BLF Community Battery Pulls Overview Thread (Laptop packs and Tool Packs)
I think you mean V instead of mAh. :wink:
Der…my bad.
Corrected.
I joined late last week so I could post this harvest album; Only now do I decide to post it :P
Notes on opening packs/VDCs in the descriptions for the images. Image thumbnail is a link, otherwise here
Batteries (Not in Order):
DELL branded C6017 (14.8v 4800mAh 71Wh) --> 8x Samsung ICR18650-24E
HP branded 416996-163 (14.4v 63Wh) --> 8x Sony US18650GR
DELL branded JKVC5 (11.1v 48Wh) --> 6x LG LGDAS31865
Generic HP (Barcode: HP8028LH121105070048; Warranty Sticker: 00761E07B) [14.4v 5200mAh] --> 12x Lishen LR1865AH
Sony branded VGP-BPL2 (11.1v 7200mAh) --> 9x Sanyo UR18650P
Generic HP (Warranty Sticker: 00761D14B) [14.4v 7800mAh] --> 8x Lishen LR1865SF
Tools Used:
Needle Nosed Pliers
Wire Cutters
Chisel
Cheapo Harbor Freight MM
2x Nitecore 2014 i4s
1x HZS-002
1x FT charger
Electrical Tape (I was brutal on the shrinks)
I am interested in what cells these batteries produced. Thanks for the post.
The thumbnail image is a link ;)
2004 Toshiba laptop.
18650 cells
Battery Pack: PA3382U-1BAS
DC 14.8V - 6450mAh
12 Sony US18650GR 2150mAh Green with Black washer
6 cells read 0V, 3 cells read 1.50V, 3 cells read 2.60V
17670 cells
Battery Pack: PA3481U-1BAS
DC 10.8V – 1200mAh
6 Sony US17670GR 2150mAh Green with Black washer
5 cells read 1.50V, 1 cell reads 2.70V
I also had 2 of them (another 7 had a friend)
Philips actually have a recall running due to capacity loss before 3 years change cycle!
we measured them between 950 and 1200 mAh …
into the bin!
Album Link
IBM branded 92P1011/1062 (10.8v 4400mAh) --> 6x Sony SF US18650GR
Lenovo branded 42T5229/5230 (10.8/14.4v 5200mAh) --> 7x Sanyo UR18650FM
IBM branded 08K8193/92P1064 (10.8v 4400mAh) --> 6x unmarked Sanyo UR18650FJ
I noticed in your album link that you are “jump starting” cells that are sitting at voltages too low to charge with your i4.
While that may work to get them to charge, these are NOT like Ni-MH or NiCads and this is NOT a good idea. All that energy that those over discharged cells accept could suddenly and catastrophically be released in a very short time (fire). At the very least, I am sure you have already noticed that those “jump started” cells have a high self discharge rate. That alone make them of no use, and if they self discharge in a short period of time you have a problem. You should safely discharge those cells and recycle them ASAP.
Besides, you now have many cells and can “afford” to be selective on which ones you keep. As a rule of thumb, any cell discharged to below around 2.5V is irreversibly damaged and should be recycled.
thanks great info in here
Will take that into account; I've had SOME luck with quality cells, but I don't want to push it.
I opened my 1st laptop battery pack last week, was from my 6yr old abused Dell Inspiron 6400, the battery failed to hold more than 2mins charge around 4yrs ago and has been used from the mains daily with battery attached for last 4yrs.
Inside were 6 x pink samsung ICR18560-26C, all voltages were 3.4v-3.8v, charged them to just under 4.20v and 5 days later they are all around 4.10-4.15v.
Sorry but I forgot to note down the exact battery part before I trashed the plastic casing, I do have some packs coming my way though so will record the details for the thread.
Thanks guys, I have been really busy lately and will get things updated soon.
Dewalt 4.0 Ah 18 V packs contain 10 pieces of Samsung 20R batteries (green color) 2000mAh.
I've ordered 10 of those & will update when they arrive, relisted here: http://www.ebay.com/itm/141355585144
That's the same seller that had another batch of different ones a while back, can't remember if they were the Panasonic 2900s or Samsung 28As...
The white ones were Samsung –28A cells.
Also, a Dell PT434 battery comes apart fairly easily. Had one for my ‘gaming’ [it will run WoT on low graphics, and RCT3 @ max cleanly] laptop that wouldn’t hold a charge, popped it apart and the six 2550mA USGR’s inside tested between 3.7 and 3.8v.
Playing battery roulette at the flea market...
Album Link
Sony branded VGP-BPS5A (7.4v 7800mAh) --> 6x Sanyo UR18650FM (All dead; 0.05-0.06v)
Dell branded TC030 (11.1v 85Wh) --> 9x LG LGDB118650 (3x 0.00v 6x 4.12v)
Will heed dchomak's warning and not push my luck :P
HP MU06 notebook battery for CQ42 / CQ62 / CQ72 / G62 / DM4-1000
HP P/N: 593562-001
6 cell 11.1v 62wh 5225mah
Samsung ICR18650-28A
Thanks for doing this! It’s a huge help.
