a real success (again).
I know I want some ...
Anybody?
I would get one.
UFH3 is better
Gurus in Electronics: any idea where I could get a new micro-switch for my firends UF-H2?
His boy ate the rubber cap and smashed an apple with the light : light is constantly on / ramping :bigsmile:
Rubber caps needed also, thanks!!
i missed it..
i've ordered a UF headband instead..
I wouldnt mind on buying one either, so Im waiting :D!
If you can get it for under US$40 delivered (including all taxes/fees) it is very well worth the money. If you can't. Buy a Zebralght H50/51 (r whatever the numbers are up to these days)
By around 7 months ;-)
i heard that the parasitic drain is quite substantial (e.g. after 4 weeks) ;)
Yep, if you forget to lock it out... threads are anodized. 1 or 2 turns at the tailcap stops parasitic drain.
