I wonder if those 22650 fit in a L2i body.
Did you manage to test the other IMR 10440? I'm trying to decide whether to buy protected 10440's or these. 130mah on the first one is just too low.
Also, the l2i will fit the 22650's. They're 24mm inside.
I did a test at 1000mA of both of the batteries on the Turnigy and got 188 and 190 whereas the label says 350mA.
Ran the test again, topping them off at 600mA this time to squeeze a little more charge into them and they hadn't lost much charge at all from a couple of weeks ago when I was last messing with them. Discharging at 1000mA one battery now has a capacity of 204mAh and the other a pathetic 46mAh (see below). They sag way, way down under load (down to about 3.7V right away). That's enough for me to say avoid these. In fact, I'd avoid all of the "IMR" batteries from BestInOne just to be safe.
Later: whoops. I may have accidentally tested one battery twice. So the 46mAh reading may have come from the same battery that had just been discharged. I charged the battery I thought was 46mAh and it took just a few mAh, starting out almost immediately at 4.20V. A discharge then gave me 203mAh. So both of these match pretty closely, but well below nominal and I still don't recommend them.
Thanks for the info Brted...I think you're right, best to avoid all of these.
Really? The 10440 and 14500's only seem to be about 2/3 of the capacity of the li-cobalts which doesn't seem too bad.
But doesn’t the cell also have to fit into the tailcap of the L2i? Thats ~22mm.
Good point :D.
Well I got the 18350s and 22650s today so I'm charging in preparation for testing, but I tested the 22650 in the L2i and it DOES fit inside the tailcap until it comes to the threads for the switch retaining ring and then it stops. This results in the cell being a little too long to screw down fully. It does function but the o-ring doesn't engage the body. I think I can find a way to grind down the threads that are holding it up so that it fits properly. (I'm thinking just a sanding drum on the Dremel should do it.)
How would these be compared to Sony, Samsung 18605 LMR s I have?
Here's the 18350s at 3 Amps: (click thumbnail for graph)
I tested both cells 3 times. I'm not real thrilled with the way #2 is lagging behind and just the consistency in general. Still... they perform acceptably. I just wish I had some of the Ultrafire 18350s to compare them to. The #2 cell is getting more capacity with each run, but I wish I knew what I did to get 915mAh out of #1. :) Here they are compared to the AW IMR 18350s:
I took the middle run from each of the generics and here is a single (only) run a pair of the AW IMRs. I like the curve of the AWs a lot better. That would give you higher current reading from the MF UF dropin or the like. The generics look like they're running out of wind at 3A and I bet there would be a big drop in capacity at 5A. But I don't think I'm going to try 5A. They are already getting warm at 3A. I'm doing 1.5A tests now, but I figured that 3A would be most relevant.
I'm going to try them both with the Manafont Ultrafire dropin and get some readings just to compare further.
EDIT: ok... done :)
(MAX from turn-on - tested with my Vichy VC99 with leads from my hobby charger)
AW - 4.325 amps
Generic - 3.506 amps
As long as they hold up, I think they are a good buy. I wish I had a larger sample size, but its safe to say that if your light will hold them, they're going to do better than ANY 16340.
Are you testing the 22650's? I think they're fit a lot of lights that are 3aaa with 18650 option, but most of those aren't terribly great. I have two though.
Yup... I will. I just haven't gotten to it yet.
The 22650 are pretty good. Between 2000 and 2100mAh @ 3A. Here is a graph of an AW IMR 18650, the generic 22650, and a Sanyo 2600 18650 (not IMR):
The only problem it that they don't fit in an L2i like I had hoped. It's possible to make them work, but the machining involved is beyond me. I murdered an L2i tailcap with a Dremel trying to make it work. What we need is solarforce to crank out a 26650 host for 4Ah of goodness. Since the uses for these cells are limited at this point, I'm not going to test them in depth.
This might well work http://www.manafont.com/product_info.php/sipik-ck91-floodtothrow-zooming-cree-q4-convex-lens-led-flashlight-black-3aaa-p-5824
Also small sun c37 for throw.
I got the 26650s yesterday and I just discharged them both for the first time @ 3 amps and got over 3300mAh for both of them. Not mind-blowing, but not bad for half the price of the premium 4000 mAh ones. If they are like the other ones, they'll gain some capacity after cycling them a couple times.
Thanks for bumping this thread Mitro. I am especially interested in the 26650's. I wonder what the cells resisitance are. Too bad there is absolutely no specifications on bestinone's site about these. How long did it take you to receive these cells?
I’ve never actually measure and calculated internal resistance before. So I thought I’d look it up and I get 52 mOhms. Not sure if my math was correct, so here’s my numbers:
3.94v open
3.77 loaded
3 amp load
Did I do it right? :)
56mohm, close enough. these things aren't precise anyway, esp since there's probably load across your meter.
After 3 discharges @ 3A, both cells are right around 3350mAh and have internal resistance comparable to the more expensive Batteryspace or MNKE cells. They just come up ~600mAh short.
Not bad for the price thats for sure. I have 4 of the MNKE 26650's on the way here from China. It's been about a month now since I ordered them from LEDDNA.
