Most RF devices you’re gonna be able to buy are component level and would need a uC with logic control to work, it’s very unlikely you’ll be able to find a stand-alone receiver that provides a simple on/off output the driver needs without a dedicated control circuit and it’ll be hard to find a circuit that can fit in that light.
Your best bet would be to try to mod the factory driver for more current. You could also let us have a look at the factory driver, maybe if you get lucky the RF MCU is a different component from the LED driver’s MCU and you could piggyback / airwire a 13A onto the driver replacing the LED driver portion of the board’s MCU to have control of the modes.
If his end goal is more throw why not leave the driver stock and/or resistor mod it and just swap in a dedomed XP-G2 / XM-L2? That would double or more the throw and you wouldn’t have to worry about the driver.
So here are some pics of the stock driver. I don’t know what I’m looking at but maybe it means something to you guys. Unfortunately there are components hidden between the two boards. I can separate them but I’ll wait for a response before I do that.
LD-36 requires a momentary non-latching switch, it can be packaged very very small with very small wires (a 2-conductor single cable would be least troublesome, probably), so the switch can still be remote mounted, it just won't be wireless. It carries no current like a clicky switch, it only grounds a pin on the controller to tell it to change modes/on/off.
That curly etch is the antennae in the first shot. Too much hidden under the top one. I would just leave it in, do the emitter swap like suggested as you don’t know how to use an ohmeter (I assume). If you know what a resistor looks like, you can color in one resistor at a time with a pencil and switch the light on and off, find out which resistor increases power to the light. Use alchohol and a qtip to take it off. Looks like the good stuff you need to get at is hiding under that board.
That’s me though, I don’t know anything about custom drivers like these other guys. Just used to overclock video cards by replacing resistors, or putting in a variable resistor so you could adjust the resistance on the fly. The thing with wires is in hunting that might not be a good idea. Your wet and I can see it coming off or getting in the way. Your friend yelling ^&%$ing pink panda I’m going to kick his ass!
Hehe, I could see that happening too. Also he doesn’t mount anything unnecassary on the gun e.g. he straps the remote button to his finger.
Stock batteries is 2x 18650 and led is XP-G2. That big resistor is just near the pins to the led (just to the left outside the red circle). Does that mean it’s a sense resistor? I’ve never tried using a pencil over the resistors but sounds simple, I’ll try it tonight.
Graphite (penciling) is used on the video cards to tweak pretty high value resistors IIRC. I don’t see it working well for sense resistors (extremely low value resistors).
The good news here is that the RF board is standalone, other than the antenna. The RF board is already setup for momentary output (it’s set by the jumper on top). Take a look at the info here.
All you need to do is make yourself a little harness and probably power it off of whatever regulated voltage the MCU on your LCK-LED driver uses. As you can see, the antenna is simple, simple, simple. You could easily make one. Just measure the total length of the coiled trace on the larger PCB and cut a wire to the same length. Done!
NO! It may look simple, but it is not. The design of these things involves a lot of obscure physics and black magic. Things like dielectric constants, impedance matching, skin effects, S-parameters, etc. That simple squiggly wire is anything but… at microwave frequencies nothing is simple or straightforward.
Hate to argue :_(, but you frequently do this TP. AFAIK it is that simple when you’re dealing with these commodity RF boards at low range. (also in lots of other situations!) Hence the simple, lame whip antenna that Helios pointed out after I posted about making the same thing. No need, it’s already been done because it is that simple.
Just because all those real & complicated physics problems are in play doesn’t mean the solution can’t be simple.
Yeah texas, wight is right in this case. You don’t have to worry about impedance because it’s a one way deal, transmitter to receiver. The receiver isn’t transmitting anything so keeping a low swr doesn’t matter in this case.
Cool that would be a simple fix, attach that to the driver, you could even add modes like that… He could blind Fleece Johnson with the strobe and finish him off with turbo. Wight knows what he’s doing- take my coat and exits the building lol
Having modes put in depending on how long he holds it could work. He might not shoot you for screwing up his light, but it would probably have to default back to his favorite after he turned it off imo.
You could contact them for a sample. Many manufacturers will sample at reasonable prices. I’d just use the existing one though, I do not think there is much risk to it. (Less risk than resistor-modding the driver for example.)
I’m not really sure, but I doubt that you could use the KS-15RD with the existing remote switch. Why don’t you see if you can get us pics / info about the other side of the receiver PCB? It may be that they are simply rebranding/cloning something else which is more available. I suspect that even more because they fail to show the other side on their website…
EDIT: if you don’t like any of that… how large is that remote switch housing? You may be able to replace the guts like you are doing with the weaponlight. In that case you could just drop in a ~$10USD TX/RX pair…
Hmm, I like this train of thought. I think STAR could be easily modified to be short press for on/off for a “main” mode and long press will always take you to a “special” mode from any state (on or off). That seems like a predictable and easy to learn system for 2 modes, although I’m not sure it’s useful here. This seems to be a hunting weapon light, not tactical. Full blast may be the only mode needed.
No, that looks like a 2.4 GHz RF module that uses something like the Nordic transceiver chips. Look at how the Flex Asgard bluetooth flashlight failed They tried to cobble a simple antenna onto it (bypassing the PC board antenna) and could not get signals in/out of the flashlight… also had lots of problems with their interface ap
Due to the short range of the link, you might be able to get by with a simple wire. But you are also trying to get the signal into a metal light housing…
My Asgard driver retrofit into a D cell Mag works fine, AR lens but plastic reflector (stock Mag LED part). It's reliable up to about 10 feet, as if you'd ever need to use it like that.
